| Oracle® Communications Security Edge Proxy Protection (SEPP) Cloud Native Installation Guide Release 1.1 F17667-01 |
![]() Previous |
![]() Next |
Following sections explain the procedure to uninstall SEPP server and client.
Uninstall SEPP Client
Table 3-4 Uninstall SEPP Client
| Step # | Procedure | Description |
1
Master Node2: Uninstall SEPP client | Execute command to uninstall SEPP client:
helm delete sepp-client --purge |
2
Master Node2: Uninstall Envoy on client |
Execute command to uninstall envoy on client side: helm delete sepp-envoy --purge |
Uninstall SEPP Server
Table 3-5 Uninstall SEPP Server
1
Master Node1: Uninstall SEPP Envoy on server | Execute command to uninstall SEPP envoy on
server side:
2
Master Node1: Uninstall SEPP Server | Execute command to uninstall SEPP server:
helm delete sepp-server --purge |
