Supported Upgrade Paths
This release has been tested for upgrades from specific prior releases. Verify that your current installed release is listed on a valid upgrade path. The possible upgrade paths to Session Monitor 4.2 are listed below.
Table 1-1 Supported Upgrade Paths
| From | To | Mechanism |
| 3.3 | 4.2 | Migrate from 3.3 to 3.4 and then upgrade to 4.1 through RPM |
| 3.4 | 4.2 | RPM Upgrade |
| 4.0 | 4.2 | RPM Upgrade |
| 4.1 | 4.2 | RPM Upgrade |
It is recommended to have both Probe and Mediation Engine in the same version of 4.2p1.
