2. Single Customer View Handoff
The Financial Services Authority (FSA), UK's previous regulator, mandates the Financial Services Compensation Scheme (FSCS) and deposit takers to ensure that eligible depositors will be compensated more quickly if a deposit taker fails.The Deposit Guarantee Schemes Directive (DGSD) enforces deposit guarantee schemes (i.e., FSCS in the UK) to pay out compensation within 20 business days of the default of a deposit taker.
A Single Customer View (SCV) provides FSCS with the information required to make a faster payout, with a payout target of seven days from the default and in any event within the DGSD timeframes. An SCV, is a file that contains the data of customer/depositor and the related accounts/deposits for the FSCS in order to speed up the compensation payout process in case bank fails.
In order to address this regulatory requirement, following parameters are required to be captured:
The following files are generated in a CSV format:
Note
The hand off files are generated from Head Office and local currency of the Head Office is considered.
The file naming convention for the files are as follows:
Where FRN is the Firm Registration Number, YYYYMMDDHHMMSS is the file creation date and time. The data is separated by '|'.
Note
The files are generated on an ad hoc basis and also during end of day based on predefined frequency.
You need to do the following maintenance in Oracle FLEXCUBE to generate the handoff file required for the regulatory authority:
This chapter includes the following sections:
2.1 SCV Bank Parameter Maintenance
2.1.1 Maintaining SCV Bank Parameters
You can maintain the Firm Registration Number, compensation amount and compensation priority based on account class and corporate deposit products at the bank level using the “SCV Bank Parameter” screen. You can invoke the screen by typing ‘STDSCVBP' in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
The following details are captured here:
Bank Code
Specify the bank code here. Alternatively, you can also select the bank code from the adjoining option list. The list contains all the bank codes maintained in the system.
Specify the firm registration number issued for the bank.You can enter a maximum of 35 characters here.
Compensation Amount
Specify the compensation amount in branch local currency to be issued to the customer.
Compensation Priority
Priority
Specify a numeric value between 1 and 99 to set the hierarchy for the account class or corporate deposit product.
Product /Account Class
Specify the corporate deposit product code or account class against the input priority. Alternatively, you can also select the product code or account class from the adjoining option list. The list displays all valid product codes or account classes available in the selected branch.
Product Description
The description of the selected product code/account class is displayed here.
Note
The default priority will be 99 for account classes and deposit products not mapped to the compensation priority in the SCV Bank Parameter Maintenance.
2.2 SCV Customer Parameter Maintenance
2.2.1 Maintaining SCV Customer Parameters
You can maintain the customer level parameters to determine the eligibility of the customer for inclusion or exclusion from the SCV file list for hand off. If no record is maintained for a customer, then system would consider the customer to be in-eligible and would go in the ineligible file.These parameters are maintained in the “SCV Customer Parameter” screen. You can invoke the screen by typing ‘STDSCVCP’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
Customer Number
Specify the customer number for whom the SCV parameters have to be defined. Alternatively, you can also select the customer number from the adjoining option list. The list contains all valid, open, and authorized customer numbers maintained in the system.
Customer Name
The short name of the selected customer is displayed here.
Customer Type
Specify the type of customer here.
SCV Eligible
Select the option to indicate whether the customer is eligible for SCV or not, from the drop-down list. The options available are:
SCV Excluded
Select the option to indicate whether the customer is excluded from the SCV list or not, from the drop-down list. The options available are:
Note
This is enabled only if ‘SCV Eligible’ is selected as ‘Yes’.
SME Flag
Select the option to indicate if the corporate customer is a Small-Medium Enterprise that needs to be reported in the handoff file, from the drop-down list. The options available are:
2.3 SCV Handoff Process
2.3.1 Maintaining Generic Interface Details
The following interfaces are defined in the GIDIFTDF “Interface Definitions” screen for generating the required files:
For more details on Generic Interface refer “Generic Interface” User Manual
Note
2.3.2 File Formats
The formats of the SCV files generated are discussed below:
2.3.2.1 STOSCVCU - SCV Customer Handoff (Depositorandaccountinformation)
This file contains the details of the customer like name, unique id, contact details and also the aggregate balance and compensation amount across account. The data of open, authorized, eligible, and not excluded customers of type individual and corporate would be considered.
File Name:
Name Element
Representation
Comment
FRN
000000
The value should be manu­ally provided in the File Mask field of the interface definition.
