5. Reports
5.1 Introduction
The report programs available under the Retail Teller (RT) module are explained in this chapter. All activities that are performed by the RT module are recorded. The inputs you have made at different stages are pieced together and can be extracted in the form of meaningful reports as and when you may require them. Every day teller doing the financial transactions, print hard copy of the reports.
5.2 Batch Journal Report
In this BIP report you can verify the transactions done by tellers and also for tallying purpose. This report lists the transactions done by a user in a day and sums up the debits and credits for the user and for reconciliation with the vouchers and cheques for onward submission. This report is generated for the current branch.
You can invoke ‘Batch Journal Report’ screen by typing ‘RTRPBJRN’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can specify the following parameters here:
Product Type
Select product type for which you wish to generate the report from the options. The following values are available for selection:
Report Format
Select the format in which you need to generate the report from the adjoining drop-down list. This list displays the following values:
Report Output
Select the output in which you need to generate the report from the adjoining drop-down list. This list displays the following values:
Printer At
Select location where you wish to print the report from the adjoining drop-down list. This list displays the following values:
Printer
Select printer using which you wish to print the report from the adjoining option list.
Click ‘OK’ button to generate the Batch Journal report, click ‘Exit’ to return to the Reports Browser.
5.2.1 Contents of the Report
The contents of the report are discussed under the following heads:
Header
The Header carries the Branch of the report, information on the branch and date, the ID of the user who generated the report, the date and time at which it was generated, the module of the report and product type.
Body of the report
The generated report will be ordered by the Teller ID.
Field Name
Field Description
Teller ID
This indicates the teller ID.
Currency
This indicates the currency.
Product
This indicates the product.
Account Number with Customer Name
This indicates the account number with customer name.
Credits
This indicates the credited amount for the transac­tion.
Debits
This indicates the debited amount for the transaction.
Commission
This indicates the commission charged for the trans­action.
Transaction Date and Time
This indicates the transaction date and time.
Transaction Number
This indicates the transaction number.
Authorizer ID
This indicates the authorizer ID.
Sum of Credits, Debits and Commission
This indicates the sum of the credits, debits and com­mission amount of transactions, teller wise.
5.3 Cash Position Branch Wise Report
This BIP report lists the cash position for all tellers under each currency. You can invoke ‘Cash Position Branch Wise’ screen by typing ‘RTRPCCY’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
The screen is as shown below:
5.3.1 Contents of the Report
Header
The Header carries the Branch of the report, information on the branch and date, the ID of the user who generated the report, the date and time at which it was generated and the module of the report.
Body of the report
The generated report will be ordered by the Currency, Teller ID.
Field Name
Description
Currency
Till ID
This indicates the till Id.
Teller ID
This indicates the teller Id.
Denomination Code
This indicates the denomination code
Till position for Teller, Currency wise
This indicates the till position for teller, currency wise.
Sum of the Till Position for the Currency
This indicates the sum of the till position for the currency.
5.4 Teller Transaction Branch Wise Report
This BIP report lists the transactions entered by tellers as on a specific transaction date.
You can invoke ‘Teller Transaction Branch Wise’ screen by typing ‘RTRPTRN’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Specify the transaction date.
5.4.1 Contents of the Report
Header
The Header carries the Branch of the report, information on the branch and date, transaction ID, the ID of the user who generated the report, the date and time at which it was generated and the module of the report.
Body of the report
Field Name
Description
Teller ID
Currency
Product with description
This indicates the product with the description.
Number of transactions by teller for the product
This indicates the number of transactions by teller for the product.
Total amount
This indicates the total amount.
Total Commission charged
This indicates the total commission charged.
5.5 Overage and Shortage Report
This report lists the overage/shortage cash transactions performed during the day for a branch.
You can invoke ‘Overage/Shortage Report’ screen by typing ‘TPROSREP’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Specify the following details here:
From Date
Specify the Overage/shortage transactions From Date here in the format YYYY-MM-DD. Alternatively, you can also select the date from the adjoining calendar button. By default the current application date is displayed here.
To Date
Specify the Overage/shortage transactions To Date here in the format YYYY-MM-DD. Alternatively, you can also select the date from the adjoining calendar button. By default the current application date is displayed here.
Branch Code
Select the branch code from the adjoining option-list. The list displays all valid branch codes. The list will not include any closed branches.
Click ‘OK’ button to generate the report. Click ‘Exit’ to return to the Reports Browser.
