Go to primary content
Oracle® Communications Binding Support Function Cloud Native Installation and Upgrade Guide
Release 1.0
F16985-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Verifying BSF Upgrade
Upgrade should ensure all pods under BSF namespace are updated based on the helm upgrade setting.
Execute below command:
kubectl get pod -n <BSF-Namespace>
Verify the following from the output of the above command:
  • All pods under BSF namespace should either be in Running status or in Completed status. If any pod with error except for kong-migration pod status found, check pod log to view the reason for error.
  • For updated service per helm upgrade setting, check its RESTART output and AGE output, if specific had been updated then the old pod should be killed and a new pod should start up. Hence, related RESTART value should be 0 and AGE value should be 3-4 seconds.
  • API gateway service and CM service should support MetalLB setting.