Spacer
‘-‘ character
SCV Date and Time
YYYYMMDDHHMMSS
File creation date and time
SCV Type
SCVDepositorandaccountin­formation
Suffix
CSV
Field Specification:
Sr No
Field Name
Data Type
Max Field Length
Mandatory
Flexcube Field Mapping
Derivation Logic
1
SCV Record Number
Char­acter
100
Yes
Concatena­tion of Firm Registration Number and STTM_CUS­TOMER.CUSTOMER_NO
2
Title
Char­acter
20
STTM_CUS­TOMER.CUS­TOMER_PREFIX
3
Cus­tomer First Fore­name
Char­acter
50
STT­M_CUST_PERSONAL.FIRST_NAME
4
Cus­tomer Second Fore­name
Char­acter
50
STT­M_CUST_PERSONAL.MID­DLE_NAME
5
Cus­tomer Third Fore­name
Char­acter
50
Blank
6
Cus­tomer Surname or Com­pany Name
Char­acter
100
Yes
Blank
IF STT­M_CUS­TOMER.CUSTOMER_­TYPE = 'I' THEN
STT­M_CUST_PERSONAL.LAST_NAME
ELSE
STT­M_CUST_CORPO­RATE.COR­PORATE_NAME
END IF
7
Previous Name
Char­acter
200
Blank
8
National Insur­ance Number
Char­acter
9
STTM_CUS­TOMER.UNIQUE_ID_VALUE WHERE UNIQUE_ID_NAME = "NI Number"
9
Passport Number
Char­acter
200
STT­M_CUST_PERSONAL.PASSPORT_NO
10
Other National Identifier
Char­acter
3
Blank
11
Other National Identity Value
Char­acter
50
Blank
12
Com­pany Number
Char­acter
50
STT­M_CUST_CORPO­RATE.C_NA­TIONAL_ID
13
DOB
Date(DDMMYYYY)
8
STT­M_CUST_PERSONAL.DATE_OF_BIRTH
14
SCV Record Number
Char­acter
100
Yes
Same as SCV Record Num­ber populated above
15
Address Line 1
Char­acter
100
Yes
STTM_CUS­TOMER.ADDRESS_LINE1
16
Address Line 2
Char­acter
100
Yes
STTM_CUS­TOMER.ADDRESS_LINE2
17
Address Line 3
Char­acter
100
STTM_CUS­TOMER.ADDRESS_LINE3
18
Address Line 4
Char­acter
100
STTM_CUS­TOMER.ADDRESS_LINE4
19
Address Line 5
Char­acter
100
Blank
20
Address Line 6
Char­acter
100
Blank
21
Post Code
Char­acter
30
STTM_CUS­TOMER.PIN­CODE
22
Country
Char­acter
30
IF STT­M_CUS­TOMER.COUNTRY <> 'GB' THEN
30 charac­ters of STT­M_COUNTRY.DESCRIP­TION for STTM_CUS­TOMER.COUNTRY
ELSE
Blank
23
Email Address
Num­ber
50
STT­M_CUST_PERSONAL.E_MAIL
24
Main Phone Number
Num­ber
40
STT­M_CUST_PERSONAL.TELEPHONE
25
Evening Phone Number
Num­ber
40
26
Mobile Number
Num­ber
30
STT­M_CUST_PERSONAL.MOBILE_NUM­BER
27
Aggre­gate bal­ance across all accounts
Num­ber
15
28
Compen­satable Amount
Num­ber
15
2.3.2.2 STOSCVAC – SCV Account Handoff (Detailsofaccount)
This file contains the details of the accounts like name, type, BIC, sort code and balances. The data of open, authorized, eligible and not excluded customer accounts, individual and corporate, are considered.
File Name:
Name Element
Representation
Comment
FRN
000000
The value should be manually provided in the File Mask field of the interface definition.
Spacer
‘-‘ character
SCV Date and Time
YYYYMMDDHHMMSS
SCV Type
SCVDetailsofaccount
Suffix
CSV
Sr No
Column Name
Data Type
Max Field Length
Mandatory
Derivation Logic
1
SCV Record Number
Character
100
Yes
Concatena­tion of Firm Registration Number and STTM_CUS­TOMER.CUS­TOMER_NO
2
Account Title
Character
50
STT­M_CUST_AC­COUNT.AC_DESC
3
Account Number
Number
35
Yes
STT­M_CUST_AC­COUNT.CUST_AC_NO
4
BIC
Character
11
STT­M_CUS­TOMER.SWIFT_CODE
5
IBAN
Character
34
STT­M_CUST_AC­COUNT.IBAN_AC_NO
6
Sort Code
Number
6
STT­M_BRANCH.CLEARING_­BANK_CODE
7
Product Type
Number
5
Yes
HIERARCHY of the Account Class / CD products
8
Product Name
Character
50
Yes
STT­M_AC­COUNT_CLASS.DESCRIP­TION
9
Account Holder Indicator
Character
3
Yes
STT­M_CUST_AC­COUNT.JOINT_AC_INDI­CATOR
If JOINT_AC_INDICATOR =’S’
Then
JOINT_AC_INDICATOR=’1’
If JOINT_AC_INDICATOR =’J’
Then
JOINT_AC_INDICA­TOR=Num­ber of Joint Account Hold­ers including primary cus­tomer
10
Account Status Code
Character
50
Yes
STT­M_CUST_AC­COUNT.RECORD_STAT
11
Exclu­sion Type
Character
6
Yes
SCV Exclu­sion type
12
Recent Transac­tion
Character
3
Yes
credits or deb­its that have occurred in the account for the last 24 months from the genera­tion date of the SCV files. All credits and debits entries posted to the account will be consid­ered as an activity in the account. The field will be marked ‘Yes’ in case there is an activity else the field will be marked ‘No’. If Credit Interest Liqui­dation not to be consid­ered for the reporting then the transac­tion code used for credit inter­est liquidation should have the parameter Consider for Activity set as No
13
Account Branch Jurisdic­tion
Character
3
UK
14
BRRD Marking
Character
3
Yes
This field will be populated with ‘Yes’ for all Individual customers. For corporate customers, the SME is Yes in SCV Customer parameter is Yes, then the field will be populated with ‘Yes’. If the SME Flag is No, the field will be popu­lated with ‘No’.