5.5.1 Contents of the Report
Header
The Header carries the Bank, Branch, Run date, User ID and the period for which the report is generated,
Body of the report
The generated report will have the following information:
Field Name
Description
Posting Date
Overage/Shortage for that date
User ID
User who has done the overage/shortage transaction.
Currency
Currency of the transaction
Overage
Overage amount for the currency
Shortage
Shortage amount for the currency
5.6 Instrument Details Report
When branches issue various instruments, they are subsequently paid and reconciled. You can generate ‘Instruments Details Report’ for a given day to list details of instruments based on the instrument status. The instrument details are grouped based on instrument and currency type. You can invoke ‘Instruments Details Report’ screen by typing ‘RTRINSDT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
Specify a valid code of the Branch in which report is being generated, from the adjoining option list.
Date
Specify a valid date for which you wish to generate instrument details report, from the adjoining calendar.
Status
Specify instrument status based on which you wish to generate the report, from the adjoining option list.
Report Format
Report Output
Printer At
Printer
5.6.1 Contents of the Report
The parameters specified while generating the report are printed at the beginning of the report. Other content displayed in the Instruments Details Report is as follows:
Header
Body of the Report
The following details are displayed as body of the generated report:
Field Name
Field Description
Instrument Type
Indicates Instrument Type
Issuer Short Name
Indicates Issuer Short Name
Instrument No.
Indicates Instrument Number
Instrument Currency
Indicates Instrument Currency
Instrument Amount
Indicates Instrument Amount
Payable Branch
Indicates Payable Branch
Instrument Status
Indicates Instrument Status
User ID
Indicates User ID
5.7 Authentication Report
There is a variation in the access rights, privileges, and transaction limits for each of your staff. Few transactions have to be revalidated and authorized by the supervisor before committing to the record. Also, few transactions have to be authorized by a supervisor due to legal/regulatory repercussions.
You can generate ‘Authentication Report’ which lists the authorizations provided on transaction.
You can invoke ‘Authentication Report’ screen by typing ‘STRBRNAU’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
Posting Date
Specify a valid Posting date of the transaction for which you wish to generate authentication details report, from the adjoining calendar.
Report Format
Report Output
Printer At
Printer
5.7.1 Contents of the Report
The parameters specified while generating the report are printed at the beginning of the report. Other content displayed in the Authentication Report is as follows:
Header
The following details are displayed in the header section:
Field Name
Field Description
Bank
Indicates Bank code and Bank Name
Branch
Indicates Branch Code and Branch Name
Run Date
Indicates Date on which report is generated
User ID
Indicates User ID
For Period
Indicates Period for which report is generated.
Body of the Report
Field Name
Field Description
Supervisor ID
Indicates Checker ID
User Id
Indicates Maker ID
Account Number
Indicates Account Number
Account Desc
Indicates Account Description
Transaction Description
Indicates Transaction Description
CCY
Indicates Transaction Currency
Transaction Amount
Indicates Transaction Amount
Date
Indicates Authorization Date
Time
Indicates the time
Authorization comments
Indicates Authorization comments
5.8 Cheques Deposited Today Report
During a day Bank receives various clearing cheques from customers, which have to be credited in to the respective accounts. To clear the settlement few details have to be furnished. You can generate ‘Cheques Deposited Today Report’, which lists cheques deposited to the accounts on the current day and their complete details.
You can invoke ‘Cheques Deposited Today Report’ screen by typing ‘STRCHDEP’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
Date
Specify the date for which you wish to generate the report from the adjoining calendar.
End Point
Specify cheque number which you wish to maintain as an end point to generate the report, from the adjoining option list.
Clearing Branch
Specify code of the branch clearing the cheques, for which the report is generated, from the adjoining option list.
Report Format
Report Output
Printer At
Printer
5.8.1 Contents of the Report
The parameters specified while generating the report are printed at the beginning of the report. Other content displayed in the Cheques Deposited Today Report is as follows:
Header
Body of the Report
Field Name
Field Description
Payee Brn
Indicates Payee Branch
Clearing Branch
Indicates the clearing Branch
Clearing branch name
Indicates the name of the clearing branch
Payee Account
Indicates Payee Account number
Customer short name
Indicates Customer short name
Customer value date
Indicates Value Date
Cheque amount
Indicates Cheque amount
Cheque number
Indicates the cheque number
Transaction currency
Indicates transaction Currency
Routing number
Indicates Routing number
Note
If the cheques deposited are from a different bank, then the customer and remitter names are displayed in the report.
