Known Issues
The following table lists the known issues in version 4.2 of Oracle Communications Session Monitor.
| ID | Description | Severity | Found In |
| 29757880 | The default active calls graph is not displaying as expected. | 4 | 4.2.0.0.0 |
| 29823958 | Packet inspector is not masking supported headers | 3 | 4.2.0.0.0 |
| 29835976 | When Mediation Engine is connected to Mediation Engine Connector via ext authentication, Mediation Engine alerts are not displayed on the connector | 3 | 4.2.0.0.0 |
| 29895638 | Call info is not displayed when a call is run in an Established state | 3 | 4.2.0.0.0 |
| 29946916 | Mediation Engine does not display the device KPI Call Attempts per Second | 3 | 4.2.0.0.0 |
| 29947559 | IMSI search only returns exact match results | 3 | 4.2.0.0.0 |
| 29965117 | In Fraud Monitor, configuring to username filter creates an incident | 4 | 4.2.0.0.0 |
| 29999562 | When exporting devices to CSV format, 3PCC does not save as Enabled. JSON export continues to function as expected | 3 | 4.2.0.0.0 |
Resolved Known Issues
The following table provides a list of previous known issues that are now resolved in 4.2 GA.
| ID | Description |
| 29952724 | Ensure users can view and add panels only for what they have permission to manage |
| 29939401 | Web session inactivity time-out is enforced as according to configuration |
| 29743505 | Cannot search for users that are not on the main user page |
| 29899590 | OCOM username does not allow special characters |
| 29754178 | FDP crash observed when running call with To/From headers missing the "userinfo" field |
| 29606673 | Diagnostics do not include PSA Version Table Entry |
| 29724786 | VSI crash observed when call event publisher is to be enabled |
| 28364504 | Skype probe installation fails on machines in a server pool |
| 29439407 | Unable to access Web GUI on MEC after upgrading to 4.1.0.2.0 |
| 29434370 | Multilib library version incompatibility while installing OCSM 4.1.0.2.0 |
| 29327721 | Fraud Monitor "to-phone-number" filter type does not allow regex |
| 29232952 | Ensure voice quality modules are not accessible to users with no voice quality permission |
| 29231708 | Ensure users cannot add alerts for modules they are not permitted to use |
| 29209386 | MEC-ME-SSL connection using regenerated self-sign certificates fails for second ME node |
| 29199158 | Restoring large configuration savepoints fails with "transaction aborted" or "504 gateway timeout" messages |
| 29041454 | pld-vsi.service restarts due to memory cghealth with customer traffic (SCTP) |
| 29031775 | OCSM: (mgcp_probe) crash results in drop in OCSM graph |
| 28895459 | Slow performance and messages log full with "WSGIControllerComponent.py" exception |
| 28816572 | MEC : Not able to log in when "Remember Me" is checked |
| 28814340 | OOCM 4.0 has invalid cron job "killall vsi" under pld-scripts |
| 28805519 | Counter: Total number of active calls Keyerror:0 |
| 28726653 | On the user tracking page, search is not working as expected |
| 28696863 | Red bars and pld-diamond.service crashing |
| 28461807 | Unable to download pcap. "Sorry, an error occurred while processing your request" error displays. |
| 28417903 | Link quality showing exception error when adding an IP |
| 28366322 | "Failed to find probe on ME" error |
| 28360801 | OCOM does not correlate From-URI user part (using uri_user test) AND x-to parameter of From header (using hf_param_equals test). These values can now be correlated with the hf_uri_param_equals test. See the Call Merging Algorithms chapter in the Operations Monitor User Guide |
| 28250113 | MEC admin unable to delete users created by admin |
| 28186912 | Blank "Recent call stats repartition" panel on Dashboard |
| 28077766 | All media legs are visible from "Media Summary" and "Media Details" even when user is configured for limited traffic visibility |
| 27823620 | Calls no longer stored on disk: "int exceeds XML-RPC limits" error |
| 27686830 | "The selected call is no longer stored on disk" error occurring for recent calls |
| 27659806 | E-Mail Alert Notification from OCFM is always in UTC timezone |
| 27627444 | Register Message Correlation for same endpoint towards more than one Registrars |
| 27596954 | Intel X710/i40e driver support |
| 27302448 | SIP response 404 cannot be seen under Calls for TCP flows |
| 27143434 | Too many streams error even with concurrent streams being recorded not on max |
| 20922461 | PI tries to reach non configured probes |
| 23213095 | Display vlan tags in message flow (toggle option) for SIP and RTP flows |
