Error Code |
Message |
SE-MA0001 |
New user and current user must be different |
SE-MA0002 |
Contract reassigned |
SE-MA0003 |
New user id cannot be null |
SE-MA0004 |
Product code cannot be null |
SE-MA0005 |
Contract reference number cannot be null |
SE-MA0006 |
The Portfolio Contract Reference Number is not valid for the Product Code selected |
SE-MA0007 |
Contract $1 has been reassigned from User "$2" to User "$3" by User "$4" |
SE-MA0008 |
Security to be disallowed must be specified |
SE-MA0009 |
Security to be allowed must be specified |
SE-MA0010 |
Duplicate values encountered for this combination of CLASS CODE and MODULE |
SE-MA0011 |
Duplicate values encountered for this class code |
SE-MA0012 |
For WAC costing method, the Accrue Premium flag and the accrue discount flag should have the same value. |
SE-MA0013 |
The accounting role record has been not been entered properly |
SE-MA0014 |
Enter the class code |
SE-MA0015 |
Enter the class description |
SE-MA0016 |
Record deleted successfully |
SE-MA0017 |
Enter the module |
SE-MA0021 |
The Record is already closed. |
SE-MA0022 |
The Record is already open. |
SE-MA0023 |
A Market Code of this name already exists. |
SE-MA0024 |
Some element/elements in the string entered is not a part of the Swift Character set. Do you wish to continue? |
SE-MA0025 |
The Market Code, From Date and To Date combination should be unique. |
SE-MA0026 |
The Class Code entered for this module already exists. |
SE-MA0027 |
The system is not able to generate accounting roles and amount tags for this charge Class. |
SE-MA0028 |
Do you wish to redefault to the class as maintained latest in the class definition? |
SE-MA0029 |
Existing role to head mappings will be deleted and redefaulted from class. Wish to continue? |
SE-MA0030 |
Sorry! Redefaulting cannot be done. Class maintenance has to be authorized first. |
SE-MA0031 |
This rate code cannot be copied since it has been propagated to the present branch from head office. |
SE-MA0032 |
This rate code cannot be closed since it has been propagated to the present branch from head office. |
SE-MA0033 |
This rate code cannot be unlocked since it has been propagated to the present branch from head office. |
SE-MA0034 |
Rate propagation has failed. |
SE-MA0035 |
STANDARD rate type is mandatory for any rate code. |
SE-MA0036 |
The rate code + tenor code + CCY code combination for this effective date is already existing in the database. |
SE-MA0037 |
This rate code can only be maintained at the head office and only be propagated from there. |
SE-MA0038 |
Duplicate Tenor Codes are not allowed. |
SE-MA0039 |
Minimum rate cannot be greater than Maximum rate. |
SE-MA0040 |
Default rate should lie between minimum and maximum rate. |
SE-MA0041 |
Class Code and Module are mandatory fields. |
SE-MA0042 |
This rate code already exists. |
SE-MA0043 |
Basis Amount Tag, Event for Association, Application and Liquidation are mandatory fields |
SE-MA0044 |
Basis amount tag and Event for Association are mandatory fields. |
SE-MA0045 |
For Third Party as Charge Type, Third Party Type is mandatory |
SE-MA0046 |
This class cannot be closed because it has been already attached to a product/products. |
SE-MA0047 |
Swift Qualifier length cannot be less than four. |
SE-MA0048 |
For Net Consideration as yes, net consideration type(add/subtract) is mandatory. |
SE-MA0049 |
Duplicate values encountered during amount tag insertion. |
SE-MA0068 |
Initial Face Value can not be zero. |
SE-MA0069 |
Limits Maintenance will be deleted. Proceed? |
SE-MA0070 |
Weekday mandatory for weekly schedules |
SE-MA0071 |
Frequency is mandatory for periodic coupon/revision |
SE-MA0072 |
Limits not maintained. Proceed? |
SE-MA0073 |
Lot Size is mandatory |
SE-MA0074 |
Interest quotation method is mandatory |
SE-MA0075 |
Interest Rate Type is mandatory |
SE-MA0076 |
The maximum tenor must be greater than minimum tenor. |
SE-MA0077 |
Price Code cannot be null if Renouncable is Yes. |
SE-MA0078 |
Tenor cannot be null if Redeemable is Yes. |
SE-MA0079 |
Equity type is mandatory. |
SE-MA0080 |
Price Quotation method is mandatory. |
SE-MA0081 |
Face value or units is mandatory. |
SE-MA0082 |
Tenor details not input. |
SE-MA0083 |
Initial Face Value not input. |
SE-MA0084 |
Exception Limit should be greater than Override Limit |
SE-MA0085 |
Number of Decimals Mandatory |
SE-MA0086 |
Cannot Close. The record has already been processed!! |
SE-MA0087 |
Cannot Reopen. Record date is past! |
SE-MA0088 |
Cannot Unlock. The record not authorized atleast once |
SE-MA0045 |
SE-MA0089 |
Announcement Date should not be greater than or equal to Exercise End Date |
SE-MA0090 |
Record Date cannot be later then Event Date |
SE-MA0091 |
For Redeemable securities Event Date should be less than Redemption or Expiry date |
SE-MA0092 |
Event Date should be greater than Issue or Tear-off Date of the security |
SE-MA0093 |
Either Dividend Amount or Dividend Rate is mandatory |
SE-MA0094 |
Record Date Cannot be earlier than End of Exercise Date |
SE-MA0095 |
Value for field Internal Security Id is mandatory |
SE-MA0096 |
Value for field Event Date is mandatory |
SE-MA0097 |
Value for field Record Date is mandatory |
SE-MA0098 |
Value for field Issuer Payment CCY is mandatory |
SE-MA0099 |
Value for field Resultant Security Id is mandatory if Cash to Stock Option is "Yes" or "Reinvest" |
SE-MA0100 |
Exclusive Lock Acquired by Rajesh S from row 90 to 104 |
SE-MA0102 |
Event Date should not be less than the Issue or Tear-off Date of the security |
SE-MA0103 |
SE-MA0104 |
SE-MA0105 |
Announcement Date should not be greater than Event Date |
SE-MA0106 |
Announcement Date should not be greater than Record Date |
SE-MA0107 |
Internal Security Id cannot be NULL |
SE-MA0108 |
Event Date cannot be NULL |
SE-MA0109 |
Record Date cannot be NULL |
SE-MA0110 |
Resultant Security Id cannot be NULL |
SE-MA0111 |
Resultant Ratio cannot be NULL |
SE-MA0112 |
Stock To Cash Price cannot be NULL when stock to cash option is YES |
SE-MA0113 |
Exercise Date cannot be NULL when stock to cash option is YES |
SE-MA0114 |
Record Date for the event has elapsed -Record cannot be reopened |
SE-MA0115 |
Event Date should br greater than Exercise end date when stock to cash option is YES |
SE-MA0116 |
For Fixed Rate type Revision Rate has to be entered |
SE-MA0117 |
Announcement Date has to be less than Event Date |
SE-MA0118 |
End of Trading Date is mandatory |
SE-MA0119 |
End of Trading Date has to be less than Event Date |
SE-MA0120 |
Announcement Date cannot be null |
SE-MA0121 |
Mandatory fields are missing |
SE-MA0131 |
Cannot Retain.. Fractional Units not allowed for this security |
SE-MA0132 |
Value for field Intmdt Security Id is mandatory |
SE-MA0133 |
Non Zero Value for field Rights Ratio is mandatory |
SE-MA0134 |
Value for field Exercise Start Date is mandatory |
SE-MA0135 |
Value for field Exercise Price is mandatory |
SE-MA0136 |
Value for field Exercise End Date is mandatory |
SE-MA0137 |
Exercise Start Date cannot be less than Event Date |
SE-MA0138 |
Exercise End Date cannot be greater than or equal to Expiry Date of intermediate security |
SE-MA0139 |
Exercise End Date cannot be greater than or equal to Expiry Date of Resultant security |
SE-MA0140 |
Value for field Resultant Security Id is mandatory |
SE-MA0141 |
Non Zero Value for field Resultant Ratio is mandatory |
SE-MA0142 |
Announcement Date should be less than exercise end date when stock cash option is YES |
SE-MA0143 |
End Trading Date cannot be NULL |
SE-MA0144 |
Call Indicator cannot be NULL |
SE-MA0145 |
Redemption Type cannot be NULL |
SE-MA0146 |
For Quantity Redemption dispose fraction cannot be NULL |
SE-MA0147 |
Dispose Fraction should be NULL for Bullet or Series Redemption |
SE-MA0148 |
For Quantity Redemption percentage cannot be NULL |
SE-MA0149 |
Redemption Price cannot be NULL |
SE-MA0150 |
Issuer Payment CCY cannot be NULL |
SE-MA0151 |
Announcement date should not be greater than end trading date |
SE-MA0152 |
End Trading Date cannot be greater than event date |
SE-MA0153 |
Restart trading date cannot be less than event date |
SE-MA0154 |
End Trading Date should not be greater than Record Date |
SE-MA0155 |
For fractional units not allowed dispose fraction cannot be of Retain type |
SE-MA0156 |
Security Redemption has to authorized atleast once for unlocking |
SE-MA0157 |
Record already processed - cannot be unlocked |
SE-MA0158 |
Delete option disallowed for system generated Redemption Event |
SE-MA0159 |
Copy option disallowed for system generated Redemption Event |
SE-MA0160 |
Close option disallowed for system generated Redemption Event |
SE-MA0161 |
Reopen option disallowed for system generated Redemption Event |
SE-MA0162 |
Series has to be defined for Redemption Type equal to Series |
SE-MA0163 |
Record has to be authorized atleast once for unlocking |
SE-MA0164 |
Units Nominal Current cannot be more than Current |
Holdings |
SE-MA0165 |
Reinvested Bonus cannot be more than Initial Bonus Due |
SE-MA0166 |
Reinvested Dividend cannot be more than Initial Dividend Amount Due |
SE-MA0167 |
Block product Cannot be NULL for a Repo Product |
SE-MA0169 |
Cannot Unlock. The record has already been processed |
SE-MA0170 |
End of Exercise Date Cannot be less than Start of Exercise Date |
SE-MA0171 |
Record date should be later than today |
SE-MA0172 |
From Date Cannot be later than To Date |
SE-MA0188 |
Duplicate values encountered during accounting role insertion. |
SE-MA0189 |
Record is successfully saved. |
SE-MA0190 |
Record has been successfully deleted. |
SE-MA0191 |
Record has been successfully reopened. |
SE-MA0192 |
Record has been successfully closed. |
SE-MA0193 |
Accounting Role and Account head are not of the same type. Still wish to continue? |
SE-MA0194 |
This safe keeping location Id already exists. |
SE-MA0195 |
Scheme cannot be closed. Its already been attached to a product/products. |
SE-MA0196 |
Deletion of component not possible since the scheme is already attached to a product/products. |
SE-MA0197 |
Tax component cannot be null. |
SE-MA0198 |
Module and scheme are mandatory fields |
SE-MA0199 |
This Scheme already exists for the module. |
SE-MA0200 |
This rate type is a mandatory one. So, it cannot be closed. |
SE-MA0201 |
SE-MA0202 |
Duplicate SK Accounts are not allowed. |
SE-MA0203 |
Duplicate Tax Rate Codes are not allowed. |
SE-MA0204 |
Duplicate Tax Rates are not allowed. |
SE-MA0205 |
Duplicate Market Codes are not allowed. |
SE-MA0206 |
For FIXED as the Spot Date Method, All days from 1st to 31st should be handled and spot dates mentioned against them. |
SE-MA0207 |
For FIXED as the Ex Date method. All days from 1st to 31st should be handled and ex dates mentioned against them. |
SE-MA0208 |
Duplicate Issuer Tax Rate Codes are not allowed. |
SE-MA0209 |
This rate code can be maintained only at the head office. It will be propagated to the present branch from there. |
SE-MA0210 |
This rate is propagated across branches and can be closed only at the head office. |
SE-MA0211 |
This rate is propagated across branches and can be modified only at the head office. |
SE-MA0212 |
Failed to propagate this rate. |
SE-MA0213 |
For this rate, atleast the STANDARD rate type has to be maintained |
SE-MA0214 |
This combination of rate code, tenor code, currency code and effective date already exists for this branch. |
SE-MA0215 |
Rates for propagated rate codes can be maintained only at the head office branch. |
SE-MA0216 |
SE-MA0217 |
For CURRENCY HOLIDAY as the holiday type, HOLIDAY CURRENCY is mandatory. |
SE-PRD001 |
Input to Product Description is Mandatory (cannot be NULL) |
SE-PRD002 |
Record is Unauthorized. Closure Not Allowed |
SE-PRD003 |
Are you sure you want to Close the record? |
SE-PRD004 |
Record Successfully Saved |
SE-PRD005 |
A combination product with this product as a leg is open. Closure NOT Allowed |
SE-PRD006 |
