SLB Configuration
This section explains how to configure functionality specific to the Oracle Communications Subscriber-Aware Load Balancer (OCSLB); it does not include configuration steps for functions that it shares in common with its corresponding Oracle Communications Session Border Controllers (OCSBCs) (for example, system-config, phy-interface, network-interface, and so on). For information about general OCSLB configuration, refer to the appropriate documentation as listed in About This Guide.
OCSLB configuration is quite simple; aside from basic network connectivity, the service interfaces, and the distribution policy, much of the configuration is learned dynamically from the OCSBCs that comprise the cluster.
