show balancer metrics
The Oracle Communications Subscriber-Aware Load Balancer (OCSLB)'s show balancer metrics command displays a comparison between the number of local endpoints (that is, the associations between source addresses and each OCSBC) and the number of remote endpoints (that is, what the OCSBC reports to the OCSLB as the number of endpoints it has received via the tunneled interface). In the following output, those two numbers are the same; this is true if and only if there are no users in the access network that have multiple phone lines sourced from the same IP address. Were that the case, the number of remote endpoints would be higher than the number of local endpoints.
This table is populated with the data received in the periodic heartbeats from the OCSBC to the OCSLB. As these heartbeats are somewhat infrequent (every two seconds by default), the data in this table should only be considered accurate within two seconds.
ORACLE# show balancer metrics local remote max max Over SBC Name epts epts max reg CPU CPU Mem% Mem Load --- ----------------------- ----- ---- ------- ---- ---- ----- ----- ---- 93 magichat 0 0 480000 2.7 90.0 0.9 95.0 no 94 westy 0 0 480000 2.7 90.0 0.8 95.0 no 95 samadams 0 0 480000 2.8 90.0 0.7 95.0 no 96 bass 0 0 480000 4.3 90.0 2.8 95.0 no 97 sixtus 0 0 480000 2.9 90.0 12.8 95.0 no 98 newcastle 0 0 480000 2.9 90.0 1.8 95.0 no 99 guiness 0 0 480000 3.6 90.0 0.8 95.0 no ORACLE#
Fields descriptions include:
- SBC contains the OCSBC handle.
 - Name contains the OCSBC hostname.
 - max reg contains the maximum number of endpoints the OCSLB will send to this specific OCSBC. Its value is derived from the product of the session-multiplier parameter in the cluster-config configuration element and the OCSBC’s licensed session capacity. The OCSBC passes this value to the OCSLB during the OCSBC’s registration process into the cluster.
 - CPU contains the last received information on the CPU percentage from this OCSBC.
 - Max CPU contains the threshold percentage at at which the OCSBC defines itself as overloaded.
 - Mem contains the last received information on the Mem percentage from this OCSBC.
 - Max Mem contains the threshold percentage at which the OCSBC defines itself as overloaded.
 - Overload displays whether or not the OCSBC is reporting itself as overloaded to the OCSLB.
