Sample Load Balancer Policy Configuration
The following formatted extract from show running-config ACLI output shows a sample load balancer policy configuration with port-aware-balancing enabled.
lbp-config state enabled log-level NOTICE untrusted-grace-period 30 max-untrusted-percentage 20 max-untrusted-upper-threshold 80 max-untrusted-lower-threshold 70 end-point-capacity-upper-threshold 80 end-point-capacity-lower-threshold 70 red-port 0 red-max-trans 500000 red-sync-start-time 5000 red-sync-comp-time 1000 port-aware-balancing enabled options strategy least-occupied last-modified-by admin@console last-modified-date 2015-11-07 18:49:04
