2. Machine Learning - An Overview
2.1 Introduction
Machine Learning is heavily dependent on historical data to build models and use the models to predict outcomes for better decision making
The following points encompasses contextual information to help you get familiarized with the subject.
This chapter contains the following section:
2.2 Machine Learning in Oracle FLEXCUBE
The machine learning framework is embedded within Oracle FLEXCUBE. It is built using Oracle R Enterprise, which is separately licensed.
The business cases are limited to retail customers.
2.3 Pre-requisites
The following Pre-requisites are mandatory for the Machine Learning Framework.
Environmental
Note
ORE database MUST be a separate instance from Oracle FLEXCUBE Instance. This is to ensure that the machine learning algorithmic processing workload is not on the critical path of banking operations and consume critical FLEXCUBE server memory
Historical Data
Oracle FLEXCUBE Data Replication
Refer to the Installation Guide for completing the installation, prior to initiating the model building routine.