15
Struc­tured Deposit Accounts
Character
3
Yes
'No'
16
Account Balance Sterling
Number
15 (16 if negative balance)
Yes
17
Author­ized Nega­tive Bal­ance
Number
Yes
If an Over­draft limit is attached to an account, the approved amount will be displayed in this field. If no Overdraft is attached but a Sublimit is attached to the account, then the approved amount of the respective Sublimit will be displayed in the field. If both Over­draft limit and Sublimit are attached to an account, then Main Limit amount will be taken. If both Overdraft limit and Sublimit are not attached to an account, the field will be left blank. If more than one main limit is attached, sys­tem will con­sider the sum of all the attached over­draft limit amount.
18
Cur­rency of Account
Character
3
Yes
STT­M_CUST_AC­COUNT.CCY
19
Account Balance in origi­nal Cur­rency
Number
Yes
20
Exchange Rate
Number
29
Yes
The standard mid-rate appli­cable for the account cur­rency and local currency pair will be applied for arriving at the value for account bal­ance in local currency. The exchange rate applied to arrive at the converted bal­ance will be displayed in this field.
21
Original Account Balance before Interest
Number
Yes
22
Trans­ferable Eligible Deposit
Number
15
Yes
2.3.2.3 STOEXCCU - Excluded Customer Handoff (Depositorandaccountinformation)
This file would contain the details of the customer like name, unique id, contact details and also the aggregate balance and compensation amount across account, similar to the SCV file except that customer list is excluded. The SCV eligible parameter should be set to Yes for such excluded customers. Criteria: All open, authorized and SCV Excluded field are set to the value between 1 and 4 for the customer records.
File Name:
Name Element
Representation
Comment
FRN
000000
Spacer
‘-‘ character
SCV Date and Time
YYYYMMDDHHMMSS
SCV Type
EXCDepositorandac­countinformation
Suffix
CSV
Sr No
Field Name
Data Type
Max Field Length
Mandatory
Derivation Logic
1
SCV Record Number
Charac­ter
100
Yes
2
Title
Charac­ter
20
STT­M_CUS­TOMER.CUSTOMER_PREFIX
3
Customer First Fore­name
Charac­ter
50
4
Customer Second Forename
Charac­ter
50
5
Customer Third Fore­name
Charac­ter
50
Blank
6
Customer Surname or Company Name
Charac­ter
100
Yes
Blank
ELSE
END IF
7
Previous Name
Charac­ter
200
Blank
8
National Insurance Number
Charac­ter
9
9
Passport Number
Charac­ter
200
STT­M_CUST_PERSONAL.PASS­PORT_NO
10
Charac­ter
3
Blank
11
Charac­ter
50
Blank
12
Company Number
Charac­ter
50
STT­M_CUST_CORPO­RATE.C_NATIONAL_ID
13
DOB
Date(DDMMYYYY)
8
14
SCV Record Number
Charac­ter
100
Yes
Same as SCV Record Number populated above
15
Address Line 1
Charac­ter
100
Yes
STT­M_CUS­TOMER.ADDRESS_LINE1
16
Address Line 2
Charac­ter
100
Yes
STT­M_CUS­TOMER.ADDRESS_LINE2
17
Address Line 3
Charac­ter
100
STT­M_CUS­TOMER.ADDRESS_LINE3
18
Address Line 4
Charac­ter
100
STT­M_CUS­TOMER.ADDRESS_LINE4
19
Address Line 5
Charac­ter
100
Blank
20
Address Line 6
Charac­ter
100
Blank
21
Post Code
Charac­ter
30
STT­M_CUS­TOMER.PINCODE
22
Country
Charac­ter
30
ELSE
Blank
23
Email Address
Number
50
24
Main Phone Number
Number
40
STT­M_CUST_PERSONAL.TELE­PHONE
25
Evening Phone Num­ber
Number
40
26
Mobile Num­ber
Number
30
STT­M_CUST_PERSONAL.MOBILE_­NUMBER
27
Aggregate balance across all accounts
Number
15
28
Compensata­ble Amount
Number
15
2.3.2.4 STOEXCAC – Excluded Customer Account Handoff (Detailsofaccount)
This file contains the details of the accounts like name, type, BIC, sort code and balances, but for the accounts where the customer is excluded from SCV.
