LDAP and Oracle ECB Authentication
Lightweight Directory Access Protocol (LDAP) is the Protocol that the Oracle Enterprise Communications Broker uses to perform queries to the Enterprise’s Active Directory to validate registration attempts in the Enterprise network. Requests and responses are sent/received based on the Oracle Enterprise Communications Broker’s LDAP configuration. The Oracle Enterprise Communications Broker's LDAP client queries an LDAP server, usually Active Directory for password information for a user attempting to register. This request and response process verifies that the user can get registration servers (authorization) and verifies that the user is who they say they are (authentication). Once both these stages complete successfully, the Oracle Enterprise Communications Broker registers the user.
The Oracle Enterprise Communications Broker, using LDAP, performs the following on a registration attempt:
  • Creates an LDAP search filter based on the dialed number and the configured LDAP attributes.
  • Sends an LDAP search query to the configured LDAP server.
You configure LDAP servers and filters, on the Oracle Enterprise Communications Broker.
The Oracle Enterprise Communications Broker keeps a permanent LDAP session open to all configured call servers. It sends an LDAP bind request on all established connections, to those servers. The first call server is considered the primary LDAP server, and all others are secondary LDAP servers. If a query request sent to the primary server fails, the Oracle Enterprise Communications Broker sends the request to the next configured LDAP server, until the request is successful in getting a response. If no response is received by the Oracle Enterprise Communications Broker, it replies to the registering endpoint with a (401? authentication failure?).
