Configuring Apache for Authenticating with LDAP Service
The NGINX Web Server provided with Session Monitor does not support the external authentication. To enable external authorization you are required to have NGINX Web Server that provides external authentication and is optional.The following procedure explains configuring external authentication using Apache Web Server as it is widely used.
To configure Apache in Session Monitor for authenticating with LDAP service:
Result: The httpd server of Session Monitor has been configured for external authentication.
When you open the Session Monitor in web browser, the external authentication pop-up appears. On providing the correct LDAP user credentials, the user will be logged in successfully.
