The
host.ini
file contains the inventory used by the various OCCNE deployment containers
that will instantiate the OCCNE cluster.
Template example
OCCNE Variables
| Variable | Definitions |
| occne_cluster_name | k8s cluster name |
| nfs_host | IP address OS install nfs host (host running the os_install container) |
| nfs_path | path to mounted OS install media on nfs host. This should always be set to /var/occne/ |
| subnet_ipv4 | subnet of IP addresses available for hosts in the OCCNE cluster |
| subnet_cidr | subnet_ipv4 in cidr notation format |
| netmask | subnet_ipv4 netmask |
| broadcast_address | broadcast address on the OCCNE cluster on which pxe server will listen |
| default_route | default router in the OCCNE cluster |
| next_server | IP address of TFTP server used for pxe boot (host running the os_install container) |
| name_server | DNS name server for the OCCNE cluster |
| ntp_server | NTP server for the OCCNE cluster |
| http_proxy | HTTP Proxy server |
| https_proxy | HTTPS Proxy server |
| occne_private_registry | OCCNE private docker registry |
| occne_private_registry_address | OCCNE private docker registry address |
| occne_private_registry_port | OCCNE private docker registry port |
| metallb_peer_address | address of the BGP router peer that metalLB connects to |
| metallb_default_pool_protocol | protocol used to metalLB to announce allocated IP address |
| metallb_default_pool_addresses | range of IP address to be allocated by metalLB from the default pool |
| pxe_install_lights_out_usr | ILO user |
| pxe_install_lights_out_passwd | ILO user password |
| pxe_config_metrics_persist_size | (optional) Logical volume size for Metrics persistent storage, will override default of 500G |
| pxe_config_es_data_persist_size | (optional) Logical volume size for ElasticSearch data persistent storage, will override default of 500G |
| pxe_config_es_master_persist_size | (optional) Logical volume size for ElasticSearch master persistent storage, will override default of 500G |
