An external system can request for debit or credit to an account or GL in FCUBS through the interface.
The following major values will be passed as part of debit request for accounting hand-off:
Values |
Description |
Mandatory |
MODULE |
Module which is sending for accounting handoff |
Yes |
TRN_REF_NO |
Transaction reference number for debit / credit |
No |
EVENT_SR_NO |
Event serial no for Dr / Cr leg |
Yes |
EVENT |
Event against which accounting to be posted |
Yes |
AC_BRANCH |
Branch for accounting handoff |
Yes |
AC_NO |
Account to which Debit / Credit to be done on accounting handoff |
Yes |
AC_CCY |
Currency of the account |
Yes |
DRCR_IND |
Account to be debited / credited on accounting handoff |
Yes |
AMOUNT_TAG |
Amount tag against which accounting to be posted |
Yes |
LCY_AMOUNT |
Local ccy amount for accounting handoff |
Yes |
ECAREFNO |
ECA reference no generated for each request under a ECA create external reference no |
Yes (Mandatory for ECA Debits only) |
FCYAMT |
Fcy amount for accounting handoff, Mandatory, if Account currency is Fcy. |
No |
EXCHRATE |
If Ccy is Fcy, then exchange rate and Lcy amount tags are mandatory. |
No |
BLOCKRELEASESTATUS |
Block release status to be set as F - Full debit; P – For partial debit (Only if partial release is allowed). |
Yes |
TRN_DT |
Transaction date on which accounting to be posted. It’s a non mandatory field, if not provided, accounting would be posted to current system date. |
No |
VALUE_DT |
Value date on which accounting to be posted. It’s a non mandatory field, if not provided, would be defaulted to current system date. |
No |
TXNNARRATIVE |
Transaction narrative captured as part of request will be displayed in account statement. |
No |
The following values will be passed as part of accounting handoff for accounting posting:
Values |
Description |
Default value |
Possible values |
Mandatory |
CHEQUE_MANDATORY |
If debit to happen against an account based on the instrument no, then cheque mandatory to be Y. |
N |
Y / N |
No |
INSTRUMENTCODE |
If cheque mandatory is Yes, then instrument code to be mandatory in the request. Based on that, the chq no would be updated to used in FLEXCUBE system. |
Null |
Valid instrument number |
No |
AVAILBALREQD |
If balance checked to happen as part of ECA debit, this flag to be Y. |
Y |
Y / N |
No |
AVLINFO |
Balance will be updated immediately / move to uncollected balance (for credit transaction alone) based on the value provided. |
I - Immediate |
I - Immediate- V - On value Date |
No |
INTRADAYRELEASE |
If Available info is I and intraday release is Y, then funds will be in Uncollected, to be cleared on intraday batch run. |
N |
Y / N |
No |
ESCROW |
If Escrow is set as Y, then on EAC credit, amount would be blocked, if it’s against a project account. |
N |
Y / N |
No |
CONSFORACCACTIVITY |
To make the account undormant on ECA processing, then consider for account activity to be sent as Y in request. |
Y |
Y / N |
No |
CONSFORTRNOVER |
To restrict the maximum amount to be credited to an account, this flag to be sent as Y in the request. |
N |
Y / N |
No |
SWEEPREQD |
If ECA debit is made more than requested amount and if sweep is Yes, then excess debit will be covered from cover accounts, if available balance isn't sufficient to cover excess debit. |
N |
Y / N |
No |
DEBIT_OVERRIDE_TRACKING |
If account is set for Debit override, if this tag has value B / O, then debit override will be displayed. |
B |
B/O |
No |
CREDIT_OVERRIDE_TRACKING |
If account is set for Credit override, if this tag has value B / O, then credit override will be displayed. |
B |
B/O |
No |
DONTSHOWINSTMT |
If during reversal request of external entries, reversal entries to be excluded from account statement, then DONTSHOWINSTMT should be Y. |
N |
Y/N |
No |
EVENTSRNOTOBEREVD |
If during reversal request of external entries, event slr no to be reversed should be sent in request. |
Null |
Valid event slr no |
Yes (for reversal request) |
TRNCODE |
If transaction code is sent as part of request, it will be stored in the ACTB_ENTRIES_TRNCODE_DETAILS table |
Null |
Transaction Code |
No |
SWIFT_CODE |
If SWIFT_CODE is sent as part of request, then it will be displayed in the SWIFT account statement. |
Null |
Valid SWIFT code |
No |
ACTIONINDICATOR |
Indicates the MIS is for Modification or New |
Null |
‘N’ or ‘M’ |
Yes |
TAG61SUPPINFO |
If the transaction is used for SWIFT message supplementary information will be send in this tag. |
Null |
USERREFNO |
User reference number used for Advice and SWIFT message. |
Null |
ISREVERSAL |
Indicate the transaction from external process is for reversal or not. |
Null |
R or Null |
BANKREFNO |
Bank reference number used for SWIFT message |
Null |
ADDLINFO |
Additional information used for Advice and SWIFT message. |
Null |
Note
Transaction code is not mandatory for external entry hand-off.