Override Limit CANNOT be greater than Stop Limit |
SE-PRD007 |
Are you sure this is a Back Valued Product? |
SE-PRD008 |
Product Start Date CANNOT be greater than Product End Date |
SE-PRD009 |
Product end Date CANNOT be before Today |
SE-PREF01 |
Are you sure you want to redefault the Class? |
SE-PRD010 |
Deal Product Copy Failed |
SE-PRD011 |
Deal Product Delete Failed |
SE-PRD012 |
Security Product Copy Failed |
SE-PRD013 |
Security Product Delete Failed |
SE-PRD014 |
Charges have not been defined for the Product |
SE-PRD015 |
Security Restrictions have not been defined for the Product |
SE-PRD016 |
Portfolio Restrictions have not been defined for the Product |
SE-PRD017 |
Tax Components have not been defined for the Product |
SE-PRD018 |
Interest Components have not been defined for the Product |
SE-PRD019 |
Input to Product Start Date is Mandatory (cannot be NULL). |
SE-PRD020 |
Input to Product Description is Mandatory (cannot be NULL). |
SE-PRD021 |
Input to Product Group is Mandatory (cannot be NULL). |
SE-PRD022 |
Input to Exchange Rate Override Limit Variance is Mandatory (cannot be NULL). |
SE-PRD023 |
Input to Exchange Rate Stop Limit Variance is Mandatory (cannot be NULL). |
SE-PRD024 |
Input to buy Product/Sell Product Mandatory (cannot be NULL). |
SE-COMBP01 |
Rekey Values for the Buy and Sell Products Differ |
SE-COMBP02 |
Values for $1 for the Buy and Sell Products Differ |
SE-COMBP03 |
Start Date $1 of the Combination Product is lesser than Start Date $2 of Product $3 |
SE-COMBP04 |
End Date $1 of the Combination Product is greater than End Date $2 of Product $3 |
SE-COMBP05 |
The Normal Rate Variance of the Buy and Sell Products Differ |
SE-COMBP06 |
The Maximum Rate Variance of the Buy and Sell Products Differ |
SE-COMBP07 |
Counter Product is Mandatory if Rights Exercise is applicable |
SE-COMBP08 |
Product $1 is Closed. Reopening of Combination Product NOT Allowed |
CS-PRD008 |
Product Code is NOT Unique |
SEREAS-01 |
New User and Current User must be different |
SEREAS-02 |
SEREAS-03 |
New user ID cannot be NULL |
SEREAS-04 |
Product code cannot be NULL |
SEREAS-05 |
Contract reference number cannot be NULL |
SEREAS-06 |
No Unauthorized Contracts exist for Reassignment for Product "$1" |
SEREAS-07 |
The Deal Reference Number is not valid for the Product Code selected |
SEREAS-08 |
FAILED in reassigning the deal to the new user. |
SE-MA0220 |
Changing the Leg type will redefault the Preferences. OK to Proceed? |
SE-MA0221 |
Partial Release is not allowed for Bank Buy or Sell |
SE-MA0222 |
Partial Release and Brokerage are not allowed for Customer Buy or Sell |
SE-MA0223 |
Partial Release, Brokerage and Forward Deals are not allowed for Withdrawal or Lodgement |
SE-MA0224 |
Partial Release, Brokerage, Forward Deals, Automatic Money Settlement and Rekey of Money Settlement Date are not allowed for SK to SK Transfer |
SE-MA0225 |
Brokerage, Forward Deals, Automatic Money Settlement and Rekey of Money Settlement Date are not allowed for Block Securities |
SE-MA0226 |
Input to Exchange Rate type field is Mandatory |
SE-MA0227 |
Block deals not defined |
SE-MA0228 |
Function Securities Repo Specific Returns False |
SE-MA0229 |
No Positions maintained for this record |
SE-MA0230 |
Bombed in Positions Check Function for Repo Block Deals |
SE-MA0231 |
Failed to validate the Repo Exposure |
SE-MA0232 |
Failed to generate the Action Id |
SE-MA0247 |
Spot Days Count Basis and Spot Days are mandatory fields. |
SE-MA0248 |
For Weekday of Spot day being mentioned, holiday treatment becomes mandatory. |
SE-MA0249 |
Ex Days Count Basis and Ex Days are mandatory fields |
SE-MA0250 |
For Weekday of Ex day being mentioned, holiday treatment becomes mandatory |
SE-MA0251 |
From Day, To day, Month Indicator, Spot Date and Holiday Treatment are mandatory fields |
SE-MA0252 |
To Day cannot be earlier than From Day |
SE-MA0253 |
For Month Indicator as FUTURE, future months becomes mandatory |
SE-MA0254 |
For Month Indicator as PREVIOUS, previous months becomes mandatory |
SE-MA0255 |
Both Include To Dates should be same, either YES or NO. |
SE-MA0256 |
Both Liquidation and Accrual Denominator Basis Should have the same value |
SE-MA0257 |
Market Code as well as Market Description is mandatory before invoking TAX maintenance |
SE-MA0258 |
For Holiday Treatment being mentioned, Weekday of Spotday becomes mandatory |
SE-MA0259 |
For Holiday Treatment being mentioned, Weekday of Ex day becomes mandatory |
SE-MA0260 |
For Months Indicator as CURRENT, Spot Day has to be greater than To Day |
SE-MA0261 |
For Months Indicator as CURRENT, Ex Day has to be less than or equal to From Day |
SE-MA0262 |
Application Date should be less than the Previous Coupon Date for UNLOCK action to happen. |
SE-MA0263 |
Issuer Reference cannot be null |
SE-MA0264 |
Record Date should lie between Previous Coupon Date and Event Date. |
SE-MA0265 |
This Security Code already exists in this branch. |
SE-MA0266 |
Price Code, Price Quotation, Market Value Date and Price are mandatory fields. |
SE-MA0267 |
For Price Quotation Method as YIELD TO MATURITY, Interest Quotation Method has to be null |
SE-MA0268 |
For a BOND, Interest Quotation Method is mandatory. |
SE-MA0269 |
Market Value Date has to be greater than/equal to security Tearoff Date ($1). |
SE-MA0270 |
Market Value Date has to be less than/equal to Redemption Date of the Security ($1). |
SE-MA0271 |
Record/Records once authorised cannot be deleted, but it/they can be modified. |
SE-MA0273 |
This $1 cannot be unlocked as Record Date is already past. |
SE-MA0274 |
Parent Security Id, Intermediate Security Id and Resultant Security Id are mandatory fields. |
SE-MA0275 |
Announcement Date cannot be later than the Record Date itself. |
SE-MA0276 |
Record Date cannot be later than the Event Date. |
SE-MA0277 |
Record Date cannot be later than Today or Today itself. |
SE-MA0278 |
Exercise End Date has to be earlier than the Expiry date of the Intermediate Security ($1). |
SE-MA0279 |
End of Trading Date has to be today or beyond. |
SE-MA0280 |
End of Trading Date cannot be greater than Event Date. |
SE-MA0281 |
For Spot Days Count Basis as WORKING DAYS, holiday treatment becomes mandatory. |
SE-MA0282 |
For Ex Days Count Basis as WORKING DAYS, holiday treatment becomes mandatory. |
SE-MA0291 |
Exchange rate fixing date has to be provided. |
SE-MA0292 |
Exchange rate has to be provided. |
SE-MA0293 |
Issuer payment CCY has to be provided. |
SE-MA0294 |
Announcement Date should not be greater than today. |
SE-MA0295 |
Confirmed Date should not be greater than today. |
SE-MA0296 |
Exchange Rate Fixing Date should not be greater than today. |
SE-MA0297 |
Confirmed Date has to be provided. |
SE-MA0298 |
Value for Dispose Fraction is mandatory. |
SE-MA0299 |
Value for Resultant Ratio Num should not be less than or equal to zero. |
SE-MAO307 |
Value for Resultant Ratio Denom should not be less than or equal to zero. |
SE-MA0308 |
Value for Dividend Type has to be provided. |
SE-MA0309 |
Only confirmed records can be closed. |
SE-MA0310 |
Only confirmed records can be reopened. |
SE-MA0311 |
Do you really want to confirm the record? |
SE-MA0312 |
End of Trading Date has to be greater than today. |
SE-MA0313 |
Restart Trading Date has to be greater than End of Trading Date |
SE-MA0314 |
This Event Date cannot be maintained for the Security |
SE-MA0350 |
Value for field Announcement Date is mandatory. |
SE-MA0351 |
Announcement Date should be on or before today. |
SE-MA0352 |
Announcement Date should be less than Event Date and Record Date. |
SE-MA0353 |
Rights Exercise End Date should be after Rights Exercise Start Date |
SE-MA0354 |
Value for the field Minimum Rights Exercise Quantity is mandatory. |
SE-MA0355 |
Value for the field Rights Exercise Price is mandatory. |
SE-MA0356 |
Rights Exercise End Date should be later than today. |
SE-MA0357 |
Value for the field Confirmed Date is mandatory |
SE-MA0358 |
Do you really want to confirm? |
SE-MA0359 |
Confirmed Date should be on or before today. |
SE-MA0360 |
Cannot Close. The record has already been confirmed!! |
SE-MA0361 |
Cannot Reopen. The record has already been confirmed!! |
SE-MA0362 |
Mandatory Field ($1) is null. |
SE-MA0363 |
Warrants Exercise End Date should be after Warrants Exercise Start Date. |
SE-MA0364 |
Value for the field Minimum Warrants Exercise Quantity is mandatory. |
SE-MA0365 |
Value for the field Warrants Exercise Price is mandatory. |
SE-MA0366 |
Warrants Exercise End Date should be later than today. |
SE-MA0367 |
Cannot delete a once authorized record. |
SE-MA0368 |
Unauthorized records can be deleted but cannot be closed. |
SE-MA0369 |
Event Date is past -- Cannot reopen the record. |
SE-MA0370 |
Event Date is past -- Cannot close the record. |
SE-MA0371 |
Mandatory Field Security Id is null. |
SE-MA0372 |
Mandatory Field Portfolio Id is null. |
SE-MA0373 |
Position Reference No. for this combination of Branch Code, Portfolio Id and Security Id does not exist. |
SE-MA0374 |
Mandatory Field SK Location Id is null. |
SE-MA0375 |
Mandatory Field SK Location Account is null. |
SE-MA0376 |
Mandatory Field Security Form Code is null. |
SE-MA0377 |
Mandatory Field To Series is null. |
SE-MA0378 |
Current Holding \ Unauthorized Holding values not available for this Position Ref. No. and To Series at this SK location Id and Account. |
SE-MA0379 |
Quantity moved should be less than or equal to the available quantity in the series. |
SE-MA0380 |
Mandatory Field Quantity Moved is null. |
SE-MA0381 |
The quantity available in this series is null. |
SE-MA0382 |
The Effective Date does not lie in the coupon period of the Security. |
SE-MA0383 |
Cannot unlock -- the record is already confirmed. |
SE-MA0384 |
Record can be inserted only if the interest revision is manual. |
SE-MA0385 |
Event Date is before the interest start date of the security. |
SE-MA0386 |
Event Date should be before the redemption date of the security. |
SE-MA0387 |
No data found for Security Interest Start Date \ Redemption or Expiry Date |
SE-MA0388 |
This combination of Security Id, Interest Component and Event Date already exists. |
SE-MA0389 |
Value for Event Date is mandatory. |
SE-MA0390 |
This combination of Security Id, Interest Component and Effective Date already exists. |
SE-MA0391 |
Value for Effective Date is mandatory. |
SE-MA0392 |
System generated records cannot be modified. |
SE-MA0393 |
SE-MA0394 |
Announcement Date should be less than Event Date and Effective Date. |
SE-MA0395 |
Value for field Interest Component is mandatory. |
SE-MA0396 |
Value for field Revision Rate is mandatory. |
SE-MA0397 |
The Event Date does not lie in the coupon period of the Security. |
SE-MA0398 |
The Record Date and the Event Date cannot be earlier than or equal to Today |
SE-MA0399 |
Record for this Component and Currency already exists. |
SE-MA0400 |
Redemption Adjustment could not be done. |
SE-MA0401 |
The Total percentage for this security exceeds 100 |
SE-MA0402 |
Redemption Price must be greater than or equal to equivalent percentage of the initial face value |
SE-MA0410 |
Bonus Encashed can not be more than the Initial Bonus Due |
SE-MA0411 |
Bonus Encashed Quantity should be an Integer |
SE-MA0412 |
Record Date is Mandatory |
SE-MA0413 |
Event Date is Mandatory |
SE-MA0414 |
Record Date has to be later than Today |
SE-MA0415 |
Event Date has to be later than Today |
SE-MA0416 |
Event Date can not be earlier than Record Date |
SE-MA0425 |
Failed to Unlock the record |
SE-MA0426 |
Initiation can not be done as Initiation Processing Date is later than Today |
SE-MA0427 |
Collection can not be done as Collection Processing Date is later than Today |
SE-MA0428 |
Liquidation can not be done as Liquidation Processing Date is later than Today |
SE-MA0429 |
Do you want process Initiation? |
SE-MA0430 |
Do you want process Collection? |
SE-MA0431 |
Do you want process Liquidation? |
SE-MA0432 |