5.9 Cheque Purchased Report
A teller purchases both the local and outstation cheques deposited by the customers, to credit on the day of deposition of cheques into the accounts. The balance available in the customer’s CASA account is updated for successful transaction.
During EOD, you can generate ‘Cheque Purchased Report’ with Teller and Authorizer ID details for reconciliation. The details of the report are grouped based on the product and currency type. You can invoke ‘Cheques Purchased Report’ screen by typing ‘STRCHPUR’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
Transaction Date
Specify transaction date for which the report needs to be generated. You can select the date using the adjoining calendar button.
Report Format
Report Output
Printer At
Printer
5.9.1 Contents of the Report
The parameters specified while generating the report are printed at the beginning of the report. Other content displayed in the Cheques Purchased Report is as follows:
Header
Field Name
Field Description
Bank
Branch
Run Date
User ID
Indicates User ID
For Period
Body of the Report
Field Name
Field Description
Product Code
Indicates PDC Product
Currency Code
Indicates Currency of the Cheque
Account Number
Indicates Beneficiary Account
Account Title
Indicates Beneficiary Account Description
Cheque number
Indicates cheque number
Txn. reference no.
Indicates Transaction Reference Number
Amount Purchased
Indicates Amount Purchased/discount
Interest Amount
Indicates Sum of Interest Amount
SC Amount
Indicates Sum of Charge Amount
Maker ID
Indicates Maker ID of the Transaction
Checker ID
Indicates Checked ID of the transaction
Note
If the purchase date and value date are same, then the Interest and SC amount are ‘0’.
5.10 Cheque Purchased Returned Today Report
If the instruments which were purchased by the branch to credit the customer accounts are returned by other banks due to valid reasons; then the customer accounts are reversed.
During EOD, you can generate ‘Cheque Purchased Returned Today Report’ which lists all the cheques which were purchased and returned on the specified day, for effective follow-up by the branches. You can invoke ‘Cheques Purchased Returned Today Report’ screen by typing ‘STRCHPRE’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
Transaction Date
Specify transaction date of the cheques for which the report is generated from the adjoining calendar.
Report Format
Report Output
Printer At
Printer
5.10.1 Contents of the Report
The parameters specified while generating the report are printed at the beginning of the report. Other content displayed in the Cheques Purchased Returned Today Report is as follows:
Header
Body of the Report
Field Name
Field Description
Payee A/C No.
Indicates Beneficiary Account Number
Cheque No
LCY
Indicates Local currency of the Branch
Amount Txn (LCY)
Indicates Cheque Amount in LCY
Routing No.
Indicates Routing No.
Txn CCY
Indicates Currency Code of the transaction
Amount Txn (TCY)
Indicates Amount in Transaction Currency
Reject Reason
Indicates Remarks of the Cheque Transaction
5.11 Drawer-wise Returned Cheques Report
Cheques are credited and discounted to the customer accounts, based on the purchase limit, margin and so on. Subsequently these cheques realized or dishonored and the corresponding details are entered.
You can generate ‘Drawer-wise Returned Cheques Report’ which lists details of the cheques returned by the correspondent bank or branch on a specified day. The report also provides details about the income earned through interest. Details in the report are grouped based on the Drawer. You can invoke ‘Drawer-wise Returned Cheques Report’ screen by typing ‘STRDRRET’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
Transaction Date
Select the transaction date using the adjoining calendar button. In the report, the system will include the transactions for the selected date.
Report Format
Report Output
Printer At
Printer
5.11.1 Contents of the Report
The parameters specified while generating the report are printed at the beginning of the report. Other content displayed in the Drawer-wise Returned Cheques Report is as follows:
Header
Body of the Report
Field Name
Field Description
Drawer ID
This indicates the identification of the drawer whose details are provided in the report
Cheque Return Count
This indicates the count of cheque returns
Account No
Account Desc
Indicates the description of the account
Customer Name
Indicates Customer Name
Cheque Dt
Indicates Cheque Date
Cheque No
Indicates Cheque Number
Routing No
Indicates Routing Number
Purchase Dt
Indicates Purchase Date
Purchase Srl No
Indicates Purchase Serial Number
Inst CCY
Purchase Limit
Indicates Limit Linked Amount
Inst Amount
Interest Amount
Indicates Interest Amount
SC Amount
Indicates Service Charge Amount
5.12 Cheque Issued on Daily Basis Report
You can invoke ‘Cheque Issued on Daily Basis Report’ screen by typing ‘RTRPCHQD’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
You can generate this report for all the branches or a single branch alone. You can indicate the branch for which the report is being generated using the following options:
From Date
Specify a valid date from when you wish to generate the report from the adjoining calendar.
