Go to primary content
Oracle® Communications Binding Support Function Cloud Native Installation and Upgrade Guide
Release 1.0
F16985-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
1 Introduction
This document provides instructions to install Binding Support Function.
Overview
The Binding Support Function allows Policy Control Function to register, update, and remove the binding information from it, and allows Network Function (NF) consumers to discover the selected Policy Control Function.
The Binding Support Function stores the binding information for a certain PDU sessions and discovers the selected Policy Control Function according to the binding information. It also acts as diameter proxy agent or diameter redirect agent to Rx requests targeting an IP address of a UE to the selected Policy Control Function.
For any AF using Rx, such as P-CSCF, the Binding Support Function determines the selected Policy Control Function address according to the information carried by the incoming Rx requests.
