Banks extend various credit facilities like limits to its customers depending on their requirements. Based on the bank’s business model and their target customers they have one of the following scenarios:
This section contains the following topic:
This document talks about two types of FCUBS installation modes. They are:
Details |
Standalone |
Componentized |
SYNC (1) |
ASYNC (2) |
SYNC (3) |
ASYNC (4) |
Data Storage |
Different DB |
Different DB |
Same DB |
Same DB |
Deployment |
Different App. |
Different App. |
Same App. |
Same App. |
Mode Interface |
Web Services |
Web Services |
Web Services |
Web Services |
Limit Response Handling |
Online |
Deferred |
Online |
Deferred |
Set up Oracle FLEXCUBE Universal Banking Application. ELCM user will have read-only access to this application. The access is provided only to particular extraction tables.
Refer the ‘Oracle FLEXCUBE Universal Banking Installation’ manual.
The following installation modes are described in the upcoming sections:
If the mode of limits installation is selected as ASYNC (Standalone/Componentized), the limits requests will be logged with Limits Pending Status in FCUBS Limits Queue. These pending limits requests are picked by a job to form the webservices XML requests. The status of the limit request will be updated in FCUBS based on the external limits response. The status can be Approved, Rejected or Timed-out. FCUBS will authorize the transactions that are in Approved status.
You can query and perform manual actions on external limit requests using Limit Processing Queue screen. This screen supports user action only on timed out requests. You can invoke this screen by typing ‘SQSEXLMT’ in the top right corner of the Application toolbar and clicking the adjoining arrow button.
You can view records based on any or all of the following criteria:
Select any or all of the parameters for a query and click ‘Search’ button. The records meeting the selected criteria are displayed.
External Limit Queue supports user actions only on a timed out request. A limit request is moved to ‘Timed-out’ status based on the time out parameter maintained. If response is not received from the external system within the given time, the status is marked as timed out. The following actions are allowed on a timed out requests:
If the mode of limits installation is selected as SYNC (Standalone/Componentized):
The following sections describes the integration maintenance and processing in detail.
You can maintain external services using ‘External Service Maintenance’ screen. You can invoke this screen by typing ‘IFDEXSER’ in the top right corner of the Application toolbar and clicking the adjoining arrow button.
You can maintain the following in this screen:
External System
Specify the external system, Alternatively, you can select the external system from the option list. The list displays all valid values maintained in the system.
Description
The system displays the description based on the external system selected.
External User
Specify the external user.
Type
Select the type from the drop-down list.
Service Name
Specify the service name. Alternatively, you can select the service name from the option list. The list displays all valid service name maintained in the system.
WS Endpoint URL
Provide WS endpoint URL.
Rest Service Context
The system displays the rest service context.
Rest Service IP
The system displays the rest service IP.
Rest Service Pattern
The system displays the rest service pattern.
You can select the required external limit setup mode and communication mode during installation.
The following parameters can be used for limit setup mode:
The following parameters can be used for external limit interface mode:
This is applicable for Standalone UBS - Limits setup/ Componentized Limits setup.
If FCUBS is installed with no external limits:
If FCUBS is installed with external limits, then:
