Go to primary content
Oracle® Communications Security Edge Proxy Protection (SEPP) Cloud Native Installation Guide
Release 1.1
F17667-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Locate Product Documentation on the Oracle Help Center Site
Oracle Communications customer documentation is available on the web at the Oracle Help Center site, http://docs.oracle.com. You do not have to register to access these documents. Viewing these files requires Adobe Acrobat Reader, which can be downloaded at http://www.adobe.com.
  1. Access the Oracle Help Center site at http://docs.oracle.com.
  2. Click Industries.
  3. Under the Oracle Communications subheading, click Oracle Communications documentation link.
    The Communications Documentation page displays. Most products covered by these documentation sets display under the headings Network Session Delivery and Control Infrastructure and Platforms.
  4. Click on your product and then the release number.
    A list of the documentation set for the selected product and release displays.
  5. To download a file to your location, right-click the PDF link, select Save target as (or similar command based on your browser), and save to a local folder.
