This manual talks about the interface between Oracle FLEXCUBE and Oracle FLEXCUBE SWIFTNet Services Integrator Messaging Hub (FC SSI MH) for SWIFTNet connectivity and SWIFTNet Services.
This User Manual is intended for the following User/User Roles:
Role | Function | ||
Back office data entry Clerks | Input functions for maintenance related to the interface | ||
Back office Managers/Officers | Authorization functions |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This manual is organized as follows:
Chapter | Description | ||
Chapter 1 | About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. | ||
Chapter 2 | Oracle FLEXCUBE – FC SSI MH Interface explains on how Oracle FLEXCUBE communicates with the SWIFT Correspondent via FC SSI MH for transfer of files. |
The table lists the abbreviations used in this User Manual:
Abbreviation | Description | ||
FC SSI MH | Oracle FLEXCUBE SWIFTNet Services Integrator Messaging Hub | ||
SC | SWIFT Correspondent |
This User Manual may refer to all or some of the following icons:
Icons | Function | ||
Exit | ||
Add row | ||
Delete row | ||
Option List |
