Alphanumeric User Database and Call Routing Entries
The Oracle Enterprise Communications Broker (OECB) allows you to enter alphanumeric entries in the User database and in the routing table because it can modify the request URI to use either alphanumeric or numeric entries, depending on the setting you choose for egress-URI-mode.
Egress-URI-mode
- No-conversion (Default)—The OECB adds only the IP address of the Home Agent in the outbound call.
- Convert-to-aor— When the incoming URI is a number, the OECB replaces it with the configured address of record in the outbound call.
- Convert-to-number—When the incoming URI is an Address of Record, the OECB replaces it with the configured number in the outbound call.
Example
Assume that the User database includes "aor1@oracle.com" for the AOR, "123@oracle.com" for the number, and the destination agent is named Agent123.
- If the request URI in the incoming call is "aor1@oracle.com", and the egress-URI-mode for Agent123 is set to "convert-to-number", the OECB modifies the request URI to 123@oracle.com.
- If the request URI in the incoming call is "123@oracle.com", and the egress-URI-mode for Agent123 is set to "convert-to-aor", the OECB modifies the request URI to "aor1@oracle.com."
- If you set the egress-URI-mode for Agent123 to "no-conversion", the user part of the request URI remains unchanged. The OECB changes only the host part of the request URI to use the IP address of Agent123.
Alphanumeric User Database Entries
| Address of Record | Number or Pattern | Home Agent | Dialing Context |
| username1@company.com | 1234567890@company.com | Agent1 | region.country |
| username2@company.com | 1234567890 | Agent2 | region.country |
| username3@company.com | Agent3 | region.country | |
| username1@1.1.1.1 | 1234567890 | Agent3 | |
| 11234567890 | Agent4 | ||
| 12324567890 | Agent4 | ||
| 12345678[01-04] | Agent5 | ||
| xxxxxxxxx | Agent5 |
- 12345678xx@company.com
- 12345678xx@country1.company.com
- 12345678xx@country2.com
- 123456[01-20]@country.company.com
Example of a valid configuration
The following example shows the Address of Record and the Number or Pattern entered in the User database in a valid configuration, where the entries are properly formatted.
| username@company.com | 1234567890@company.com | Agent1 | region.country |
With "convert-to-number" selected, the OECB modifies the request URI to use the number 1234567890@company.com. With "convert-to-aor" selected, the OECB modifies the request URI to use the Address of Record username@company.com.
Example of an invalid configuration
The following example shows an invalid user record which includes two different address of record entries for one user (rows 1 and 2), and duplicate address of records for two different numbers (rows 3 and 4).
| user@1.1.1.1 | 1234567890@company.com | Agent1 | region.country |
| auser@company.com | 5551234567@company.com | Agent1 | region.country |
| auser@company.com | 0005551234@company.com | Agent1 | region.country |
Routing Table Entries
- 1234567890
- 123[000-999]
- 123[x]xxx
- 1234567890@company.com
- user_name@company.com
- user.name@1.1.1.1
Dial Plan Lookup
When the OECB attempts a dial plan lookup, it first confirms that the user part of the request-uri is a valid phone number. For a valid number, the OECB performs the dial plan lookup. When user part of request-uri is an alphanumeric string, the OECB skips the dial plan lookup.ENUM
When the OECB uses a configured route to an ENUM server, it does not convert the request-uri as specified in the destination agent configuration. If the destination agent (returned by the ENUM server) is not reachable, and OECB chooses a backup route from the user database, the OECB converts the request-uri of the outgoing INVITE based on the egress-uri-mode parameter set for the destination agent in the user database.
LDAP
When a user database entry and an LDAP entry both exist, the OECB gives priority to the entry in user database. Conversion of the request-uri is performed based on the configuration of the destination agent. If a user database entry does not exist, LDAP takes the precedence and the system does not convert the request-uri.
