PreviousNextJavaScript must be enabled to correctly display this content
OCSLB Configuration for IMS-AKA and TLS Traffic
The user makes the settings below to the applicable
cluster-config
element on the
Oracle Communications
Subscriber-Aware Load Balancer (OCSLB) to support
IMS-AKA and TLS traffic. These setting allow this support by preventing the
OCSLB from restricting the type
of traffic supported by the cluster.
From superuser
mode, use the following ACLI command sequence to access the
cluster-config
element.