The following values will be passed as part of accounting handoff for accounting posting for MIS:
Values |
Description |
Default value |
BRNCD |
Transaction Branch Code |
Null |
CALCMETH1 |
Calculation Method |
Null |
CCY |
Currency |
Null |
COMPMIS1 |
Composite MIS code 1 |
Null |
COMPMIS2 |
Composite MIS code 2 |
Null |
COMPMIS3 |
Composite MIS code 3 |
Null |
COMPMIS4 |
Composite MIS code 4 |
Null |
COMPMIS5 |
Composite MIS code 5 |
Null |
COMPMIS6 |
Composite MIS code 6 |
Null |
COMPMIS7 |
Composite MIS code 7 |
Null |
COMPMIS8 |
Composite MIS code 8 |
Null |
COMPMIS9 |
Composite MIS code 9 |
Null |
COMPMIS10 |
Composite MIS code 10 |
Null |
COSTCD1 |
MIS Cost Code 1 |
Null |
COSTCD2 |
MIS Cost Code 2 |
Null |
COSTCD3 |
MIS Cost Code 3 |
Null |
COSTCD4 |
MIS Cost Code 4 |
Null |
COSTCD5 |
MIS Cost Code 5$ |
Null |
CUSTOMER |
Customer Number |
Null |
FUNDMIS1 |
Fund MIS Code 1 |
Null |
FUNDMIS2 |
Fund MIS Code 2 |
Null |
FUNDMIS3 |
Fund MIS Code 3 |
Null |
FUNDMIS4 |
Fund MIS Code 4 |
Null |
FUNDMIS5 |
Fund MIS Code 5 |
Null |
FUNDMIS6 |
Fund MIS Code 6 |
Null |
FUNDMIS7 |
Fund MIS Code 7 |
Null |
FUNDMIS8 |
Fund MIS Code 8 |
Null |
FUNDMIS9 |
Fund MIS Code 9 |
Null |
FUNDMIS10 |
Fund MIS Code 10 |
Null |
GRPREFNO |
Group reference number to indicate the group of Transaction doe which the MIS is applicable. |
Null |
MISGRP |
MIS group |
Null |
MISGRPCOMP |
Composite MIS group |
Null |
MISGRPFUN |
Fund MIS group |
Null |
MISGRPTXN |
Transaction MIS group |
Null |
MISHEAD |
MIS head |
Null |
POOLCD |
Pool Code |
Null |
PROCESSEDFLAG |
MIS Processed Flag |
Null |
PRODUCT |
Product code |
Null |
RATEFLG |
Rate flag for MIS processing |
Null |
REFRATE |
Ref rate for MIS |
Null |
REFRATECD |
Ref rate code for MIS |
Null |
REFRATETYP |
Ref rate type for MIS |
Null |
REFSPREAD |
Ref spread |
Null |
REFXRATE |
Ref exchange rate |
Null |
RELACC |
Related account number |
Null |
RELETED_REFERENCE |
Related reference number for MIS |
Null |
RGREL |
Null |
TXNMIS1 |
Transaction MIS code 1 |
Null |
TXNMIS2 |
Transaction MIS code 2 |
Null |
TXNMIS3 |
Transaction MIS code 3 |
Null |
TXNMIS4 |
Transaction MIS code 4 |
Null |
TXNMIS5 |
Transaction MIS code 5 |
Null |
TXNMIS6 |
Transaction MIS code 6 |
Null |
TXNMIS7 |
Transaction MIS code 7 |
Null |
TXNMIS8 |
Transaction MIS code 8 |
Null |
TXNMIS9 |
Transaction MIS code 9 |
Null |
TXNMIS10 |
Transaction MIS code 10 |
Null |
UNITREFNO |
Reference number ,either account number or contract ref number base to the MIST type. |
Null |
UNITTYPE |
Unit type ,to indicate Account MIS or contract MIS |
Null |