Failed to process Initiation |
SE-MA0433 |
Failed to process Collection |
SE-MA0434 |
Failed to process Liquidation |
SE-MA0435 |
Initiation processed Successfully |
SE-MA0436 |
Collection processed Successfully |
SE-MA0437 |
Liquidation processed Successfully |
SE-MA0438 |
Do you want to reverse the event $1? |
SE-MA0439 |
Failed to process the event |
SE-MA0440 |
Failed to apply Charges |
SE-MA0441 |
Failed to apply Tax |
SE-MA0442 |
Failed to pickup Settlements |
SE-MA0443 |
Event can not be processed. Security Quantity is zero |
SE-MA0444 |
Event can not be processed. Security Quantity is Negative |
SE-MA0445 |
Event can not be processed. Rights due is zero |
SE-MA0446 |
Event can not be processed. Rights due is Negative |
SE-MA0447 |
Event can not be processed. Warrants due is zero |
SE-MA0448 |
Event can not be processed. Warrants due is Negative |
SE-MA0449 |
Event can not be processed. Residual Bonus Due is zero |
SE-MA0450 |
Event can not be processed. Residual Bonus Due is Negative |
SE-MA0451 |
Event can not be processed. Redemption Due is zero |
SE-MA0452 |
Event can not be processed. Redemption Due is Negative |
SE-MA0453 |
There are no Interest Components associated with the Security |
SE-MA0454 |
There are no Issuer Tax Components associated with the Security |
SE-MA0455 |
Failed to Reverse the Event |
SE-MA0456 |
Event Successfully Reversed |
SE-MA0460 |
Select the Portfolio Id to start Printing from. |
SE-MA0461 |
Select the to Portfolio Id to Print. |
SE-MA0462 |
The From Portfolio Id should be less than the To Portfolio Id |
SE-MA0463 |
Select the From Customer Id |
SE-MA0464 |
Select the To Customer Id |
SE-MA0465 |
The From Customer should be less than the To Customer. |
SE-MA0466 |
The Processing Date cannot be null |
SE-MA0467 |
Select the From Security Id |
SE-MA0468 |
Select the To Security Id |
SE-MA0469 |
The From Security Id should be less than the To Security Id |
SE-MA0470 |
The redemption type does not match with the redemption type of Security Definition |
SE-MA0471 |
An open bullet redemption record already exists. Cannot have another record |
SE-MA0472 |
Active Deals exist that are due to settle on or after the record date of redemption. Cannot save. |
SE-MA0473 |
Active Deals exist using this series that are due to settle on or after the record date of redemption. Cannot save. |
SE-MA0474 |
Start Date cannot be greater than Branch Date |
SE-MA0475 |
There must be atleast one open record on the redemption date for series redemption. Cannot close this record |
SE-MA0476 |
End Date cannot be greater than Branch Date |
SE-MA0477 |
End date cannot be less than Start Date |
SE-MA0478 |
Open Coupon record(s) exist after the redemption event date. Cannot save. |
SE-MA0479 |
Open Interest Revision record(s) exist after the redemption event date. Cannot save. |
SE-MA0480 |
There must be atleast some percentage left on the final redemption date. |
SE-MA0481 |
Redemption Price must be greater than or equal to Initial Face Value $1 |
SE-MA0482 |
Open Bullet redemption record not correctly maintained for security $1 |
SE-MA0483 |
Only One open Bullet Redemption record should be maintained for security $1 |
SE-MA0484 |
Atleast one open redemption record should be maintained for security $1 on the maturity date $2 |
SE-MA0485 |
Sum of all the open redemption records is not 100 for $1 |
SE-MA0486 |
The trading date is later than the end of trading date maintained in the redemption record |
SE-MA0487 |
Deal Trade date lies in a non trading period. |
SE-MA0488 |
Deal Settlement date is after the security maturity date |
SE-MA0489 |
Redemption Validations for this security failed |
SE-MA0490 |
Select the From Event Date. |
SE-MA0491 |
Select the To Event Date. |
SE-MA0492 |
The From Date cannot be greater than the To date. |
SE-MA0493 |
Failed in populating security details for the new branch |
SE-MA0494 |
Effective Date should be later than today |
Error Code |
Message |
SE-SO0001 |
Internal Security ID must be Unique |
SE-SO0002 |
ISIN Identifier must be Unique |
SE-SO0003 |
Market of Issue cannot be cleared after having been populated once. |
SE-SO0004 |
Security Currency cannot be cleared after having been populated once. |
SE-SO0005 |
Initial Face Value would be cleared. Proceed? |
SE-SO0006 |
Issue Price would be cleared. Proceed? |
SE-SO0007 |
Redemption Price would be cleared. Proceed? |
SE-SO0011 |
By SWIFT Standards, valid day count indicators are A001, A002, A003, A004, A005, A006 and A007 |
SE-SO0031 |
By SWIFT Standards, there needs to be necessarily $1 characters |
SE-SO0032 |
By SWIFT Standards, valid characters are [A - Z] , [0 - 9] |
SE-SO0033 |
By SWIFT Standards, some characters are invalid. Proceed with appropriate substitution? |
SE-SO0051 |
Internal Security ID is Mandatory |
SE-SO0052 |
Product is Mandatory |
SE-SO0053 |
Market of Issue is Mandatory |
SE-SO0054 |
Issuer ID is Mandatory |
SE-SO0055 |
Registered / Bearer is Mandatory |
SE-SO0056 |
Form Type is Mandatory |
SE-SO0057 |
Quantity Quotation is Mandatory |
SE-SO0058 |
Price Quotation is Mandatory |
SE-SO0059 |
Interest Quotation is Mandatory |
SE-SO0060 |
Unit Decimals is Mandatory |
SE-SO0061 |
Lot Size is not populated. Proceed? |
SE-SO0062 |
Redemption Type is Mandatory |
SE-SO0063 |
Security Currency is Mandatory |
SE-SO0064 |
Payment Currency is Mandatory |
SE-SO0065 |
Issue /Tearoff Date is Mandatory |
SE-SO0066 |
Start of Interest Date is Mandatory |
SE-SO0067 |
Start of Trading Date is Mandatory |
SE-SO0068 |
Redemption / Expiry Date is Mandatory |
SE-SO0069 |
Start of Interest Date is earlier than Issue /Tearoff Date. Proceed? |
SE-SO0070 |
Start of Trading Date must be later than Issue / Tearoff Date |
SE-SO0071 |
Start of Trading Date must be later than Start of Interest Date |
SE-SO0072 |
Redemption / Expiry Date must be later than Issue / Tearoff Date |
SE-SO0073 |
Redemption / Expiry Date must be later than Start of Interest Date |
SE-SO0074 |
Redemption / Expiry Date must be later than Start of Trading Date |
SE-SO0075 |
Initial Face Value is Mandatory |
SE-SO0076 |
Issue Price is Mandatory |
SE-SO0077 |
Redemption Price is Mandatory |
SE-SO0078 |
Issue Price must be lesser than Initial Face Value |
SE-SO0079 |
Redemption Price must be greater than or equal to Initial Face Value |
SE-SO0080 |
Quantity Quotation must be "UNITS" |
SE-SO0081 |
Lot Size must be a multiple of Initial Face Value |
SE-SO0101 |
Coupon Frequency is Mandatory |
SE-SO0102 |
Coupon Weekday is Mandatory |
SE-SO0103 |
Revision Frequency is Mandatory |
SE-SO0104 |
Revision Weekday is Mandatory |
SE-SO0105 |
Rounding Basis is Mandatory |
SE-SO0106 |
Rate Basis is Mandatory |
SE-SO0107 |
Accrual Numerator Method is Mandatory |
SE-SO0108 |
Accrual Denominator Method is Mandatory |
SE-SO0109 |
Accrual Denominator Basis is Mandatory |
SE-SO0110 |
Liquidation Numerator Method is Mandatory |
SE-SO0111 |
Liquidation Denominator Method is Mandatory |
SE-SO0112 |
Liquidation Denominator Basis is Mandatory |
SE-SO0113 |
Accrual Denominator Basis and Liquidation Denominator Basis must be identical |
SE-SO0114 |
Accrual Include To Day and Liquidation Include To Day must be identical |
SE-SO0115 |
If Rate Basis and Accrual / Liquidation Denominator Basis are not identical then it must be Periodic Coupon |
SE-SO0116 |
If Rate Basis and Accrual / Liquidation Denominator Basis are not identical then it must not be Weekly Coupon |
SE-SO0131 |
Collateral Type is Mandatory |
SE-SO0132 |
Dividend Basis is Mandatory |
SE-SO0133 |
Warrant Basis is Mandatory |
SE-SO0134 |
Rights Basis is Mandatory |
SE-SO0151 |
Coupon Schedules have not been maintained. Proceed? |
SE-SO0181 |
Series must be Unique |
SE-SO0182 |
Redemption of this Series has already been defined |
SE-SO0183 |
Series is Mandatory |
SE-SO0201 |
Base Start Date must be Unique |
SE-SO0202 |
Base Start Date must later than Start of Interest Date |
SE-SO0203 |
Base Start Date must be earlier than Redemption/Expiry Date |
SE-SO0204 |
Base End Date must be later than Start of Interest Date |
SE-SO0205 |
Base End Date must be earlier than or equal to Redemption/Expiry Date |
SE-SO0206 |
Base Start Date is Mandatory |
SE-SO0207 |
Base End Date must be later than Base Start Date |
SE-SO0208 |
Base Frequency is Mandatory |
SE-SO0209 |
Week Day is Mandatory |
SE-SO0210 |
Base Start Date must be on specified the Weekday |
SE-SO0231 |
First Previous Virtual Coupon Date must be earlier than Previous Coupon Date |
SE-SO0232 |
First Previous Virtual Coupon Date must be later than Previous Coupon Date |
SE-SO0233 |
Second Previous Virtual Coupon Date must be earlier than Previous Coupon Date |
SE-SO0234 |
First Next Virtual Coupon Date must be later than Next Coupon Date |
SE-SO0235 |
First Next Virtual Coupon Date must be earlier than Next Coupon Date |
SE-SO0236 |
Second Next Virtual Coupon Date must be later than Next Coupon Date |
SE-SO0237 |
First Previous Virtual Coupon Date is Mandatory |
SE-SO0238 |
Second Previous Virtual Coupon Date is Mandatory |
SE-SO0239 |
First Next Virtual Coupon Date is Mandatory |
SE-SO0240 |
Second Next Virtual Coupon Date is Mandatory |
SE-SO0261 |
Effective Date must later than Start of Interest Date |
SE-SO0262 |
Effective Date must be earlier than Redemption/Expiry Date |
SE-SO0263 |
Effective Date is Mandatory |
SE-SO0281 |
Event Date must be Unique |
SE-SO0282 |
Event Date must be later than Issue/Tearoff Date |
SE-SO0283 |
Event Date must be earlier than Redemption/Expiry Date |
SE-SO0284 |
Cumulative % To Be Redeemed must be lesser than 100% |
SE-SO0285 |
Redemption Price must be greater than equal to Initial Face Value |
SE-SO0286 |
SE-SO0287 |
% To Be Redeemed is Mandatory |
SE-SO0288 |
SE-SO0289 |
Disposition of Fractions is Mandatory |
SE-SO0290 |
Redemption Price must be greater than equal to Face Value being Redeemed |
SE-SO0291 |
SE-SO0401 |
Attributes defaulted from Market of Issue would be redefaulted. Proceed? |
SE-SO0402 |
Coupon Schedules would be deleted. Proceed? |
SE-SO0403 |
Revision Schedules would be deleted. Proceed? |
SE-SO0404 |
Redemption Schedules would be deleted. Proceed? |
SE-SO0405 |
Interest Component/s would need to be associated afresh. Proceed? |
SE-SO0406 |
Tax Component/s would need to be associated afresh. Proceed? |
SE-SO0407 |
MIS would need to be associated afresh. Proceed? |
SE-SO0501 |
Unable to Update Maintenance Stamp in Security Definition Function |
SE-SO0502 |
Unhandled Exception in Security Definition Function |
SE-SO0503 |
SE-SO0504 |
SE-SO0505 |
Unable to Update Current Block Items in Security Definition Function |
SE-SO0506 |
SE-SO0507 |
SE-SO0508 |
SE-SO0509 |
Unable to Commit in Security Definition Function |
SE-SO0510 |
Security Definition Saved Successfully |
SE-SO0511 |
SE-SO0512 |
SE-SO0513 |
Security Definition Deleted Successfully |
SE-SO0514 |
SE-SO0515 |
SE-SO0516 |
SE-SO0517 |
Security Definition is not yet Authorized Once |
SE-SO0518 |
Security Definition is Closed Already |
SE-SO0519 |
Deals have already been struck for the Security |
SE-SO0520 |
Unable to Post in Security Definition Function |
SE-SO0521 |
SE-SO0522 |
Security Definition Closed Successfully |
SE-SO0523 |
SE-SO0524 |
Security Definition is Open Already |
SE-SO0525 |
SE-SO0526 |
SE-SO0527 |
Security Definition Reopened Successfully |
SE-SO0528 |
SE-SO0551 |
Product is Unavailable in the Current List |
SE-SO0552 |
Market of Issue is Unavailable in the Current List |
SE-SO0553 |
Issuer ID is Unavailable in the Current List |
SE-SO0554 |
Security Currency is Unavailable in the Current List |
SE-SO0555 |
Payment Currency is Unavailable in the Current List |
SE-SO0556 |
Collateral Type is Unavailable in the Current List |
SE-SO0557 |
Revaluation Price Code is Unavailable in the Current List |
SE-SO0601 |
SE-SO0602 |
SE-SO0603 |
SE-SO0604 |
SE-SO0605 |
SE-SO0606 |
SE-SO0607 |
SE-SO0608 |
SE-SO0609 |
SE-SO0610 |
SE-SO0611 |
SE-SO0612 |
SE-SO0613 |
SE-SO0614 |
SE-SO0615 |
SE-SO0616 |
