This manual helps you get acquainted with the Process Framework module of Oracle FLEXCUBE Universal Banking system. This manual explains the basic design of Oracle the process framework and the common operations that you will follow while using it.
This manual is intended for the back-end and front-end staff who setup/use Oracle FLEXCUBE Universal Banking process framework.
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
The following abbreviations are used in this User Manual:
Abbreviation |
Description |
BPEL |
Business Process Execution Language |
WF |
Workflow |
This manual is organized as follows:
Chapter |
Description |
Chapter 1 |
Preface gives information on the intended audience. It also lists the various chapters covered in this User Manual. |
Chapter 2 |
Getting Started with Oracle FLEXCUBE Process Framework explains the features of Oracle FLEXCUBE process framework accessible from the landing page. |
Chapter 3 |
Origination Dashboards provides the details of origination dashboards in Oracle FLEXCUBE system. |
Chapter 4 |
Configurations explains the methods to configure Queues, Landing and Sub-stages to suit your bank’s requirements. |
Chapter 5 |
Function ID Glossary contains the function IDs mentioned in this user manual. |
This User Manual may refer to all or some of the following icons:
Icons |
Function |
Exit |
Add row |
Delete row |
Option List |
