Go to primary content
Oracle® Communications Service Communication Proxy (SCP) Cloud Native Installation Guide
Release 1.0
F12352-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
SCP Deployment
This procedure describes the steps to deploy SCP on CNE. Below steps needs to be executed from a server which is having access to Kubectl and helm commands.
Table 2-6 SCP Deployment
Step # Procedure Description
1
Search helm chart Execute the following command to check the version of the helm chart installation.
helm search <deployment_name>
2
Prepare custom_values.yaml file
Prepare a custom_values.yaml file with the required parameter information. Refer to SCP Configuration Parameters for more information on parameters. Refer to OCSCP Yaml File for sample YAML file. You can also download sample ocscp_values.yaml file from OHC, refer to Table 2-5 for more information.
  • User needs to update the "domain" in custom_values.yaml file per the name of cluster (default value of domain is "svc.cluster.local"). If cluster name is XYZ then domain must be svc.XYZ.
  • User needs to update the "clusterDomain" in custom_values.yaml file per the name of cluster (default value of domain is "cluster.local"). If cluster name is XYZ then domain must be XYZ.
3
Deploy SCP using HELM repository Execute the following command:
helm install <helm-repo> -f <custom_values.yaml> --name <deployment_name> --namespace <namespace_name> --version <helm_version>
Where:
helm-repo: repository name where the helm images, charts are stored
custom_values: helm configuration file which needs to be updated based on the doctor registry
deployment_name and namespace_name: depends on customer configuration
For example:
helm install ocspf-helm-repo/ocscp -f <custom values.yaml> --name ocscp --namespace scpsvc --version <helm version>
4
Deploy SCP using HELM tgz Execute the following command:
helm install -f <custom values.yaml> --name ocscp --namespace <namespace> <chartpath>./<chart>.tgz
5
Check repo status Execute helm status <deployment_name> to check the deployment status.
6
Check svc status Check if all the services are deployed and running:
kubectl -n <namespace_name> get services
7
Check pod status Check if all the pods are up and running:
kubectl -n <namespace_name> get pods
Note: Worker and pilot status must be Running and Ready must be n/n. spfc-soothsayer status must be Running and Ready must be n/n, where n is number of containers in the pod.