SE-SO0617 |
SE-SO0618 |
SE-SO0619 |
SE-SO0620 |
SE-SO0621 |
SE-SO0622 |
SE-SO0623 |
SE-SO0624 |
SE-SO0625 |
SE-SO0626 |
SE-SO0627 |
SE-SO0651 |
Coupon Schedule Definition resulted in convergent Coupon Dates |
SE-SO0652 |
The Tenor of the Security does not conform to the Tenor Variance specified at the Product Level |
SE-SO0653 |
Coupon Date missing on Redemption Date $1 |
SE-SO0654 |
No Series has been defined for Redemption on Event Date $1 |
SE-SO0655 |
Revision Schedule Definition resulted in convergent Revision Dates |
SE-SO0656 |
Effective Date of Revision on Event Date $1 does not lie within the same Coupon Period as the Event Date |
SE-SO0657 |
Interest Rate not populated for Interest Component $1 |
SE-SO0658 |
All Interest Components have been Waived |
SE-SO0659 |
Tax Rate Code not populated for Tax Component $1 |
SE-SO0660 |
The Issue date should be later than the product start date |
SE-SO0661 |
The Redemption or Expiry date cannot be later than the product end date |
SE-SO0662 |
The Redemption Price is lesser than the Initial Face Value. Continue? |
Error Code |
Message |
SE-AC001 |
Failed to Lock SE Leg Reference No. $1 for $2 event |
SE-AC002 |
Failed to get End Of Input for the current branch |
SE-AC003 |
This is an End of Day process |
SE-AC004 |
First run the predecessor programs before Event Selection and ALPL program |
SE-AC005 |
Process Till Date is Mandatory |
SE-AC006 |
Process Till Date cannot be greater than 365 days from today |
SE-AC007 |
Are you sure you want to start Event Selection and ALPL? |
SE-AC008 |
Event Selection and Processing and ALPL process Failed. |
SE-AC009 |
Event Selection and Processing and ALPL process successfully completed |
SE-BA0001 |
Unhandled Exception in Sepkss_repo.fn_populate_work_table |
SE-BA0002 |
Unhandled Exception in Sepkss_repo.fn_repo_block_deals |
SE-BA0003 |
Unhandled Exception in fn_create_block_deals |
SE-BA0004 |
Unhandled Exception in fn_ammend_block_deals |
SE-BA0005 |
Unhandled Exception in fn_delete_block_deals |
SE-BA0006 |
Insert to setbs_deal_master bombed |
SE-BA0007 |
Insert to setbs_deal_detail bombed |
SE-BA0008 |
Insert to cstbs_contract bombed |
SE-BA0009 |
Insert to setbs_mm_repo_linkage bombed |
SE-BA0010 |
Updation of cstbs_contract bombed |
SE-BA0011 |
Insert to setws_repo_rrepo_blocks bombed |
SE-BA0012 |
Unhandled Exception in Sepkss_repo.fn_delete_action |
SE-BA0013 |
Security Value $1 should not be less than Loan Amount $2 |
SE-BA0014 |
Unhandled Exception in fn_calculate_security_val |
SE-BA0015 |
Unhandled Exception in Sepkss_repo.fn_repo_release_block |
SE-BA0016 |
Unhandled Exception in sepkss_repo.fn_repo_authorize |
SE-BA0017 |
Old Deal Reference cannot be Null |
SE-BA0018 |
Copy Flag should be either V or N |
SE-BA0019 |
Select from Cstb Contract failed |
SE-BA0020 |
Select from setbs_deal_master failed |
SE-BA0021 |
Unhandled exception in fn_project_balance |
SE-BA0022 |
Unhandled exception in fn_get_pfolio_balance |
SE-BA0023 |
Unhandled exception in fn_get_balances |
SE-BA0024 |
Unable to insert into setb_pfolio_vdated_movmnts |
SE-BA0025 |
Unable to insert into setb_pfolio_skacbalances |
SE-BA0026 |
Unable to get record from setb_pfolio_skacbalances |
SE-BA0027 |
Unhandled exception in fn_upd_vbal_opening |
SE-BA0028 |
Failed to get the commit frequency |
SE-BA0029 |
Unable to get record from sevw_pfolio_skacbalances |
SE-BA0030 |
Cannot settle Sell deal $1;Deal quantity ($2) is greater than Available balance ($3) |
SE-BA0031 |
SE-BA0032 |
Failed to get the Next Processing Date |
SE-BA0033 |
Unable to insert record into setb_event_log |
SE-BA0034 |
Unable to lock record $1 |
SE-BA0035 |
Failed to insert into $1 |
SE-BA0036 |
Unable to read from setb_event_log |
SE-BA0037 |
Unhandled exception in fn_rights_RXLL |
SE-BA0038 |
Unhandled exception in fn_build_event_advice |
SE-BA0039 |
Unhandled exception in fn_populate_vdbals |
SE-BA0040 |
Failed to do FPL accrual for $1 |
SE-BA0041 |
No data found in setm_security_master |
SE-BA0042 |
No data found in setm_cash_dividend |
SE-BA0043 |
No data found in setm_portfolio_master |
SE-BA0044 |
No data found in setm_sk_location |
SE-BA0045 |
Error while updating setm_corp_actions_due |
SE-BA0046 |
When Others of fn_cash_dvnd_population |
SE-BA0047 |
No data found in setm_stock_dividend |
SE-BA0048 |
Error while rounding Rights fraction |
SE-BA0049 |
When Others of fn_bonus_population |
SE-BA0050 |
No data found in setm_rights |
SE-BA0051 |
When Others of fn_rights_population |
SE-BA0052 |
No data found in setm_warrants |
SE-BA0053 |
When Others of fn_warrant_population |
SE-BA0054 |
No data found in setm_redemption |
SE-BA0055 |
When Others of fn_redemption_population |
SE-BA0056 |
Unhandled exception in fn_redemption series |
SE-BA0057 |
No data found in setm_coupon |
SE-BA0058 |
When Others of fn_coupon_population |
SE-BA0059 |
Unhandled exception in fn_get_sk_for_buysell |
SE-BA0060 |
Select from SE Master and Detail to Populate Work Table Failed |
SE-BA0061 |
Security Ccy not maintained for Internal Security Id |
SE-BA0062 |
Latest ESN not maintained for Contract Reference |
SE-BA0063 |
Updation of setbs_deal_master bombed |
SE-BA0064 |
Updation of setbs_deal_detail bombed |
SE-BA0065 |
Select from setbs_mm_repo_linkage failed |
SE-BA0066 |
Insert to setws_tmp_repo_exposure bombed |
SE-BA0067 |
Unhandled Exception in fn_calculate_repo_exposure |
SE-BA0068 |
Unhandled Exception in sepkss_copy.fn_secopy_adeal |
SE-BA0069 |
Insert to Cstb Contract Failed |
SE-BA0070 |
Unhandled Exception in fn_cstb_contract_insert |
SE-BA0071 |
Updation Of Cstb Contract Failed |
SE-BA0072 |
Unhandled Exception in fn_cstb_contract_update |
SE-BA0073 |
Insert to setbs_deal_master Failed |
SE-BA0074 |
Unhandled Exception in fn_deal_master_insert |
SE-BA0075 |
Insert to setbs_deal_detail Failed |
SE-BA0076 |
Unhandled Exception in fn_deal_detail_insert |
SE-BA0077 |
Insert to setbs_deal_parties Failed |
SE-BA0078 |
Unhandled Exception in fn_deal_parties_insert |
SE-BA0079 |
Insert to setbs_deal_parties_narrative Failed |
SE-BA0080 |
Unhandled Exception in fn_deal_narrative_insert |
SE-BA0081 |
Inserting into exception for reference number $1 failed |
SE-BA0082 |
Unhandled exception in getting all legs to be processed for MSTL |
SE-BA0083 |
Insert into event log bombed for leg $1 |
SE-BA0084 |
Unhandled exception in fn process leg for MSTL for leg $1 |
SE-BA0085 |
Failed to Lock SE Leg reference no. $1 for $2 event |
SE-BA0086 |
Portfolio ID does not exist for position reference $1 |
SE-BA0087 |
Corporate action notice details could not be got for $1 |
SE-BA0088 |
Failed to update corporate actions due table for $1 |
SE-BA0089 |
Failed in identifying if processing is required |
SE-BA0090 |
Failed in inserting into contract event advice table for $1 |
SE-BA0091 |
Unhandled exception in fn_periodic_accrual for Forward P/L |
SE-BA0092 |
Failed to do product level FPL accruals for $1 |
SE-BA0093 |
Unhandled exception in fn_pass_product_entries for Forward P/L |
SE-BA0094 |
Unable to lock cstb_contract for $1 |
SE-BA0095 |
Unhandled exception in fn_accrue_for_aleg |
SE-BA0096 |
Unhandled exception in fn_reverse_for_a_leg |
SE-BA0097 |
Unhandled exception in fn_complete_fpl_accrual |
SE-BA0098 |
Failed to insert into setb_event_log for $1 |
SE-BA0099 |
Unhandled exception in function fn_right_tearoff_RGLL |
SE-BA0100 |
Unhandled exception in function fn_pass_product_entries |
SE-BA0101 |
Unable to do product level accruals for portfolio $1 and ccy $2 |
SE-BA0102 |
Unable to update the setb_fwdpnl_master for portfolio $1 and ccy $2 |
SE-BA0103 |
Unhandled exception in function fn_update_opening_bal |
SE-BA0106 |
Unhandled exception in function fn_msg_handoff |
SE-BA0107 |
Next process date $1 > Process till date $2 for product $3 |
SE-BA0108 |
Unable to get record from $1 for record $2 |
SE-BA0109 |
Unable to lock record from $1 for record $2 |
SE-BA0110 |
Unhandled exception in function fn_settlements |
SE-BA0111 |
Error updating processed flag in setbs_caevent_log to W(work in progress) for Action ID -->> $1 |
SE-BA0112 |
Collection cannot be processed before initiation for internal Action ID $1 and position reference $2 |
SE-BA0113 |
Liquidation cannot be processed before initiation/collection for internal Action ID $1 and position reference $2 |
SE-BA0114 |
Unhandled exception - when others for internal Action ID $1 and position reference $2 |
SE-BA0115 |
Error updating processed flag in setbs_caevent_log to Y(Processed) for Action ID -->> $1 |
SE-BA0116 |
Unhandled exception – when others in function fn_dividend_auto. |
SE-BA0117 |
Error selecting corporate actions record for internal Action ID $1 and position reference $2 |
SE-BA0118 |
Unhandled exception - when others in function fn_dividend_manual |
SE-BA0119 |
Unable to lock record in setbms_corp_actions_due for internal Action ID $1 and position reference $2 |
SE-BA0120 |
Error selecting corporate actions record for update |
SE-BA0121 |
Error selecting portfolio product and Portfolio Ref No for Portfolio ID -->> $1 |
SE-BA0122 |
Unhandled exception in function fn_process_event. |
SE-BA0123 |
Function sepkss_utils.fn_lock_cstb_contract returned false for position reference $1 |
SE-BA0124 |
Failed to lock cstbs_contract for position reference $1 |
SE-BA0125 |
Unhandled exception - when others of function fn_coupon_auto |
SE-BA0126 |
Coupon amount due is zero for component $1 |
SE-BA0127 |
Unhandled exception - when others of function fn_process_interest_due |
SE-BA0128 |
Unhandled exception in function fn_get_locks |
SE-BA0131 |
Unhandled exception in function fn_SPLP_for_aleg |
SE-BA0132 |
Unhandled exception in function fn_SPSP_for_aleg |
SE-BA0133 |
Unhandled exception in function fn_SSLP_for_aleg |
SE-BA0134 |
Unhandled exception in function fn_SSSP_for_aleg |
SE-BA0135 |
Failed to insert into setbs_dstl_details for $1 |
SE-BA0136 |
Failed to update setbs_dstl_master for $1 |
SE-BA0137 |
Failed while rounding amount tag $1 for amount $2 |
SE-BA0138 |
Unhandled exception in fn_memo_fpl_accrual |
SE-BA0139 |
Failed to get the ESN for Memo accrual |
SE-BA0140 |
Cannot settle $1 as it is not fully matched |
SE-BA0141 |
Unhandled exception in fn_complete_DSTL |
SE-BA0142 |
Failed to get current_holding |
SE-BA0143 |
Failed to do DSTL for $1 as position goes +ve for Issuer Portfolio $2. |
SE-BA0144 |
Failed to do DSTL for $1 as position goes -ve for Non-Issuer Portfolio $2. |
SE-BA0145 |
Unable to select from setb_deal_detail for $1 |
SE-BA0146 |
Unable to select from setb_deal_master for $1 |
SE-BA0147 |
Unable to select from setb_portfolio_master for $1 |
SE-BA0148 |
Unable to update setb_caevent_tearoff_log |
SE-BA0149 |
Unable to select from setm_security_master for $1 |
SE-BA0150 |
Unable to select from setb_dstl_master for $1 and $2 |
SE-BA0151 |
This program can be run only as part of End of Day or Beginning of Day processing. |
SE-BA0152 |
Select from setms_security_master failed |
SE-BA0153 |
Select from setms_price_detail failed |
SE-BA0154 |
Select from ldtbs_contract_master failed |
SE-BA0155 |
Select from ldtbs_contract_iccf_details failed |
SE-BA0156 |
Select from ldtbs_contract_balance failed |
SE-BA0157 |
Unhandled exception in fn_calculate_mm_amount |
SE-BA0158 |
Unhandled exception in Sepkss_repo.fn_reverse_block_deals |
SE-BA0159 |
Unhandled exception in Sepkss_repo.fn_roll_block_deals |
SE-BA0160 |
SE-BA0161 |
Security expires before Contract Maturity |
SE-BA0162 |
Select from setms_portfolio_master failed |
SE-BA0163 |
Select from ldtms_product_master failed |
SE-BA0164 |
Unhandled exception in fn_roll_each_block_deal |
SE-BA0165 |
Failed to update cstbs_contract_event_log |
SE-BA0166 |
Block Product not maintained for this product |
SE-BA0167 |
Unhandled exception in fn_reverese_each_block_deal |
SE-BA0168 |
Failed to delete from setbs_caevent_tearoff_log |
SE-BA0169 |
Confirmed Date should not be more than Today |
SE-BA0170 |
