| Oracle® Communications Cloud Native Diameter Routing Agent (CNDRA) Installation Guide Release 1.0 F16991-02 |
![]() Previous |
![]() Next |
The following table provides information about the acronyms used in the document.
Table 1-1 Acronyms
| Field | Description |
| CIDR | Classless InterDomain Routing |
| CNDRA | Cloud Native Diameter Routing Agent |
| CNE | Cloud Native Environment |
| DRA | Diameter Routing Agent |
| draWorker | A node that process diameter traffic |
| EFK | Elastic search , Fluentd and Kibana stack |
| NF | Network Function |
| OSDC | Oracle Software Delivery Cloud |
| OCCNDRA | Oracle Communications Signaling, Cloud Native Diameter Routing Agent |
| OverSeer | A service that supervises pods of draWorker svc |
