This manual is designed to assist you in getting acquainted with the Oracle FLEXCUBE Machine Learning framework.
It has detailed stepwise instructions to help you build Oracle FLEXCUBE Machine Learning models and process their execution.
The manual also outlines how to access and interpret the model outcomes for augmented decision making.
This manual is intended for the following User/User Roles:
Role |
Function |
Branch Managers |
Overall Branch Perspective |
Account Managers/ |
Customer Relationship Management |
Head Office Managers |
Overall Bank Perspective |
FLEXCUBE Admin / |
Application Administration and Support |
This manual is organized into the following chapters:
Chapter Number |
Title |
Description |
Chapter 1 |
Preface |
Information about this manual. It covers intended audiences and lists chapter information |
Chapter 2 |
Machine Learning - |
It introduces the Machine
Learning context and specifically the Oracle |
Chapter 3 |
Model Building Routine |
This chapter contains instructions on how to build Machine Learning Models using historical Oracle FLEXCUBE data |
Chapter 4 |
Model Execution Routine |
This chapter explains how to apply Machine Learning Models on Oracle FLEXCUBE data |
Chapter 5 |
Enterprise Dashboard |
This section helps you
interpret |
Chapter 6 |
Branch Dashboard |
This screen helps you interpret
Chapter 7 |
Customer Query Board |
This allows you to query customers across the bank based on attrition Risk profile, branch code and/or segment |
This User Manual may refer to all or some of the following icons:
Icons |
Function |
Exit |
Add row |
Delete row |
Option List |