Improper Internal Action ID |
SE-BA0171 |
Insert to setbs_caevent_tearoff_log failed |
SE-BA0172 |
Unhandled exception in sepks_utils.fn_populate_caevent_tear_log |
SE-BA0173 |
Unhandled exception in sepks_utils.fn_delete_caevent_tear_log |
SE-BA0174 |
Insert to setbs_caevent_expiry_log failed |
SE-BA0175 |
Securities with only Quantity type of redemption can be processed for rebuild |
SE-BA0176 |
Insert to setbs_securty_face_value failed |
SE-BA0177 |
Redeemed Value of Security cannot be less than Zero |
SE-BA0178 |
Select from setms_redemption failed |
SE-BA0179 |
Failed to round the redemption value |
SE-BA0180 |
Unhandled exception in sepkss_security_rebuild.fn_rebuild_for_a_security |
SE-BA0181 |
Position goes negative for $1 |
SE-BA0182 |
Position goes positive for $1 |
SE-BA0183 |
Amount round failed for $1 |
SE-BA0184 |
Unhandled exception in $1 |
SE-BA0185 |
Failed to read deal for $1 |
SE-BA0186 |
Failed to insert into cstb_contract_exception |
SE-BA0187 |
Unhandled exception in fn_rebuild_slabs. |
SE-BA0188 |
Unable to select from setms_portfolio_master |
SE-BA0189 |
Unable to select from setb_dprp_accr_calc |
SE-BA0190 |
Unable to lock position $1 |
SE-BA0191 |
Unable to select from setm_redemption |
SE-BA0192 |
Unable to select from setm_security_master |
SE-BA0193 |
Unable to update setb_bep |
SE-BA0194 |
Unable to insert/update setb_dprp_accr_calc |
SE-BA0195 |
Unhandled exception in fn_process_calc_table |
SE-BA0196 |
Unable to calculate the tenor |
SE-BA0197 |
Unable to calculate the no. of days |
SE-BA0198 |
Unhandled exception in fn_constant_yld_dp |
SE-BA0199 |
Unhandled exception in fn_constant_yld_rp |
SE-BA0200 |
Unable to select from setm_branch_parameters |
SE-BA0201 |
SE-BA0202 |
Unable to select from setb_dprp_accr_master |
SE-BA0203 |
Unable to update setb_dprp_accr_master |
SE-BA0204 |
Unhandled exception in fn_dprp_batch_accr |
SE-BA0205 |
Unhandled exception in fn_pass_product_entries |
SE-BA0206 |
Unable to update setb_dprp_accr_log |
SE-BA0207 |
Unable to update accrual_entry_flag in setb_dprp_accr_log |
SE-BA0208 |
Unhandled exception in fn_dprp_memo_accr |
SE-BA0209 |
Unhandled exception in fn_dprp_reversals |
SE-BA0210 |
Unhandled exception in fn_accrue |
SE-BA0211 |
Unable to select from setb_bep |
SE-BA0212 |
Unhandled exception in fn_accrue_during_settle |
SE-BA0213 |
Unhandled exception in fn_acc_entry |
SE-BA0214 |
Component code not correctly set |
SE-BA0215 |
Unable to insert into setb_dprp_accr_log |
SE-BA0216 |
Unhandled exception in fn_update_accr_log |
SE-BA0217 |
Unhandled exception in fn_dprp_poswac |
SE-BA0218 |
Unhandled exception in fn_dprp_negwac |
SE-BA0219 |
Unhandled exception in fn_dprp_dmwac |
SE-BA0220 |
Unhandled exception in fn_dprp_wac_noaccr |
SE-BA0221 |
Unable to check future holding |
SE-BA0222 |
Unable to select from setb_unrel_unmatch for $1 |
SE-BA0223 |
Unhandled exception in fn_rights_settlements |
SE-BA0224 |
Unhandled exception in fn_warrants_settlements |
SE-BA0225 |
Unhandled exception in fn_bonus_settlements |
SE-BA0226 |
Unable to get current holding for position $1 |
SE-BA0227 |
Unable to select from setb_matched_deal for sell leg $1 |
SE-BA0228 |
Unable to update setb_event_log |
SE-BA0229 |
Failed in function fn_find_cum_ex |
SE-BA0230 |
Unable to break the match for $1 |
SE-BA0231 |
Unable to get Buy deal for position $1 |
SE-BA0232 |
Unable to insert into setb_matched_deal for sell leg $1 |
SE-BA0233 |
Unable to update setb_unrel_unmatch |
SE-BA0234 |
Unhandled exception in fn_drive_alpl |
SE-BA0235 |
Unhandled exception in fn_drive_dprp_accr |
SE-BA0236 |
Unhandled exception in fn_drive_fpl_accr |
SE-BA0237 |
Unhandled exception in fn_drive_fpl_memo_accr |
SE-BA0238 |
Unhandled exception in fn_drive_dprp_memo_accr |
SE-BA0239 |
Unable to update setb_dstl_master for $1 and dstl date $2 |
SE-BA0240 |
Unhandled exception in fn_reverse_alpl |
SE-BA0241 |
Unhandled exception in fn_mark_dstl_master |
SE-BA0242 |
Unable to get the Rights intrinsic value |
SE-BA0243 |
Unable to select from setb_position_ref |
SE-BA0244 |
Failed in function fn_build_event_advice |
SE-BA0245 |
Unable to get the deal details for $1 |
SE-BA0246 |
Unhandled exception in fn_rights_exercise_RELL |
SE-BA0247 |
Error while calculating P&L for Rights exercise |
SE-BA0248 |
Unable to insert into setb_event_log |
SE-BA0249 |
Unable to insert into setb_dstl_details |
SE-BA0250 |
Unable to insert into cstb_contract_event_advice |
SE-BA0251 |
Failed in function fn_msg_handoff |
SE-BA0252 |
Error while calculating P&L for Rights expiry |
SE-BA0253 |
Unhandled exception in fn_rights_expiry_RXLL |
SE-BA0254 |
SE-BA0255 |
SE-BA0256 |
ALPL is already running in the current branch |
SE-BA0257 |
Unhandled exception in Event Selection and Processing and ALPL function |
SE-BA0258 |
Unhandled exception in fn_SSSP_settlements |
SE-BA0259 |
Unhandled exception in fn_do_matching |
SE-BA0260 |
Closing sec balance not equal to settled quantity |
SE-BA0261 |
Insert to setbs_interest rate failed |
SE-BA0262 |
Unhandled exception in sepkss_security_rebuild.fn_rebuild_interest |
SE-BA0263 |
Security being traded has already expired |
SE-BA0264 |
Updation of setws_repo_rrepo_blocks failed |
SE-BA0265 |
Select from setws_repo_rrepo_blocks failed |
SE-BA0266 |
Unhandled Exception in sepks_repo_addon.fn_calculate_repo_face_value |
SE-BA0271 |
Unhandled exception in function sepkss_corpaction_msg.fn_process_notice |
SE-BA0272 |
Unhandled exception in function sepkss_corpaction_msg.fn_check_advice |
SE-BA0273 |
Unhandled exception in function sepkss_corpaction_msg.fn_handoff |
SE-BA0274 |
Error updating advice_generated field to Y |
SE-BA0275 |
Error updating advice_generated field to P |
SE-BA0276 |
Error updating internal_action_id in setbs_event_log |
SE-BA0277 |
Unable to handoff to mstbs_msg_handoff. Function sepkss_advice_utils.fn_insert_msg_handoff returned false |
SE-BA0278 |
Error updating statement date/number fields in setms_portfolio_master |
SE-BA0279 |
Unhandled exception in function fn_statements_handoff |
SE-BA0280 |
Matched buy deals have not settled. DSTL will not be done for $1 |
CS-CF0001 |
Unhandled exception in fn_create_cash_flow - version 1 |
CS-CF0002 |
Cstbs_event_due_dates not populated |
CS-CF0003 |
Unhandled exception in fn_create_cash_flow - version 2 |
CS-CF0004 |
Unhandled exception in fn_restore_cash_flow |
CS-CF0005 |
Unhandled exception in fn_authorize_cash_flow |
CS-CF0006 |
Unhandled exception in fn_settle_cash_flow |
CS-CF0007 |
Unhandled exception in fn_process_charges |
CS-CF0008 |
Unhandled exception in fn_tax_charges |
CS-CF0009 |
Unhandled exception in fn_is_referral |
CS-CF0010 |
Unhandled exception in fn_process_settlements_lists |
CS-CF0011 |
Unhandled exception in fn_upd_amt_due |
CS-CF0012 |
Unhandled exception in fn_upd_amt_paid |
CS-CF0013 |
Unhandled exception in fn_backup_cash_flow |
SE-CF0001 |
Unhandled exception in fn_cash_flow_redemption |
SE-CF0002 |
Unhandled exception in fn_cash_flow_dividends |
SE-CF0003 |
Unhandled exception in fn_cash_flow_coupons |
SE-CF0004 |
Unhandled exception in fn_populate_amt_due |
SE-CF0005 |
Unhandled exception in fn_get_sett_acc |
SE-BOD001 |
Unhandled exception in function sepkss_security_batch.fn_process_security_batch wile processing security $1 |
SE-BOD002 |
Unhandled exception in function sepkss_security_batch.fn_process_security_batch |
SE-BOD003 |
Unhandled exception in function fn_update of sepkss_security_batch |
SE-BOD040 |
Failed to update setb_caevent_tearoff_log |
SE-BOD041 |
Failed to lock cstb_contract |
SE-BOD042 |
Failed to update setm_corp_actions_due with auto deal reference |
SE-BOD043 |
When Others of fn_right_tearoff |
SE-BOD044 |
Error while selecting product for building auto deal |
SE-BOD045 |
When Others of fn_right_pfolio_processing |
SE-BOD046 |
No data found in setm_combination_product |
SE-BOD047 |
Failed to insert into setb_unrel_unmatch |
SE-BOD048 |
Unhandled exception in fn_deal_detail |
SE-BOD049 |
Unhandled exception in fn_deal_master |
SE-BOD050 |
Failed to update setb_caevent_expiry_log |
SE-BOD051 |
Unhandled exception in fn_rights_expiry |
SE-BOD052 |
Are you sure you want start Corp Action Batch processing? |
SE-BOD053 |
Unhandled exception encountered while running Batch program |
SE-BOD074 |
When Others of fn_populate_coupon_eod |
SE-BOD075 |
When Others of fn_populate_cash_dvnd_eod |
Error Code |
Message |
SE-DO0000 |
For Securities Deal On-line error code format is SE-DONNNN, where NNNN is a running four-digit number with left padded zeros. Please insert the Error Codes you want and reserve it. The Error Message cannot be greater than 255 characters. Please do not use SE-DO0000 as a Error Code. |
SE-DO0001 |
Product code should be entered |
SE-DO0002 |
Unable to generate reference number |
SE-DO0003 |
Trade date cannot be after today |
SE-DO0004 |
Trade date cannot be after interest date |
SE-DO0005 |
Interest date cannot be after delivery settlement date |
SE-DO0006 |
Delivery settlement date cannot be before trade date |
SE-DO0007 |
Security code should be entered |
SE-DO0008 |
Market code should be entered |
SE-DO0009 |
Deal quantity should be entered |
SE-DO0010 |
Input price should be entered |
SE-DO0011 |
Trade date should be entered |
SE-DO0012 |
Delivery settlement date should be entered |
SE-DO0013 |
Interest date should be entered |
SE-DO0014 |
SE-DO0015 |
Broker code should be entered |
SE-DO0016 |
Security series should be entered |
SE-DO0017 |
Payment date should be entered |
SE-DO0018 |
Spot date should be entered |
SE-DO0019 |
Spot price should be entered |
SE-DO0020 |
Payment Currency should be entered |
SE-DO0021 |
Interest days should be entered |
SE-DO0022 |
Counterparty should be entered |
SE-DO0023 |
SK location should be entered |
SE-DO0024 |
Portfolio should be entered |
SE-DO0025 |
User reference should be entered |
SE-DO0026 |
Dealer code should be entered |
SE-DO0027 |
Money settlement date should be entered |
SE-DO0028 |
SK Account should be entered |
SE-DO0029 |
Actual money settlement date should be entered |
SE-DO0030 |
Overrides need to be confirmed for Authorization |
SE-DO0031 |
Do you want to undo the changes you have made? |
SE-DO0032 |
Do you want to delete the contract? |
SE-DO0033 |
Do you want to undo the last unauthorized changes? |
SE-DO0034 |
Authorized contract can not be deleted |
SE-DO0035 |
Contract successfully deleted |
SE-DO0036 |
User Reference Number should be unique |
SE-DO0037 |
Liquidate Failed |
SE-DO0038 |
Rollover Failed |
SE-DO0039 |
Failed to generate new version, Reversal of contract Failed |
SE-DO0040 |
Failed to copy the contract |
SE-DO0041 |
Failed to delete the contract |
SE-DO0042 |
SE-DO0043 |
Do you want to close the contract? |
SE-DO0044 |
Contract successfully closed |
SE-DO0045 |
Failed to CLOSE the contract |
SE-DO0046 |
Unauthorised contract can not be modified |
SE-DO0048 |
Contract will be put on hold |
SE-DO0053 |
Failed in contract event log processing |
SE-DO0054 |
Failed to unlock the contract |
SE-DO0055 |
User Id should be same as the maker Id |
SE-DO0056 |
unauthorized record can not be processed |
SE-DO0057 |
DSTL date should be entered |
SE-DO0058 |
New DSTL date should not be before the existing DSTL date |
SE-DO0059 |
Rollover completed successfully |
SE-DO0060 |
Failed to process the deal leg records |
SE-DO0061 |
Security ID does not match, Please reenter the security ID |
SE-DO0062 |
Input price does not match, please reenter the input price |
SE-DO0063 |
Trade date does not match, please re enter the trade date |
SE-DO0064 |
deal settlement date does not match, please re enter the deal settlement date |
SE-DO0065 |
Deal units are not matching, please reenter the deal units |
SE-DO0066 |
Portfolio Ids do not match, Please reenter the portfolio ID |
SE-DO0067 |
Money settlement date does not match, please reenter the money settlement date |
SE-DO0068 |
Failed to validate the dates |
SE-DO0069 |
