| Oracle® Communications Cloud Native Diameter Routing Agent (CNDRA) Installation Guide Release 1.0 F16991-02 |
![]() Previous |
![]() Next |
This section includes information about the required environment for CNDRA deployment.
CNDRA Software
The CNDRA software includes:
The following software must be installed:
| Software | Version |
| Kubernetes | v1.12.5 |
| HELM | v2.11.0 |
Additional software that needs to be deployed as per the requirement of the services:
| Software | Chart Version | Notes |
| elasticsearch | 1.21.1 | Needed for Logging Area |
| elastic-curator | 1.2.1 | Needed for Logging Area |
| elastic-exporter | 1.1.2 | Needed for Logging Area |
| logs | 2.0.7 | Needed for Logging Area |
| kibana | 1.5.2 | Needed for Logging Area |
| grafana | 2.2.0 | Needed for Metrics Area |
| metallb | 0.8.4 | Needed for External IP |
| metrics-server | 2.4.0 | Needed for Metric Server |
| tracer | 0.8.3 | Needed for Tracing Area |
In case any of the above services are needed and the respective software is not installed in CNE. Please install software before proceeding.ClusterRole and
ClusterRoleBinding
resources.
Network access
The Kubernetes cluster hosts must have network access to:
All the kubectl and helm related commands that are used in this document must be executed on a system depending on the infrastructure of the deployment. It may be some admin server (VM, server, local desktop so on).
Laptop/Desktop Client software
kubectl
commands. The environment should have privileges to create namespace in the
Kubernetes cluster.
helm
install command deploys the software in the Kubernetes cluster.