Criteria: All open accounts, authorized accounts and SCV Excluded field are set to the value between 1 and 4 for the customer of the account.
File Name:
Name Element
Representation
Comment
FRN
000000
Spacer
‘-‘ character
SCV Date and Time
YYYYMMDDHHMMSS
SCV Type
EXCDetailsofaccount
Suffix
CSV
Sr No
Column Name
Data Type
Max Field Length
Mandatory
Derivation Logic
1
SCV Record Number
Char­acter
100
Yes
Concatena­tion of Firm Registration Number and STT­M_CUS­TOMER.CUSTOMER_NO
2
Account Title
Char­acter
50
STT­M_CUST_ACCOUNT.AC_­DESC
3
Account Number
Num­ber
35
Yes
STT­M_CUST_ACCOUNT.CUST_AC_NO
4
BIC
Char­acter
11
STTM_CUS­TOMER.SWIFT_CODE
5
IBAN
Char­acter
34
STT­M_CUST_ACCOUNT.IBAN_AC_NO
6
Sort Code
Num­ber
6
7
Product Type
Num­ber
5
Yes
HIERAR­CHY of the Account Class / CD products
8
Product Name
Char­acter
50
Yes
STTM_AC­COUNT_­CLASS.DESCRIPTION
9
Char­acter
3
Yes
STT­M_CUST_ACCOUNT.JOINT_AC_INDICATOR
If JOINT_AC_INDICA­TOR =’S’
Then
JOINT_AC_INDICA­TOR=’1’
If JOINT_AC_INDICA­TOR =’J’
Then
JOINT_AC_INDICA­TOR=Num­ber of Joint Account Holders including primary cus­tomer
10
Account Status Code
Char­acter
50
Yes
STT­M_CUST_ACCOUNT.RECORD_STAT
11
Exclusion Type
Char­acter
6
Yes
SCV Exclu­sion Type
12
Recent Transac­tion
Char­acter
3
Yes
credits or debits that have occurred in the account for the last 24 months from the generation date of the SCV files. All credits and debits entries posted to the account will be con­sidered as an activity in the account. The field will be marked ‘Yes’ in case there is an activity else the field will be marked ‘No’. If Credit Inter­est Liquida­tion not to be consid­ered for the reporting then the transaction code used for credit interest liq­uidation should have the parame­ter Con­sider for Activity set as No.
13
Account Branch Jurisdiction
Char­acter
3
UK
14
BRRD Marking
Char­acter
3
Yes
This field will be popu­lated with ‘Yes’ for all Individual customers. For corpo­rate custom­ers, the SME is Yes in SCV Cus­tomer parameter is Yes, then the field will be popu­lated with ‘Yes’. If the SME Flag is No, the field will be popu­lated with ‘No’.
15
Structured Deposit Accounts
Char­acter
3
Yes
'No'
16
Num­ber
15 (16 if neg­ative bal­ance)
Yes
17
Author­ized Nega­tive Balance
Num­ber
Yes
If an Over­draft limit is attached to an account, the approved amount will be displayed in this field. If no Over­draft is attached but a Sublimit is attached to the account, then the approved amount of the respec­tive Sublimit will be dis­played in the field. If both Overdraft limit and Sublimit are attached to an account, then Main Limit amount will be taken. If both Over­draft limit and Sub­limit are not attached to an account, the field will be left blank. If more than one main limit is attached, system will consider the sum of all the attached overdraft limit amount.
18
Currency of Account
Char­acter
3
Yes
STT­M_CUST_ACCOUNT.CCY
19
Account Balance in original Currency
Num­ber
Yes
20
Exchange Rate
Num­ber
29
Yes
The stand­ard mid-rate applicable for the account cur­rency and local cur­rency pair will be applied for arriving at the value for account bal­ance in local currency. The exchange rate applied to arrive at the con­verted bal­ance will be displayed in this field.
21
Num­ber
Yes
22
Transfera­ble Eligi­ble Deposit
Num­ber
15
Yes
2.3.2.5 STONELCU – Ineligible Customer Handoff (Depositorandaccountinformation)
This file contains the details of the customer like name, unique id, contact details and also the aggregate balance and compensation amount across account same as in SCV except that the customers are marked for ineligibility.