$1, $2 $3 is $4 holiday. Continue? |
SE-DO0070 |
Trade date is earlier than product start date |
SE-DO0071 |
Deal Settlement date is earlier than product start date |
SE-DO0072 |
Money Settlement date is earlier than product start date |
SE-DO0073 |
Trade date should not be after product end date |
SE-DO0074 |
Deal Settlement date should not be after product end date |
SE-DO0075 |
Money Settlement date should not be after product end date |
SE-DO0076 |
Trade Date cannot be after Today's System Date |
SE-DO0077 |
Trade Date cannot be after the Deal Settlement Date |
SE-DO0078 |
Trade Date is same as The Settlement Date |
SE-DO0079 |
Money Settlement Date cannot be earlier than the Trade Date |
SE-DO0080 |
Money Settlement Date cannot be later than Settlement Date |
SE-DO0081 |
Actual Settlement Date cannot be earlier than Money Settlement Date |
SE-DO0082 |
Actual Settlement Date cannot be earlier than the Deal Settlement Date |
SE-DO0083 |
Interest Value Date cannot be earlier than Trade Date |
SE-DO0084 |
Interest Value Date cannot be after the Settlement Date |
SE-DO0085 |
Trade Date is earlier than Today's System Date |
SE-DO0086 |
Settlement Date is earlier than Today's System Date |
SE-DO0087 |
Deal input price exceeds market price by $1, Continue? |
SE-DO0088 |
Deal input price exceeds market price by $1%, variance Exception limit exceeded. |
SE-DO0089 |
Deal is already settled. Settlement date can not be extended. |
SE-DO0090 |
Portfolio Id for Buy leg and that for sell leg should not be same. |
SE-DO0091 |
Counterparty for Buy leg and that for sell leg should not be same. |
SE-DO0092 |
Money Settlement for $ is already completed |
SE-DO0093 |
Failed in event processing, $1 failed |
SE-DO0094 |
Checker ID can not be same as the Maker ID |
SE-DO0095 |
Contract saved as TEMPLATE |
SE-DO0096 |
Contract saved |
SE-DO0097 |
Matched units can not be null |
SE-DO0098 |
Contract already liquidated |
SE-DO0100 |
Deal Successfully Saved |
SE-DO0131 |
Failed to get the price components |
SE-DO0132 |
Spot date can not be earlier than Trade date |
SE-DO0133 |
Money settlement is already done |
SE-DO0134 |
Deal settlement is already done |
SE-DO0135 |
Could not retrieve spot price for the given face value, please input spot price |
SE-DO0136 |
Limits are not maintained |
SE-DO0137 |
Combination of the entered details is not valid |
SE-DO0138 |
Please enter the mandatory fields |
SE-DO0139 |
Money Settlement date is earlier than today |
SE-DO0140 |
New Deal Settlement Date is greater than one of the sell leg Deal Settlement Dates matched to $1 |
SE-DO0141 |
New Deal Settlement Date is earlier than one of the buy leg Deal Settlement Dates matched to $1 |
SE-DO0142 |
Failed to compare Deal settlement dates for matched deals |
SE-DO0143 |
Failed in $1 pickup |
SE-DO0144 |
Please enter the narrative type |
SE-DO0145 |
Failed to generate Position Reference Number |
SE-DO0146 |
Contract reversed. |
SE-DO0147 |
Do you want to reverse the contract? |
SE-DO0148 |
Failed to select the record |
SE-DO0149 |
Selected record has changed, please reselect |
SE-DO0150 |
Do you want to re-pickup the subsystems? |
SE-DO0151 |
Number of units entered is not in multiples of minimum tradable security units |
SE-DO0152 |
DSTL date is earlier than start of trading date for the security |
SE-DO0153 |
DSTL date is not earlier than the security redemption date |
SE-DO0154 |
Settlement SKL is mandatory |
SE-DO0155 |
Payment Currency - Security Currency ratio is mandatory |
SE-DO0156 |
Failed to authorize the contract |
SE-DO0157 |
Failed to validate the rekey fields |
SE-DO158 |
input quantity has exceeded maximum limit |
SE-DO0159 |
Failed to default the product details |
SE-DO0160 |
Spot date should be less than Deal Settlement date |
SE-DO0161 |
Failed to default price components |
SE-DO0162 |
Deal is already settled. Can not continue! |
SE-DO0163 |
Failed to save the contract |
SE-DO0164 |
Failed to reserve record for liquidation |
SE-DO0165 |
Zero units are available for release |
SE-DO0166 |
Failed to maintain the template |
SE-DO0167 |
Contract reference number can not be null, Please contact support |
SE-DO0168 |
Failed to get the counter product details for deal product |
SE-DO0169 |
Please input rights exercise details, before proceeding further |
SE-DO0170 |
Please enter the Parties details for leg with reference number $1 |
SE-DO0171 |
Failed to initialize the parameters |
SE-DO0172 |
Failed in Holiday checks |
SE-DO0173 |
Failed to get the resultant security code |
SE-DO0174 |
Deal quantity can not exceed the maximum allowed quantity for exercise |
SE-DO0175 |
Trade Date validations failed |
SE-DO0176 |
Trade date is not between start of exercise date and the end of exercise date |
SE-DO0177 |
Deal settlement date can not be greater than the redemption date/expiry date of security |
SE-DO0178 |
Failed to validate the DSTL date |
SE-DO0179 |
Failed to update rows for the deal |
SE-DO0180 |
Failed in rights exercise processing |
SE-DO0181 |
Deal quantity should be greater than 0 |
SE-DO0182 |
From leg position can not be same as the to leg position |
SE-DO0183 |
This position has $1 balance |
SE-DO0184 |
Failed to validate the deal |
SE-DO0185 |
Error codes could not be retrieved correctly |
SE-DO0186 |
SE-DO0187 |
Failed to duplicate the overrides |
SE-DO0188 |
Reversed contract can not be unlocked |
SE-DO0189 |
Money Settlement can not be done for bank leg |
SE-DO0190 |
Interest Value Date should be between $1 and $2 |
SE-DO0191 |
Variance is not maintained for the security product in security currency |
SE-DO0192 |
MIS maintenance is not done for security/portfolio |
SE-DO0193 |
Failed to get security trading dates |
SE-DO0194 |
Incorrect format for SWIFT address |
SE-DO0195 |
First line of address is mandatory |
SE-DO0196 |
Medium is mandatory for walk-in customer |
SE-DO0197 |
Deal quantity should be greater than the minimum allowed quantity for exercise |
SE-DO0198 |
Counterparty confirmation is not allowed for this deal. |
SE-CALC01 |
Divide by zero condition. Cannot calculate yield. |
SE-CALC02 |
Unhandled exception in function sepkss_calc.fn_tbill_pricetoyield. |
SE-CALC03 |
Divide by zero condition. Cannot calculate price. |
SE-CALC04 |
Unhandled exception in function sepkss_calc.fn_tbill_yieldtoprice. |
SE-CALC05 |
Error condition while calculating Present Value of cash flow(s). |
SE-CALC06 |
Unhandled exception in function sepkss_calc.fn_bond_pricetoyield. |
SE-CALC07 |
Unhandled exception in function sepkss_calc.fn_bond_yieldtoprice |
SE-CALC08 |
Unhandled exception in function sepkss_calc.fn_tbill_calc |
SE-CALC09 |
Function(fn_tbill_calc) does not understand mode $1 |
SE-CALC10 |
Function(fn_tbill_calc) cannot determine which is to be calculated (Yield or Price) |
SE-ONL100 |
Error during Netcons Processing |
SE-ONL101 |
Error processing Parties |
SE-ONL102 |
Error processing of Advices |
SE-ONL103 |
Error processing Subsystems |
SE-ONL104 |
Error updating of Exchange Rates in Settlements |
SE-ONL105 |
Error retrieving Deal Amount Tags |
SE-ONL106 |
Error creating Deal Amount Tag list |
SE-ONL107 |
Error retrieving Deal Detail |
SE-ONL108 |
Error retrieving Deal Master |
SE-ONL109 |
Settlement CCY for a Netcons component different from Payment CCY |
SE-ONL110 |
Error Processing Module Components during Settlements pickup |
SE-ONL111 |
Error Processing Module Components for Net consideration |
SE-ONL112 |
Error Processing Interest Components for Net consideration |
SE-ONL113 |
Error Processing Tax Components under Net consideration |
SE-ONL114 |
Error processing Parties. CIF record missing |
SE-ONL115 |
Error inserting into Unrel - Unmatch Table |
SE-ONL116 |
Error processing exposures |
SE-ONL117 |
Error processing clean risk |
SE-ONL118 |
Error inserting into Securities Event Log |
SE-ONL119 |
Error inserting Core Contract control table |
SE-ONL120 |
Error updating Core Contract control table |
SE-ONL121 |
Error inserting Core Contract event log table |
SE-ONL122 |
Error retrieving Spot Price |
SE-ONL123 |
Error processing event - $1 |
SE-ONL124 |
Error authorizing event - $1 |
SE-ONL125 |
Error retrieving data from Core Contract control table |
SE-ONL126 |
Error Deleting contract |
SE-ONL127 |
Error inserting Deal Master |
SE-ONL128 |
Error inserting Deal Detail |
SE-ONL129 |
Error inserting into Deal Matching tables |
SE-ONL130 |
Error copying contract |
SE-ONL131 |
Error splitting price |
SE-ONL132 |
Error retrieving Face Value |
SE-ONL133 |
Error retrieving Market Price |
SE-ONL134 |
Error handing off messages |
SE-ONL135 |
Error retrieving DCN |
SE-ONL136 |
DEAL_NOMINALAMT not defined in product accounting entry |
SE-ONL137 |
Active or Unauthorized Reversed/Cancelled Sell Legs are linked to this buy leg. Only completely unmatched buy legs or buy legs linked to authorised reversed/cancelled sell legs can be reversed |
SE-ONL138 |
Error during updation of blocked balances |
SE-ONL139 |
Portfolio cannot go short. Current position insufficient |
SE-ONL140 |
Holdings insufficient to be blocked |
SE-ONL141 |
Error verifying available balance for Portfolio |
SE-ONL142 |
MSTL possible for only Customer - Buy/Sell legs |
SE-ONL143 |
Failed in Cash flow processing |
SE-ONL144 |
Failed to populate the amount due records in cash flow |
SE-ONL145 |
Failed in creating cash flow |
SE-ONL146 |
SD-LM-00001 |
The Issuer Limits details are incomplete. Complete/Delete the Issuer Limits details. |
SD-LM-00002 |
The Line Code is not a Limits Template |
SD-LM-00003 |
The Line Code is not entered |
SD-LM-00004 |
The Liability is not entered |
SD-LM-00005 |
The Line Start Date cannot be later than the Line Expiry Date |
SD-LM-00006 |
The Last Available Date cannot be later than the Line Expiry Date |
SD-LM-00007 |
The Line Currency is not entered |
SD-LM-00008 |
This Tenor has been maintained for the Limit |
SD-LM-00009 |
The Tenor details are incomplete. Complete/Delete the Tenor details |
SD-LM-00010 |
The Products Allowed details are incomplete. Complete/Delete the Products Allowed details |
SD-LM-00011 |
The Branches Allowed details are incomplete. Complete/Delete the Branches Allowed details |
SD-LM-00012 |
The Last Available Date cannot be less than the Line Start Date |
SD-LM-00013 |
The Customers Allowed details are incomplete. Complete/Delete the Customers Allowed details |
SD-LM-00014 |
The Tenor Limit Amount exceeds the Line Limit Amount |
SD-LM-00015 |
The Sub Line Tenor Limit Amount cannot be greater than the next higher Main Line Tenor Limit Amount. $1 - $2 |
SD-LM-00016 |
The Sub Line Tenor cannot be greater than Maximum Main Line Tenor. $1 Days |
SD-LM-00017 |
There are no Tenors specified for the Main Line |
SD-LM-00018 |
The Line Code is Limits Template. Details will be copied from template. Continue? |
SD-LM-00019 |
The Sub Line Limit cannot exceed the Main Line Limit. $1-$2 |
SD-LM-00020 |
The Main Line Limit cannot be less than any of its Sub Line Limit. $1 -$2 |
SD-LM-00021 |
The Main Line Tenor cannot be Less than the Minimum Tenor of any Sub Lines reporting to it. - $1 Days |
SD-LM-00022 |
The Main Line Tenor Limit Amount cannot be less than the next lower Sub Line Tenor Limit Amount. $1 - $2 |
SD-LM-00023 |
The Limits Copy could not be completed. |
SD-LM-00024 |
Blank spaces cannot be a part of this field |
SD-LM-00025 |
The Line Code should have a nine characters |
SD-LM-00026 |
The Tenor Mnemonic is not entered. |
SD-LM-00027 |
The Limit is not entered. |
SD-LM-00028 |
The Collateral Start Date cannot be later than the Collateral Expiry Date |
SD-LM-00029 |
The Margin computed is not between 0 and 100. |
SD-LM-00030 |
The Collateral Currency is not entered. |
SD-LM-00031 |
The Collateral Type is not entered. |
SD-LM-00032 |
The Collateral Review Date cannot be later than the Collateral Expiry Date |
SD-LM-00033 |
The Collateral Review Date cannot be earlier than Collateral Start Date |
SD-LM-00034 |
The Expiry Date cannot be earlier than Start Date. |
