Platform Support
The Oracle Communications Subscriber-Aware Load Balancer can be run on the platforms listed below.
Acme Packet Platforms
The S-Cz8.3.0m1p2 version of the
Subscriber-Aware Load Balancer supports the following platform:
- Acme Packet 6100
Supported Hypervisors
The Oracle Communications Subscriber-Aware Load Balancer supports the following hypervisors starting at version S-Cz8.3.0:
- KVM: Linux version 3.10.0-123 or later, with KVM/QEMU (2.9.0_16 or later) and libvirt (3.9.0_14 or later)
- VMware: vSphere ESXi Version 6.x or later (Version 6.5 or later is recommended)
- XEN: Release 4.4 or later
OpenStack Compatibility
Oracle distributes Heat templates for the Newton and Pike versions of OpenStack. Use the Newton template when running either the Newton or Ocata versions of OpenStack. Use the Pike template when running Pike or a later version of OpenStack.
