Go to primary content
Oracle® Communications Security Edge Proxy Protection (SEPP) Cloud Native Installation Guide
Release 1.1
F17667-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Limitations
  1. Configurations (All configurations are static and done using helm chart)
    • Remote SEPP IP & Port
    • Remote SEPP Capability
    • Local SEPP Capability
    • All Certificates are self-signed & packaged in Server_envoy and Client_envoy (Change in certificate would need re-build of both envoy)
  2. TLS Handshake:
    • N32 - C Client & Server performs mutual TLS handshake before message exchange
    • N32 - F (Envoy) tested with mutual TLS origination (Without Server hostname verification)
  3. Functionality:
    • N32 - C Server/Client is implemented to handle Capability negotiation between two SEPPs only, other Control plane messages are not supported for now
