Enable ENUM Session Agent Group Matching
When you want the Oracle Enterprise Communications Broker (OECB) to consider session agent groups as part of the response from the ENUM server, set the enum sag match parameter in SIP config to enable. With this parameter enabled, the OECB matches session agent group names received from the ENUM server with the hostname portion in the naming authority pointer. In this way, the OECB supports a group of session agents as a SIP designation in the OECB ENUM request.
You can enable and disable enum sag match from either the command line or the GUI.
From the command line
ecb# configure terminal ecb(session-router)# sip-config ecb(sip-config)# select ecb(sip-config)# enum-sag-match <enabled> <disabled> ecb(sip-config)#done ecb(sip-config)#exit ecb# save-config ecb# activate-config
From the GUI
- Go to Configuration, SIP Interface, SIP-config
- On the SIP-config page, and enable enum-sag-match.
- Save the configuration.