To Date
Specify a valid date till when you wish to generate the report from the adjoining calendar.
5.12.1 Contents of the Report
The parameters specified while generating the report are printed at the beginning of the report. Other content displayed in the Report is as follows:
Header
Field Name
Field Description
Report Name
Indicates Report Name
Branch Code / Branch Name
Indicates Current Branch code and Branch Name
User ID
Indicates the Identification of the User
Module
Indicates the Module of the Report
Report Run Date
Indicates Current System Date
Report Run Time
Indicates Current System Time
Body of the Report
Field Name
Field Description
Branch
Indicates the branch code
Branch name
Indicates the name of the branch
Date of issue
Indicates the date of issue
Account Number
Indicates the account number
Currency
Indicates the currency of transaction
Customer Name
Indicates the name of the customer
Maker ID
Indicates the maker ID of the record
Maker Date
Indicates the date and time when the record was created
Checker ID
Indicates the checker ID of the record
Checker Date
Indicates the date and time on which the record was authorized
5.13 Paid Out Cheque Report
You can invoke ‘Paid Out Cheque Report’ screen by typing ‘RTRPPCHQ’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
Report Date
Specify date of the report from the adjoining calendar.
The parameters specified while generating the report are printed at the beginning of the report. Other content displayed in the report is as follows:
Header
Field Name
Field Description
Report Name
User ID
Module
Report Run Date
Report Run Time
Body of the Report
Field Name
Field Description
Indicates the transaction reference number
Dr Account Number
Indicates the debit account number
Dr Account Title
Indicates the debit account title
Amount
Indicates the amount
Currency
Indicates the currency of the transaction
Cheque Serial Number
Indicates the serial number of the cheque used
Date of the Cheque
Indicates the date in the cheque
Value Date
Indicates the value date
Beneficiary Title
Indicates the beneficiary title
5.14 Stationary Management Report
You can invoke ‘Stationary Management Report’ screen by typing ‘RTRPSMNG’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
Date
Header
Field Name
Field Description
Report Name
User ID
Module
Report Run Date
Report Run Time
Body of the Report
Field Name
Field Description
Opening Balance
Indicates the opening balance
Cheque Number Used
Indicates the number of the cheque used
Cancelled Cheque Number
Indicates number of the cancelled cheque
Date of Booking
Indicates the date of booking
Amount
Closing Balance
Indicates the closing balance
Status
Indicates the status
Maker ID
Indicates the identification of the maker of the record
Checker ID
Indicates the identification of the checker who authorized the record
5.15 Demand Draft/Purchase Order Stale Report
You can invoke ‘State Cheque Report’ screen by typing ‘RTRPSTAL’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
Date
Header
Field Name
Field Description
Report Name
User ID
Module
Report Run Date
Report Run Time
Page No
The page number of the report
Body of the Report
Field Name
Field Description
MC Number
Indicates the MC number
Debit Account Number
Title
Indicates the title
Amount
Date of Transaction
Indicates the date of transaction
Beneficiary Title
5.16 Processed FCY Collection Transaction Report
You can invoke ‘Processed FCY Collection Transaction Report’ screen by typing ‘RTRPFCYC’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Branch Code
Date
Header
Field Name
Field Description
Report Name
User ID
Module
Report Run Date
Report Run Time
Page No
Body of the Report
Field Name
Field Description
Transaction Code
Indicates the transaction code
Indicates the reference number of the transaction
Dr Account Number
Dr Account Title
Indicates the title of the debit account
Cr Account Number
Indicates the credit account number
Cr Account Title
Indicates the title of the credit account
Amount of the Cheque
Indicates the amount of the cheque
Beneficiary Bank
Indicates the beneficiary bank code
Booking Date
Indicates the booking date of the transaction
Value Date
Indicates the value date of the transaction
Rate Applied
Indicates the rate applied
Branch
Maker Id
Indicates the user ID of the user who created the transaction
Maker Date Stamp
Indicates the date on which the transaction was created
Checker Id
Indicates the user ID of the user who authorized the transaction
Checker Date Stamp
Indicates the date on which the transaction was authorized
