show balancer statistics
The show balancer statistics command displays statistical output pertinent to low-level events on the OCSLB. The contents and output of this command are subject to change, and will be documented in a subsequent document release.
ORACLE# show balancer statistics
Balance stats:
LBP agent not found 0
packets dropped by standby 0
max capacity reached drops 0
total packets processed 3
packets dropped in balance 0
group not found 0
service not found count 0
untrusted dropped 0
invalid endpoint 0
duplicate ept packet drops 0
insert error 0
Tx packet failed count 0
throttle drops 0
sbc not found drops 0
forwarded duplicates 0
policy miss 0
realm miss 3
throttle skips 0
throttle policy skips 0
EPT mgmt stats:
untrusted age outs 3
Total Endpoint add reqs 3
Endpoints added 3
ept added as trusted 0
ept add invalid 0
ept added unknown state 0
ept added success 3
ept insert not valid 0
ept insert not pend 0
EPT add errors 0
no endpoint handles 0
already added 0
ept add db fail 0
flow add err 0
datapath add err 0
Total Endpoint update reqs 0
Endpoints updated 0
endpoint not valid 0
endpoint being deleted 0
endpoint already trusted 0
endpoint not found 0
unknown trust state 0
not untrusted pending 0
not trusted pending 0
trusted not valid 0
cbk unknown state 0
bad callback 0
ept update success 0
EPT update errors 0
update param err 0
find group err 0
invalid index 0
flow update err 0
ept upd cbk invalid 0
datapath upd err 0
marked invalid 0
not pending 0
not inserted 0
Total Endpoint remove reqs 3
CCD/RED Endpoint remove reqs 0
Endpoints removed 3
unknown state 0
del not wait 0
del not pend 0
ept delete success 3
EPT delete errors 0
find group err 0
invalid index 0
delete in progress 0
endpoint SBC mismatch 0
ept del invalid 0
ept del db fail 0
datapath del err 0
insert wait 0
insert not pend 0
trusted endpoints (EPT db) 0
untrusted endpoints (EPT db) 0
total trusted endpoints 0
total untrusted endpoints 0
total endpoints 0
available endpoint handles 5000000
Map / queue sizing:
insert size 0
trust size 0
remove size 0
Max requests, etc.
g_lbpMaxRequests: 0
g_lbpMaxRequests_highwater: 1
g_lbpMsg_highwater: 0
g_lbp_setEndpointTrustLevel 0
g_lbp_removeEndpoint 0
g_lbp_max_untrusted 10000
g_pendingHAListHighWater 0
g_pendingHADelListHighWater 0