Criteria: All open, authorized and SCV Eligible field are set to No for the customer.
File Name:
Name Element
Representation
Comment
FRN
000000
Spacer
‘-‘ character
SCV Date and Time
YYYYMMDDHHMM
SCV Type
INELIGDepositorandac­countinformation
Suffix
CSV
Sr No
Field Name
Data Type
Max Field Length
Mandatory
Derivation Logic
1
SCV Record Number
Character
100
Yes
Concatena­tion of Firm Registra­tion Num­ber and STT­M_CUS­TOMER.CUSTOMER_NO
2
Title
Character
20
STT­M_CUS­TOMER.CUSTOM­ER_PRE­FIX
3
Character
50
STT­M_CUST_PER­SONAL.FIRST_NAME
4
Customer Second Fore­name
Character
50
STT­M_CUST_PER­SONAL.MIDDLE_NAME
5
Character
50
Blank
6
Character
100
Yes
Blank
ELSE
STT­M_CUST_CORPO­RATE.CORPORATE_NAME
END IF
7
Previous Name
Character
200
Blank
8
Character
9
STT­M_CUS­TOMER.UNIQUE_ID_VALUE WHERE UNIQUE_ID_NAME = "NI Num­ber"
9
Passport Number
Character
200
STT­M_CUST_PER­SONAL.PASS­PORT_NO
10
Other National Iden­tifier
Character
3
Blank
11
Other National Iden­tity Value
Character
50
Blank
12
Company Number
Character
50
STT­M_CUST_CORPO­RATE.C_NATION­AL_ID
13
DOB
Date(DDMMYYYY)
8
STT­M_CUST_PER­SONAL.DATE_OF_BIRTH
14
SCV Record Number
Character
100
Yes
15
Address Line 1
Character
100
Yes
16
Address Line 2
Character
100
Yes
17
Address Line 3
Character
100
18
Address Line 4
Character
100
19
Address Line 5
Character
100
Blank
20
Address Line 6
Character
100
Blank
21
Post Code
Character
30
22
Country
Character
30
30 charac­ters of STT­M_COUNTRY.DESCRIPTION for STT­M_CUS­TOMER.COUNTRY
ELSE
Blank
23
Email Address
Number
50
STT­M_CUST_PER­SONAL.E_MAIL
24
Main Phone Number
Number
40
STT­M_CUST_PER­SONAL.TELE­PHONE
25
Number
40
26
Mobile Num­ber
Number
30
STT­M_CUST_PER­SONAL.MOBILE_­NUMBER
27
Number
15
28
Number
15
2.3.2.6 STONELAC – Ineligible Customer Account Handoff (Detailsofaccount)
This file would contain the details of the accounts like name, type, BIC, sort code and balances, but for the accounts where SCV Eligible is set to NO for the customer.
Criteria: All open accounts, authorized accounts and SCV Eligible is set to the value No for the customer of the account.
File Name:
Name Element
Representation
Comment
FRN
000000
Spacer
‘-‘ character
SCV Date and Time
YYYYMMDDHHMM
SCV Type
INELIGDetailsofaccount
Suffix
CSV
Sr No
Column Name
Data Type
Max Field Length
Mandatory
Derivation Logic
1
SCV Record Number
Charac­ter
100
Yes
2
Account Title
Charac­ter
50
3
Account Num­ber
Number
35
Yes
4
BIC
Charac­ter
11
5
IBAN
Charac­ter
34
6
Sort Code
Number
6
7
Product Type
Number
5
Yes
8
Product Name
Charac­ter
50
Yes
9
Account Holder Indica­tor
Charac­ter
3
Yes
STT­M_CUST_AC­COUNT.JOINT_AC_INDICA­TOR
Then
Then
JOINT_AC_INDICA­TOR=Number of Joint Account Hold­ers including primary cus­tomer
10
Account Sta­tus Code
Charac­ter
50
Yes
11
Exclusion Type
Charac­ter
6
Yes
SCV Exclusion Type
12
Recent Trans­action
Charac­ter
3
Yes
credits or deb­its that have occurred in the account for the last 24 months from the gen­eration date of the SCV files. All credits and debits entries posted to the account will be considered as an activity in the account. The field will be marked ‘Yes’ in case there is an activity else the field will be marked ‘No’. If Credit Interest Liquidation not to be consid­ered for the reporting then the transac­tion code used for credit inter­est liquidation should have the parameter Consider for Activity set as No.
13
Account Branch Juris­diction
Charac­ter
3
UK
14
BRRD Mark­ing
Charac­ter
3
Yes
This field will be populated with ‘Yes’ for all Individual customers. For corporate customers, the SME is Yes in SCV Cus­tomer parame­ter is Yes, then the field will be populated with ‘Yes’. If the SME Flag is No, the field will be popu­lated with ‘No’.
