Go to primary content
Oracle® Communications Binding Support Function Cloud Native Installation and Upgrade Guide
Release 1.0
F16985-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Verify kong API Gateway Service
As the entrance of BSF, all request goes through API gateway to specific service. It is necessary to verify if it works.
Refer to Enabling Loadbalancer with MetalLB for detailed description to update API gateway service to use loadbalancer.
Run the following command and get API gateway service name <BSF-Name>- pcf-api-gateway.
kubectl get svc -n <BSF-Namespace>
The service must have an external IP allocated, and default administration port value 8001. Get the below URL: http://< API_GATEWAY_EXTERNAL_IP>:8001/services.
