Oracle FLEXCUBE interfaces with the Tax Payment System for exchange of the tax payment details of customers. This interface also helps you view the reports related to customers’ tax payments.
This section contains the following topic:
The following are maintained for Tax Payment interface, internally:
For further details on maintaining external system and interface, refer to the Oracle FLEXCUBE Generic Interface user manual.
For tax payment interface, you need to maintain the interface parameterization details. To invoke the ‘Interface Parameterization’ screen, type ‘IFDPARAM’ in the field at the top right corner of the Application toolbar and click the adjoining arrow button.
Specify the following details:
Interface Code
Select the interface code from the adjoining option list. This list displays all interface codes maintained in the system.
Parameter Name
Specify a unique parameter name for the interface upload.
Parameter Value
Specify the default values assigned for every unique parameter name and interface code.
Account Description
Specify the description of the selected parameter is here.
Oracle FLEXCUBE picks up the file containing the tax payment details of customers from the intermediate data store. This file contains the following information:
The system further debits the tax amount from the customer account and credits the 'SIMPATI' GL.
The system will not process if the records are empty or does not contain mandatory fields.
Before passing the accounting entries, the system checks whether sufficient balance is available in the account. In case of insufficient balance, the transaction is rejected.
The file format is given below:
Attribute Name  |
Attribute Value  |
Interface Type  |
Incoming  |
From System  |
EXTSTPS  |
To System  |
FLEXCUBE  |
Directory Location  |
To be Confirmed  |
File Name  |
TxPmt$Y$M$D$H$M$S.txt  |
Frequency  |
Daily  |
Character Set  |
ASCII  |
File Header  |
No  |
File Footer  |
No  |
Delimiter  |
Record Length  |
Variable  |
Format  |
Line Sequential, Variable Length Records  |
End of the Record  |
CR/LF  |
Numeric padding  |
No  |
Text padding  |
No  |
You can generate and view customer tax payment reports using ‘Customer Tax Payment’ screen. To invoke the screen, type ‘IFRTXPM’ in the field at the top right corner of the Application toolbar and click the adjoining arrow button.
To generate the report, you need to specify the following details:
Branch Code
The system displays the branch code.
Account Number
Specify the account number for which you need to generate the tax payment report.
Assessment Year
Specify the assessment year. The tax payment report will contain the details of payment of tax during the assessment year specified here.
From Date
You need to indicate period. Specify the start date of the tax payment report period here. The system will generate the report for the period from this date.
To Date
You need to indicate period. Specify the end date of the tax payment report period here. The system will generate the report for the period from the start date until this date.
Once you have captured the details, click ‘Ok’ button. The system generates and displays the tax payment report for the selected account and period.
The tax payment report contains the following details:
