PreviousNextJavaScript must be enabled to correctly display this content
Unsecure Option
If you do not wish to use encrypted connections, for instance for testing, you can allow unsecure connections from SBCs on the Trusted Certificate panel. You can then disable the TLS option in the SBC. These connections will use port 4739. However, this setup is not recommended in production.