SD-LM-00035 |
The Security Code is not entered. |
SD-LM-00036 |
The Security Type is not entered. |
SD-LM-00037 |
The Currency is not entered. |
SD-LM-00038 |
The Market Price Details are incomplete. Complete / Delete the Market Price Details |
SD-LM-00039 |
The Line Code is not entered. |
SD-LM-00040 |
The computed exposure is not between 1 and 100. |
SD-LM-00041 |
There are Active Sub Lines reporting to this Main Line. Main Line cannot be closed. |
SD-LM-00042 |
The Last Price Change Date cannot be greater than Branch Date |
SD-LM-00043 |
The Security Code is not entered for the MVBC |
SD-LM-00044 |
The Price Code is not entered for the MVBC |
SD-LM-00045 |
The Number Of Units is not entered for the MVBC |
SD-LM-00046 |
The Collateral Ccy is not entered for the Collateral |
SD-LM-00047 |
Security Code has not been entered |
SD-LM-00048 |
The Issuer Exposure Details are incomplete. Complete / Delete the Issuer Exposure Details |
SD-LM-00049 |
The Start Date cannot be greater than the Branch Date |
SD-LM-00050 |
The Last Price Change Date cannot be earlier than Start Date |
SD-LM-00051 |
The Expiry Date cannot be earlier than Branch Date. |
SD-LM-00052 |
The Last Price Change Date cannot later than Expiry Date |
SD-LM-00053 |
The Description is not entered. |
SD-LM-00054 |
The Face Value is not entered. |
SD-LM-00055 |
The Limit Contribution cannot be greater than the Cap Amount. |
SD-LM-00056 |
Report date should be greater than the date today |
SD-LM-00057 |
The Total Issuer Exposure should be greater than 100 %. |
SD-LM-00058 |
Collateral exists with the Issuer Code. Record cannot be closed. |
SD-LM-00059 |
Securities exist with the Issuer Code. Record cannot be closed. |
SD-LM-00060 |
There are Collateral linked to this Limit. Record cannot be closed. |
SD-LM-00061 |
There are Collateral linked to this Security. Record cannot be closed. |
SD-LM-00062 |
There are Collateral linked to this Price Code. Record cannot be closed. |
SD-LM-00063 |
There are Collateral linked to this Collateral Type. Record cannot be deleted |
SD-LM-00064 |
This Facility is not available at this Branch |
SD-LM-00065 |
No Details exist for the Reference Number. |
SD-LM-00066 |
Customer Clean Risk Limit cannot be greater than Liability Clean Risk Limit |
SD-LM-00067 |
Customer Clean Risk Limit cannot be greater than Overall Limit |
SD-LM-00068 |
Liability Clean Risk Limit cannot be greater than Overall Limit |
SD-LM-00069 |
Limit Currency is not Entered |
SD-LM-00070 |
Overall Limit is not Entered |
SD-LM-00071 |
Liability Clean Risk Limit is not Entered |
SD-LM-00100 |
Line Not Authorised |
SD-LM-00101 |
Line Closed |
SD-LM-00102 |
Line Not Found |
SD-LM-00103 |
Invalid Customer ID |
SD-LM-00104 |
Liability ID. Not Specified |
SD-LM-00105 |
Account ID. Not specified |
SD-LM-00106 |
Reference Id not specified |
SD-LM-00107 |
Amount tag not specified |
SD-LM-00108 |
Amount not specified |
SD-LM-00109 |
Currency not specified |
SD-LM-00110 |
Branch not specified |
SD-LM-00111 |
Line $1 - Amount exceeds Limit for specified tenor by $2 |
SD-LM-00112 |
Line $1 - Amount exceeds all available tenor limits by $2 |
SD-LM-00113 |
Line $1 - Amount exceeds line limit. Limit = $3 $2. Utilisation = $4 $2. Overdraft = $5 $2 |
SD-LM-00114 |
Main Line $1 - Amount exceeds Main line limit amount. Limit = $3 $2. Utilisation = $4 $2. Overdraft = $5 $2 |
SD-LM-00115 |
Line has matured |
SD-LM-00116 |
Line not available |
SD-LM-00117 |
Amount exceeds limit for liability $1. Limit = $3 $2 Utilisation = $4 $2 Overdraft = $5 $2 |
SD-LM-00200 |
Clean risk limit exceeded for Customer $1 On $2. Limit = $4 $3 , Utilisation = $5 $3, Excess = $6 $3 |
SD-LM-00201 |
Clean risk limit exceeded for Liability $1 On $2. Limit = $4 $3 , Utilisation = $5 $3, Excess = $6 $3 |
SD-LM-00202 |
Date input is a holiday. Do you want to continue? |
SD-LM-00203 |
Customer clean risk exceeds for customer $1 for date $2 for currency $3. The limit is $4. The actual amount is $5 and the difference is $6 |
SD-LM-00204 |
Liability clean risk exceeds for customer $1 for date $2 for currency $3. The limit is $4. The actual amount is $5 and the difference is $6 |
SD-LM-99998 |
Limits: Node $1 Unavailable. Utilization will be updated later. |
SD-LM-99999 |
Limits Service - Unexpected Error - $1 |
Error Code |
Message |
TA-CL002 |
A class named $1 is already maintained |
TA-CL003 |
Class details Saved |
TA-CL004 |
Record successfully deleted |
TA-CL005 |
The Record is already closed |
TA-CL006 |
Cannot maintain amount tags for this component. Cannot authorize |
TA-CL007 |
Do you want to delink the Tax Component? |
CS-CL1001 |
This class code already exists |
CS-CL1002 |
Please enter the class code |
CS-CL1003 |
Do you want to print accounting entries class details for all modules? |
CS-CL1004 |
Module ID does not match with the Class Code |
CS-CL1005 |
Duplicate Class Code encountered. Please enter the class code again |
CF-CL0001 |
Currency or rate missing |
CF-CL0002 |
Max. values should be lesser or equal to Min. values |
CF-CL0003 |
For Fixed interest rate, Default rate is mandatory and Spread should not be input |
CF-CL0004 |
For Floating interest rate, Spread is mandatory and Default Rate should be null |
CF-CL0005 |
Default Rate Code and Default Tenor mandatory if Rate type is Floating rate |
CF-CO0001 |
Component is of floating rate type. Tenor code must be entered |
CF-CO0002 |
Interest Calculation method must be entered |
CF-CO0003 |
Effective Rate cannot be null |
CF-CL0006 |
Changing the Rate type will delete all the rate maintenance. Do you want to go ahead? |
CF-CL0007 |
There must be at least one component or relevant type |
CF-CL0008 |
The component is linked to a product. Cannot modify or close the record |
CF-CL0009 |
This component has been authorized. Only redefault is allowed. |
CS-PR0001 |
There are no authorized class codes |
CS-PR0002 |
There are no more accounting roles |
CS-PR0003 |
Mandatory field (Class Code) is null |
CS-PR0004 |
Mandatory fields (Accounting Role/Account head) are null |
CS-PR0005 |
There are no more events |
CS-PR0006 |
Mandatory fields (Accounting Role/Amount Tag/Txn code) are null |
CS-PR0007 |
Mandatory field (Advice Name) is null |
CS-PR0008 |
There are no more advices |
CS-PR0009 |
This is not the right button for moving the selected records |
CS-PR0010 |
Cannot move out of the block as some records are selected |
CS-PR0011 |
Already in the last record |
CS-PR0012 |
Already in the first record |
CS-PR0013 |
Cannot create a new component as all the authorized class codes have already been used |
CS-PR0014 |
All the other authorized class codes have already been used |
CS-PR0015 |
Mandatory field (Scheme) is null |
CS-PR0016 |
Mandatory field (Component) is null |
CS-PR0017 |
There are no authorized tax schemes |
CS-PR0018 |
Product Preferences will have to be redefined. Proceed? |
CS-PR0019 |
Mandatory field (Rate Type) is null |
CS-PR0020 |
Format is not correct. The correct format is… |
CS-PR0021 |
Customer ID must be specified |
CS-PR0022 |
Security ID must be specified |
CS-PR0023 |
Portfolio ID must be specified |
CS-PR0024 |
The Scheme has been authorized. Only redefault is allowed. |
CS-PR0025 |
Mandatory Field (Default Rate Code) is null |
CS-PR0026 |
Mandatory Field (Default Rule) is null |
CS-PR0027 |
Mandatory Fields (Rule/Settlement Ccy) are null |
CS-PR0028 |
The Amount Tag $1 does not have corresponding components defined |
CS-PR0029 |
There are no details to be maintained for Customer Portfolio |
CS-PR0030 |
Mandatory Field ($1) is null |
CS-PR0031 |
Mandatory Field ( Product Code ) is null |
CF-CL0010 |
Default Rate should be within the Maximum and Minimum Rate specified |
CF-CL0011 |
Floating rate type cannot be null when rate type is Floating |
CF-CL0012 |
This class is linked to a product. Cannot close the class. |
CF-CL0013 |
No rates maintained for this class code. Proceed? |
CF-CL0014 |
Event for association, Basis Amount tag and Amount Category are mandatory |
CF-CL0015 |
For module SS, Basis amount category should be Normal |
CF-CL0016 |
For module other than SS, Basis amount category should be either ‘Expected’ or ‘Overdue’ |
CF-CO0004 |
The value entered must be in the format $1 |
CF-CO0005 |
Spread cannot be zero |
CF-CO0006 |
Rate cannot be zero |
CF-CO0007 |
Floor cannot be zero |
CF-CO0008 |
Ceiling cannot be zero |
Error Code |
Message |
SE-PO0010 |
Reference No. could not be generated |
SE-PO0001 |
Authorizer cannot be the same as the Maker |
SE-PO0001 |
SE-PO0002 |
Contract Reference Number does not match |
SE-PO0002 |
SE-PO0003 |
Customer ID does not match |
SE-PO0003 |
SE-PO0004 |
Currency Code does not match |
SE-PO0004 |
SE-PO0005 |
Overrides not confirmed |
SE-PO0005 |
SE-PO0010 |
SE-PO0011 |
Failed while $1 into Change Log table |
SE-PO0011 |
SE-PO0012 |
Safe Keeping Location to Account mapping already exists |
SE-PO0014 |
SE-PO0016 |
Security ‘Allowed’ flag can't be changed if Security ID is null |
SE-PO0017 |
Contract was input by $1. Cannot be deleted |
SE-PO0018 |
Cannot delete a once authorised record |
SE-PO0019 |
SE-PO0020 |
Are you sure you want to close the contract |
SE-PO0021 |
User Reference No. already exists |
SE-PO0023 |
Input Counterparty |
SE-PO0024 |
Input Currency |
SE-PO0025 |
Enter the Product Code |
SE-PO0026 |
Safe Keeping Location to Account mapping not maintained for this portfolio |
SE-PO0027 |
Contract Reference Number does not exist for this portfolio |
SE-PO0029 |
Contract shall be put on HOLD status |
SE-PO0032 |
Pickup failed |
SE-PO0033 |
Unauthorized record cannot be unlocked |
SE-PO0034 |
Unauthorized record cannot be closed |
SE-PO0035 |
Failed to copy the portfolio - security restrictions |
SE-PO0036 |
Referral Failed |
SE-PO0037 |
Unauthorized record cannot be reopened |
SE-PO0038 |
Contract put on hold successfully |
SE-PO0041 |
For Bank Portfolio and WAC costing method, ‘Accrue Premium’ flag should have the same value as that of ‘Accrue Discount’ flag |
SE-PO0050 |
SE-PO0051 |
Location ID cannot be deleted as it is in use |
SE-PO0052 |
For WAC Costing Method, Redemption Premium is not allowed |
SE-PO0053 |
For Non Accrual or Cash Asset Accounting Basis, Premium Accrual and Discount Accrual is not allowed |
SE-PO0054 |
For Accrual Asset Accounting Basis, Premium Accrual or Discount Accrual must be chosen |
SE-PO0055 |
Safe Keeping Locations are not defined. Proceed? |
SE-PO0056 |
Security Restrictions screen is not visited. Proceed? |
SE-PO0057 |
Role to Head mapping is not defined. Proceed? |
SE-PO0058 |
Portfolio ID is not unique |
SE-PO0059 |
Revaluation of unsettled positions is not allowed without the revaluation of settled positions |
SE-PO0060 |
Withholding Tax Accrual is not without Interest Accrual |
SE-PO0061 |
Record successfully Closed |
SE-PO0062 |
Record successfully Reopened |
SE-PO0063 |
Mandatory Fields (Security Product/Role To Head Class) are null |
SE-PO0064 |
Mandatory Fields (Security ID/Role To Head Class) are null |
SE-PO0065 |
Mandatory Fields (SK Location/SK Location Account) are null |
SE-PO0066 |
Customer Account needs to be reselected. Proceed? |
SE-PO0067 |
Customer Branch and Customer Account need to be reselected. Proceed? |
SE-PO0068 |
Closure not allowed as live contracts are present |
SE-PO0069 |
Failed to open a new record |
SE-PO0070 |
Failed to copy the record |
SE-PO0071 |
Failed to delete the record |
SE-PO0072 |
Failed to close the record |
SE-PO0073 |
Failed to unlock the record |
SE-PO0074 |
Failed to reopen the record |
SE-PO0075 |
Failed to authorize the record |
SE-PO0076 |
Failed to copy the Product Details |
SE-PO0078 |
Record cannot be Modified after the Event Date |
SE-PO0079 |
Record cannot be Closed after the Event Date |
SE-PO0080 |
Record cannot be Reopened after the Event Date |
SE-PO0081 |
Failed to Save the Record |
Error Code |
Message |
SE-BTCH-002 |
Failed in building array for a function |
SE-BTCH-003 |