15
Charac­ter
3
Yes
'No'
16
Account Bal­ance Sterling
Number
Yes
17
Authorized Negative Bal­ance
Number
Yes
If an Overdraft limit is attached to an account, the approved amount will be displayed in this field. If no Overdraft is attached but a Sublimit is attached to the account, then the approved amount of the respective Sublimit will be displayed in the field. If both Overdraft limit and Sub­limit are attached to an account, then Main Limit amount will be taken. If both Overdraft limit and Sublimit are not attached to an account, the field will be left blank. If more than one main limit is attached, sys­tem will con­sider the sum of all the attached over­draft limit amount.
18
Currency of Account
Charac­ter
3
Yes
19
Account Bal­ance in origi­nal Currency
Number
Yes
20
Exchange Rate
Number
29
Yes
21
Original Account Bal­ance before Interest
Number
Yes
22
Transferable Eligible Deposit
Number
15
Yes
2.3.2.7 File Footer
Footer
Trailer record
Twenty digits of character ‘9’ e.g. 99999999999999999999
2.3.2.8 Aggregate Balance across all accounts
The value of this field is arrived by summing up all the positive account balances of a customer inclusive of any accrued debit/credit interest. However, the accounts with negative balances will not be considered for arriving at the balances for this field. For a customer having Joint Accounts (2 or more Holders), the balance is split equally between the holders.
For Example 1: Single Account Holder. Generation date is on 10th August 2016. The data as on this date would be as follows:
Customer No
Account/CD Ref No
Currency
Balance
Accrued Interest
Value of Aggregate Balance
A00001
A00001001
GBP
50,000.00
500.25
(50,000.00+500.25) +
(25,000.00+350.47)1 GBP equiva­lent
(20,000.00+57.12)
= 50,500.25+19,519.86+20,057.12
= 90,077.232 GBP
A00001
A00001002
USD
25,000.00
350.47
A00001
A00001003
GBP
-13,500.00
-23.33
A00001
000CD0112345789
GBP
20,000.00
57.12
For Example 2: Joint Account Holder. Generation date is on 10th August 2016. The data as on this date would be as follows:
Customer No
Account/CD Ref No
HIERARCHY
Currency
Balance
Accrued Interest
A00001
A00001001
1
GBP
50,000.00
500.25
(25,000.00+350.47)1 GBP equivalent
(20,000.00+57.12)
= 90,077.232 GBP
90,077.23 + 22,517 = 1,12,594.234 GBP
A00001
A00001002
2
USD
25,000.00
350.47
A00001
A00001003
2
GBP
-13,500.00
-23.33
A00001
000CD0112345789
GBP
20,000.00
57.12
A00002
A00002001
2
GBP
45,000.00
34.00
22,5173 GBP
A00001
2.3.2.9 Compensatable Amount
This indicates the covered funds for a customer. If it is fully covered it will be equal to compensation amount defined for the bank. But it can be lesser to the extent of the various account balances contributing towards this customer. The accounts with negative balances are not considered for this field.
If aggregate balance is greater than the compensation amount then the value would be the compensation amount for the customer else it would be the aggregate balance.
For Example 1: Single Account Holder. Generation date is on 10th August 2016. The compensation amount for customer is maintained to be 75,000.00 GBP. The data as on this date would be as follows:
Customer No
Account/CD Ref No
Currency
Balance
Accrued Interest
A00001
A00001001
GBP
50,000.00
500.25
(20,000.00+57.12)
= 90,077.232 GBP
90,077.23GBP is greater than the compensation amount 75,000.00 GBP. Hence the value for this cus­tomer would be 75,000.00 GBP.
A00001
A00001002
USD
25,000.00
350.47
A00001
A00001003
GBP
-13,500.00
-23.33
A00001
000CD0112345789
GBP
20,000.00
57.12
For Example 2: Joint Account Holder. Generation date is on 10th August 2016. The compensation amount for customer is also 75,000.00 GBP. The data as on this date would be as follows:
Customer No
Account/CD Ref No
HIERARCHY
Currency
Balance
Accrued Interest
A00001
A00001001
1
GBP
50,000.00
500.25
(25,000.00+350.47)1 GBP equiv­alent
(20,000.00+57.12)
= 90,077.232 GBP
75,000.00 GBP
A00001
A00001002
2
USD
25,000.00
350.47
A00001
A00001003
2
GBP
-13,500.00
-23.33
A00001
000CD0112345789
GBP
20,000.00
57.12
A00002
A00002001
2
GBP
45,000.00
34.00
22,5173 GBP
22,517.00 GBP
A00001
2.3.2.10 Account Balance in Local Currency (Account Balance in Sterling field)
This is the balance in the account inclusive of the debit/credit interest accrued. It would also consider the negative balance.
