Updating DPDK
This
section provides the instructions to update DPDK after a Kernel update.
To update DPDK:
You must perform the instructions in this section if you have installed another Linux Kernel.- Reboot the system.
- Follow the procedure detailed in Installing and Configuring DPDK with Internet or Installing and Configuring DPDK without Internet depending on your setup.
- Reboot the machine that hosts the probe or mediation engine and probe.
