Configuring Proxies and Repos
You are required to configure the proxies and repos.
Configure the http proxy in /etc/yum.conf file and also export the same to environment by doing the following.
In
/etc.yum.conf, add the following line:
proxy=<Your_Proxy>
where, <your_proxy> is the proxy server details.
Run the following command to export to the environment:
export http_proxy=<Your_Proxy> export https_proxy=<Your_Proxy>
Run the following command to enable the required proxies in
yum.conf file before upgrade:
curl -O https://yum.oracle.com/public-yum-ol7.repo mv public-yum-ol7.repo /etc/yum.repos.d/public-yum-ol7.repo yum-config-manager --enable ol7_latest ol7_UEKR4 ol7_developer_EPEL ol7_optional_ latest ol7_addons ol7_UEKR3 ol7_UEKR5