For Example 1: Single Account Holder. Generation date is on 10th August 2016. The compensation amount for single is maintained to be 75,000.00 GBP. The data as on this date would be as follows:
Customer No
Account/CD Ref No
Currency
Balance
Accrued Interest
A00001
A00001001
GBP
50,000.00
500.25
(20,000.00+57.12)
= 90,077.232 GBP
A00001
A00001002
USD
25,000.00
350.47
A00001
A00001003
GBP
-13,500.00
-23.33
A00001
000CD0112345789
GBP
20,000.00
57.12
Account File
Account/CD Ref No
Currency
HIERARCHY
Acc Bal in Local Currency (Ex: GBP)
A00001001
GBP
1
50500.25
A00001002
USD
2
19519.86
A00001003
GBP
2
-13523.33
000CD0112345789
GBP
20057.12
For Example 2: Joint Account Holder. Generation date is on 10th August 2016. The compensation amount for joint is also 75,000.00 GBP. The data as on this date would be as follows::
Customer No
Account/CD Ref No
HIERARCHY
Currency
Balance
Accrued Interest
A00001
A00001001
1
GBP
50,000.00
500.25
(20,000.00+57.12)
= 90,077.232 GBP
75,000.00 GBP
A00001
A00001002
2
USD
25,000.00
350.47
A00001
A00001003
2
GBP
-13,500.00
-23.33
A00001
000CD0112345789
GBP
20,000.00
57.12
A00002
A00002001
2
GBP
45,000.00
34.00
22,5173 GBP
22,517.00 GBP
A00001
Account File:
SCV Id
Account/CD Ref No
Currency
HIERARCHY
11111A00001
A00001001
GBP
1
50500.25
11111A00001
A00001002
USD
2
19519.86
11111A00001
A00001003
GBP
2
-13523.33
11111A00001
A00002001
GBP
2
22,517.00
11111A00001
000CD0112345789
GBP
20057.12
11111A00002
A00002001
GBP
2
22,517.00
2.3.2.11 Account Balance in original currency
The balance in the account currency along with accrued debit/credit interest (in account currency) is populated in this field. If there is a negative balance for an account, the ‘–‘symbol is prefixed to the balance displayed in this field.
Customer No
Account/CD Ref No
Currency
Balance
Accrued Interest
A00001
A00001001
GBP
50,000.00
500.25
(20,000.00+57.12)
= 90,077.232 GBP
90,077.23GBP is greater than the compensation amount 75,000.00 GBP. Hence the value for this customer would be 75,000.00 GBP.
A00001
A00001002
USD
25,000.00
350.47
A00001
A00001003
GBP
-13,500.00
-23.33
A00001
000CD0112345789
GBP
20,000.00
57.12
Account File:
Account/CD Ref No
Currency
HIERARCHY
Acc Bal in Acc Currency
A00001001
GBP
1
50500.25
50500.25
A00001002
USD
2
19519.86
25350.47
A00001003
GBP
2
-13523.33
-13523.33
000CD0112345789
GBP
20057.12
20057.12
Customer No
Account/CD Ref No
HIERARCHY
Currency
Balance
Accrued Interest
A00001
A00001001
1
GBP
50,000.00
500.25
(20,000.00+57.12)
= 90,077.232 GBP
75,000.00 GBP
A00001
A00001002
2
USD
25,000.00
350.47
A00001
A00001003
2
GBP
-13,500.00
-23.33
A00001
000CD0112345789
GBP
20,000.00
57.12
A00002
A00002001
2
GBP
45,000.00
34.00
22,5173 GBP
22,517.00 GBP
A00001
Account File:
SCV Id
Account/CD Ref No
Currency
HIERARCHY
Acc Bal in Local Currency(Ex: GBP)
11111A00001
A00001001
GBP
1
50500.25
50500.25
11111A00001
A00001002
USD
2
19519.86
19519.86
11111A00001
A00001003
GBP
2
-13523.33
-13523.33
11111A00001
A00002001
GBP
2
22,517.00
22517.00
11111A00001
000CD0112345789
GBP
20057.12
20057.12
11111A00002
A00002001
GBP
2
22,517.00
22517.00
2.3.2.12 Original Account Balance before interest
The account balance in account currency without considering the accrued debit/credit interest will be displayed in this field. If there is a negative balance for an account, the ‘–‘symbol is prefixed to the balance displayed in this field.
