Upgrade Checklist
Before upgrading the Oracle Communications Subscriber-Aware Load Balancer software:
- Obtain the name and location of the target software image file from either Oracle Software Delivery Cloud, https://edelivery.oracle.com/, or My Oracle Support, https://support.oracle.com, as applicable.
- Provision platforms with the Oracle Communications Subscriber-Aware Load Balancer image file in the boot parameters.
- Run the check-upgrade-readiness command and examine its output for any recommendations or requirements prior to upgrade.
- Verify the integrity of your configuration using the ACLI verify-config command.
- Back up a well-working configuration. Name the file descriptively so you can fall back to this configuration easily.
- Refer to the Oracle Communications Subscriber-Aware Load Balancer Release Notes for any caveats involving software upgrades.
