This section includes overview information about
Cloud Native Diameter Routing Agent (CNDRA).
The CNDRA (Cloud Native Diameter Routing Agent) is Diameter Routing
solution for the Cloud Native Environment.
The CNDRA supports the following features:
- Initial deployment is
performed using Helm Job.
- MMI support for Diameter
configuration
- Logging support through
CNE infrastructure components, such as EFK.
- Responder connection
support for any message processor PODs (draWorker) in the topology
- Peer’s incoming connection
requests is distributed using MetalLB (Cluster level) and subsequently by
Kube-proxy (Node level) to an mpPod in the topology.
- Initiator connection
distribution support with Pod having least number of initiator connections
available in topology.