Customer No
Account/CD Ref No
Currency
Balance
Accrued Interest
A00001
A00001001
GBP
50,000.00
500.25
(20,000.00+57.12)
= 90,077.232 GBP
A00001
A00001002
USD
25,000.00
350.47
A00001
A00001003
GBP
-13,500.00
-23.33
A00001
000CD0112345789
GBP
20,000.00
57.12
Account File:
Account/CD Ref No
Currency
HIERARCHY
Bal before interest in Acc Currency
A00001001
GBP
1
50500.25
50500.25
50000
A00001002
USD
2
19519.86
25350.47
25000
A00001003
GBP
2
-13523.33
-13523.33
-13500
000CD0112345789
GBP
20057.12
20057.12
20000
Customer No
Account/CD Ref No
HIERARCHY
Currency
Balance
Accrued Interest
A00001
A00001001
1
GBP
50,000.00
500.25
(20,000.00+57.12)
= 90,077.232 GBP
75,000.00 GBP
A00001
A00001002
2
USD
25,000.00
350.47
A00001
A00001003
2
GBP
-13,500.00
-23.33
A00001
000CD0112345789
GBP
20,000.00
57.12
A00002
A00002001
2
GBP
45,000.00
34.00
22,5173 GBP
22,517.00 GBP
A00001
Account File:
SCV Id
Account/CD Ref No
Currency
HIERARCHY
11111A00001
A00001001
GBP
1
50500.25
50500.25
50000
11111A00001
A00001002
USD
2
19519.86
25350.47
25000
11111A00001
A00001003
GBP
2
-13523.33
-13523.33
-13500
11111A00001
A00002001
GBP
2
22,517.00
22517.00
22500
11111A00001
000CD0112345789
GBP
20057.12
20057.12
20000
11111A00002
A00002001
GBP
2
22,517.00
22517.00
22500
2.3.2.13 Transferrable Eligible Deposit
The contribution towards the covered funds (Compensatable amount) by the various accounts of a customer will be governed by prioritization rules (HIERARCHY and pari paasu-Equal footing) and would be populated in this field.
The accounts with negative balance, considering available balance + uncollected funds +/- interest, will not be considered towards contribution for this field.
The contribution by the various accounts of a customer will be governed by the Hierarchy level of the customer account . Contribution should be first made from an account higher up in hierarchy than one at a lower level I.e. IAA accounts should make up the compensation amount first and if there is not enough in this account then it should move onto the next account in the hierarchy and so on.
If there are two accounts within the same hierarchy then the excess amount should be taken equally from each (pari paasu-Equal footing).
The transferrable eligible balance would be arrived from the balances of each individual accounts/deposits by taking off the excess amounts from the balances of accounts/deposits based on hierarchy and by using the Bottom-Up approach. That is, the excess amount would first be taken out from the account/deposit in the lowest hierarchy moving upward.
Customer No
Account/CD Ref No
Currency
Balance
Accrued Interest
A00001
A00001001
GBP
50,000.00
500.25
(20,000.00+57.12)
= 90,077.232 GBP
Excess Amount is 15077.23 GBP
This excess amount is divided by 2 as there are 2 accounts in hierar­chy 2 with the posi­tive balance. So the equal amount to be taken out from the each account is 7538.615
A00001
A00001002
USD
25,000.00
350.47
A00001
A00001003
GBP
-13,500.00
-23.33
A00001
000CD0112345789
GBP
20,000.00
57.12
Account File:
Account/CD Ref No
Currency
HIERARCHY
Transferrable Eligible Amount
A00001001
GBP
1
50500.25
50500.25
50000
50500.25
A00001002
USD
2
19519.86
25350.47
25000
19519.86-7538.62 = 11981.2
A00001003
GBP
2
-13523.33
-13523.33
-13500
000CD0112345789
GBP
2
20057.12
20057.12
20000
20057.12 – 7538.62 = 12518.5
Customer No
Account/CD Ref No
HIERARCHY
Currency
Balance
Accrued Interest
A00001
A00001001
1
GBP
50,000.00
500.25
(20,000.00+57.12)
= 90,077.232 GBP
75,000.00 GBP
Excess Amount is 37594.23 GBP.
The equal amount to be taken out from each account under same hier­archy 2 is, 12531.41 GBP
A00001
A00001002
2
USD
25,000.00
350.47
A00001
A00001003
2
GBP
-13,500.00
-23.33
A00001
000CD0112345789
GBP
20,000.00
57.12
A00002
A00002001
2
GBP
45,000.00
34.00
22,5173 GBP
22,517.00 GBP
A00001
Account File:
SCV Id
Account/CD Ref No
Currency
HIERARCHY
11111A00001
A00001001
GBP
1
50500.25
50500.25
50000
50500.25
11111A00001
A00001002
USD
2
19519.86
25350.47
25000
19519.86 – 12531.41 = 6988.45
11111A00001
A00001003
GBP
2
-13523.33
-13523.33
-13500
11111A00001
A00002001
GBP
2
22,517.00
22517.00
22500
22517 – 12531.41 = 9985.59
11111A00001
000CD0112345789
GBP
2
20057.12
20057.12
20000
20057.12-12531.41 = 7525.71
11111A00002
A00002001
GBP
2
22,517.00
22517.00
22500
22517.00