Failed in population of branch batch queue |
SE-BTCH-004 |
Failed in batch processing for a day |
SE-BTCH-005 |
Failed in processing task |
SE-BTCH-006 |
Failed in unmarking end of transaction input |
SE-CFLP-001 |
Cannot process Coupon Flipping |
SE-CFLP-002 |
Cannot process Position |
SE-CFLP-003 |
Cannot populate Securities Movements |
SE-CPOP-001 |
Failed to populate Coupon for branches |
SE-CPOP-002 |
Failed to populate Coupon |
SE-CPOP-003 |
SK Account Currency different from Issuer payment Currency |
SE-CPOP-004 |
Failed in processing tax due |
SE-CPOP-005 |
Failed in charge processing |
SE-CPOP-006 |
Failed in processing transaction level tax |
SE-CPOP-007 |
Failed in processing Settlements |
SE-CPOP-008 |
Failed in inserting coupon due record |
SE-CPOP-009 |
Failed in logging exception when populating coupon |
SE-CPOP-010 |
Failed in populating coupon for branches |
SE-CPOP-021 |
Next working date cannot be null |
SE-CPOP-022 |
not confirmed |
SE-CPOP-023 |
Incorrect number of records returned during coupon population |
SE-CPOP-024 |
Receive Account could not be got |
SE-CPOP-025 |
Pay Account could not be got |
SE-CPOP-026 |
Account currency is not the same as Issuer payment currency |
SE-CPOP-027 |
Portfolio Account details could not be got |
SE-CPOP-028 |
SE-CPRC-001 |
Could not process coupon for branches |
SE-CPRC-002 |
Could not process Coupon event |
SE-CPRC-003 |
Could not get sub system flags during coupon processing |
SE-CPRC-004 |
Error while processing coupon |
SE-CPRC-005 |
Failed while processing Tax |
SE-CPRC-006 |
Failed while processing charge |
SE-CPRC-007 |
Failed while processing Transaction level tax |
SE-CPRC-008 |
Failed in Settlements processing |
SE-DATE-001 |
Failed in computing day count |
SE-DATE-002 |
Failed in getting denominator |
SE-DATE-003 |
Failed in computing the number of days |
SE-DATE-004 |
Failed to get next leap date |
SE-DATE-005 |
Failed to get next periodic date |
SE-DATE-006 |
Failed in add months function |
SE-DATE-007 |
SE-DATE-008 |
Failed in calculating the months between two dates |
SE-DATE-051 |
Failed in getting the date in the correct format |
SE-DATE-052 |
Could not convert the date to the correct format |
SE-DATE-053 |
Failed in check for leap year |
SE-DATE-054 |
SE-DATE-055 |
SE-DATE-056 |
SE-DATE-057 |
SE-DATE-058 |
SE-DPOP-001 |
Failed in populating Dividend for branches |
SE-DPOP-002 |
Failed in inserting Dividend record |
SE-DPOP-003 |
SE-DPOP-004 |
Failed in Tax processing for dividend |
SE-DPOP-005 |
Failed in Charge processing for dividend |
SE-DPOP-006 |
Failed in Transaction Tax processing for dividend |
SE-DPOP-007 |
Failed in Settlements processing for dividend |
SE-DPOP-008 |
Failed in insert of dividend record |
SE-DPOP-009 |
Failed in logging exception when populating dividend |
SE-DPOP-010 |
SE-DPOP-021 |
Failed to get next working date when dividend population |
SE-DPOP-022 |
SE-DPOP-023 |
Incorrect number of records returned during dividend population |
SE-DPOP-024 |
Receive Account could not be got when populating dividend |
SE-DPOP-025 |
Pay Account could not be got when populating dividend |
SE-DPOP-026 |
SE-DPOP-027 |
SE-DPOP-028 |
SE-DPRC-001 |
Failed in processing dividend for branches |
SE-DPRC-002 |
Failed in processing dividend event |
SE-DPRC-003 |
Failed to set subsystem flags during dividend processing |
SE-DPRC-004 |
Failed in processing amount due during dividend processing |
SE-DPRC-005 |
SE-DPRC-006 |
SE-DPRC-007 |
SE-DPRC-008 |
SE-DSRV-001 |
SE-IAC0-001 |
Could not build queue array during interest accrual |
SE-IAC0-002 |
Failed to get periodic accrual date |
SE-IAC0-003 |
Failed in adjustment of accrual |
SE-IAC0-004 |
Failed in period accrual function |
SE-IAC0-005 |
Failed in coupon date accrual |
SE-IAC0-006 |
Failed in deleting accrual queues |
SE-IAC1-001 |
Failed in accrual for a position |
SE-IAC1-002 |
Failed in computing quantity for accrual |
SE-IAC1-003 |
Failed in computing interest balances |
SE-IAC1-004 |
Failed in obtaining interest history |
SE-IAC1-005 |
Failed in computing interest amounts |
SE-IAC1-006 |
Failed in computing tax balances |
SE-IAC1-007 |
Failed in obtaining tax history |
SE-IAC1-008 |
Failed in computing tax amounts |
SE-IAC1-009 |
Failed in passing portfolio entries during interest accrual |
SE-IAC2-001 |
Failed in obtaining previous interest amounts |
SE-IAC2-002 |
Failed in obtaining previous tax amounts |
SE-IAC2-003 |
Failed in computing net interest amounts during accrual |
SE-IAC2-004 |
Failed in computing net tax amounts during interest accrual |
SE-IAC2-005 |
Failed in building interest entry lists |
SE-IAC2-006 |
Failed in building tax entry lists |
SE-IAC2-007 |
Failed in processing amount tag during interest accrual |
SE-IAC2-008 |
Failed in populating interest accrual details |
SE-IAC2-009 |
Failed in populating tax accrual details |
SE-IAC2-010 |
SE-IAC2-011 |
SE-IAC2-012 |
Failed in populating accrual period |
SE-IAC2-013 |
Failed in populating accrual details for a position |
SE-IAC2-014 |
Failed in populating accrual details for a portfolio |
SE-IAC2-015 |
Failed in logging exception during interest accrual |
SE-ICLC-001 |
Failed in computing interest for cum period |
SE-ICLC-002 |
Failed in computing interest for ex period |
SE-ICLC-003 |
Failed in computing interest amount |
SE-ICLC-004 |
Failed in building period table for interest |
SE-ICLC-005 |
Failed in building interest rate table |
SE-IMV1-001 |
Failed in populating period accrual |
SE-IMV1-002 |
Failed in populating interest quantity movement |
SE-IMV1-003 |
Failed in populating purchased and sold interest |
SE-IMV1-004 |
Failed in populating purchased and sold tax |
SE-IMV1-005 |
Failed in building daily queue for interest rebuild |
SE-IMV1-006 |
Failed in building daily queue for interest accrual |
SE-IMV1-007 |
Failed in interest period adjustment |
SE-IMV1-008 |
Failed in tax period adjustment |
SE-IMV1-009 |
Failed in populating interest adjustment details |
SE-IMV1-010 |
Failed in populating tax adjustment details |
SE-ISRV-001 |
Failed in obtaining interest value date variance |
SE-ISRV-002 |
Failed in building deal array |
SE-ISRV-003 |
Failed in building cash flow array |
SE-MRKT-001 |
Failed in computing market spot date |
SE-MRKT-002 |
Failed in computing market Ex date |
SE-MRKT-051 |
Failed to get market details while computing spot date |
SE-MRKT-052 |
Market Record is not authorized |
SE-MRKT-053 |
Failed to get the next working day while computing spot date |
SE-MRKT-054 |
Failed in holiday check while computing spot date |
SE-MRKT-055 |
SE-MRKT-056 |
SE-MRKT-057 |
SE-MRKT-058 |
No record found for market spot date |
SE-MRKT-059 |
Error during getting market spot date |
SE-MRKT-060 |
Zero days got when computing the days in a month |
SE-MRKT-061 |
Failed in setting the date to the correct format while computing spot date |
SE-MRKT-062 |
Failed to set the date to the correct format |
SE-MRKT-063 |
SE-MRKT-064 |
SE-MRKT-065 |
Failed to get next working date while computing spot date |
SE-MRKT-066 |
Failed to get spot date |
SE-MRKT-067 |
Failed to get market details while computing ex date |
SE-MRKT-068 |
SE-MRKT-069 |
Could not get Ex date |
SE-MRKT-070 |
Error in holiday check while computing ex date |
SE-MRKT-071 |
Failed in holiday check while computing ex date |
SE-MRKT-072 |
Failed in getting next working day when computing ex date |
SE-MRKT-073 |
Failed to get next working day when computing ex date |
SE-MRKT-074 |
Market Ex date details not maintained |
SE-MRKT-075 |
Market Ex date details not correctly maintained |
SE-MRKT-076 |
Failed in getting the number of days in the month |
SE-MRKT-077 |
Error while setting the format for the date while computing ex date |
SE-MRKT-078 |
Could not set the ex date to the correct format |
SE-MRKT-079 |
SE-MRKT-080 |
SE-MRKT-081 |
SE-MRKT-082 |
SE-NONE |
SE-ONLXXX |
SE-RVL0-001 |
Failed to build array queue in revaluation |
SE-RVL0-002 |
Failed in getting periodic revaluation date |
SE-RVL0-003 |
Failed in periodic revaluation |
SE-RVL0-004 |
Failed in getting market price for revaluation |
SE-RVL0-005 |
Failed in reversal of revaluation |
SE-RVL0-051 |
Price record could not be obtained for revaluation |
SE-RVL0-052 |
Price record is not authorized for revaluation |
SE-RVL0-053 |
Price record is not open for revaluation |
SE-RVL1-001 |
Failed in revaluation for a position |
SE-RVL1-002 |
Failed in getting position balance for revaluation |
SE-RVL1-003 |
Failed in processing for unsettled legs for revaluation |
SE-RVL1-004 |
Failed in mark to market revaluation |
SE-RVL1-005 |
Failed in computing amount tags for revaluation |
SE-RVL1-006 |
Failed in population of revaluation details |
SE-RVL1-007 |
Failed in population of revaluation details for a position |
SE-RVL1-008 |
Failed in passing portfolio level accounting entries |
SE-RVL1-009 |
SE-RVL1-010 |
Failed in populating portfolio level entries |
SE-RVL1-011 |
Failed in building account entry list during revaluation |
SE-RVL1-012 |
Failed in processing amount tags during revaluation |
SE-RVL1-013 |
Failed in population of portfolio revaluation details |
SE-RVL1-014 |
Failed in reversal of revaluation for a portfolio |
SE-RVL1-015 |
Failed in logging exception during revaluation |
SE-RVL1-051 |
Unauthorized unsettled legs exist |
SE-SBRN-001 |
Failed in populating security details for other branches |
SE-SBRN-002 |
Failed to delete security details for other branches |
SE-SBRN-003 |
Failed to authorize security details for other branches |
SE-SKEV-001 |
Failed to register the event for the position |
SE-SO0008 |
Duplicate records during coupon population |
SE-SO0013 |
Failed to get security details during schedule population |
SE-SO0014 |
Interest revision sequence number does not exist |
SE-SO0015 |
Failed to delete security details |
SE-SO00610 |
SE-SPOP-024 |
Failed to get SK settlement account |
SE-SPOP-026 |
Issuer payment currency is not the same as the SK account currency |
SE-SPOP-027 |
Failed to get Portfolio Settlement currency |
SE-SPRC-001 |
Failed in stock to cash processing for branches |
SE-SPRC-002 |
Failed in stock to cash event processing |
SE-SPRC-003 |
Failed to get subsystems flags in stock to cash processing |
SE-SPRC-004 |
Failed in processing stock to cash amount due |
SE-SPRC-005 |
Failed in processing stock to cash tax amount due |
SE-SPRC-006 |
Failed in processing charge for stock to cash conversion |
SE-SPRC-007 |
Failed in processing transaction tax during stock to cash conversion |
SE-SPRC-008 |
Failed in processing settlements during stock to cash processing |
SE-SSRV-001 |
SE-SUTL-001 |
Failed to get security face value period |
SE-SUTL-002 |
Failed to get coupon period |
SE-SUTL-051 |
Failed to get the security face value for the date |
SE-SUTL-052 |
Face value for security not maintained correctly |
SE-SUTL-053 |
SE-SUTL-054 |
Failed to get the coupon period for this date |
SE-SUTL-055 |
Coupon period records not correct |
SE-ACCT-001 |
Failed to pass leg accounting entry |
SE-ACCT-002 |
Failed to pass position entry |
SE-ACCT-003 |
Failed to pass portfolio level entry |
SE-ACCT-004 |
Failed to lookup product accounting entries |
SE-ACCT-005 |
Failed to lookup position accounting entries |
SE-ACCT-006 |
Failed to fetch accounting head |
SE-ACCT-007 |
Failed to delete for an event |
SE-ACCT-008 |
Failed to authorize for the event |
SE-ACCT-009 |
Failed to reverse all the leg entries |
SE-ACCT-010 |
Failed to reverse all the position entries |
SE-ACCT-011 |
Failed to reverse entry for an event |
SE-ACCT-051 |
Class is not open |
SE-ACCT-052 |
Class is not authorized |
SE-ACCT-053 |
GL record status is not open |
SE-ACCT-054 |
GL is not authorized |
SE-ACCT-055 |
Class is not open |
SE-ACCT-056 |
SE-ACCT-057 |
SE-ACCT-058 |
SE-ACCT-059 |
Class is not open |
SE-ACCT-060 |
SE-ACCT-061 |
SE-ACCT-062 |
SE-ACCT-063 |
GL is not open |
SE-ACCT-064 |
SE-ACCT-065 |
Failed to get accounting head |
