SLB Tunnel Configuration
The Oracle Communications Subscriber-Aware Load Balancer (OCSLB) sends and receives signaling messages to and from clustered OCSBCs through an IP-in-IP tunnel. The OCSLB requires one tunnel per interface.
Use the following procedure to perform required OCSLB-side tunnel configuration. Completion of tunnel configuration is accomplished on the clustered OCSBCs as described in OCSBC Tunnel Configuration.
