Once an instruction has been recorded in the system, it will be executed on the due date by an automatic process. This automatic process has to be executed twice everyday, as follows:
When an instruction is processed at regular intervals, chances are that a due date falls due on a holiday. In such a case, the due date has to be adjusted to be processed on a working day. This adjustment can be made in one of the following ways:
The above mentioned cases can be handled at the product level in order to adjust the due date on a working day.
If the due date is brought backward or pushed backward, the value date of the accounting entry for the instruction will be the working day on which it was processed.
Note
Sometimes, an adjustment of the due date makes it fall on a month other than the one it was originally due. Under such circumstances, the adjustment will made in such a way that the due date is retained in the month of the original due date. The adjustment may be in the form of an exactly opposite action from that defined for the product -- the due date may be backward for a product with the forward code, and vice versa.
Thus, whether an instruction will be picked up for processing also depends on your holiday handling specifications, as it does on the frequency and the first value date defined for the instruction.
On the day a cycle of an instruction is processed, its details will be put onto the SI Cycle Due table. The following information will be available for a pending cycle in this table:
For each retry that is done for a cycle, the following details are shown:
Failure advices are generated when the SI retries reach ‘Retry Count for Advice’ maintained at product level for all loan categories. The first try to execute the instruction is also considered for the retry count.
Consider the following example.
The following example provides an overview of generation of ‘Failure Advice’:
If,
Advice |
Period |
Execution Periodicity |
8 Days |
Maximum Retries |
5 |
Retries for Advice |
2 |
Then,
SI Cycle |
Retry Count |
SI Status |
Failure Advice Generation |
1 |
1 |
R |
No |
1 |
2 |
R |
Yes |
1 |
3 |
R |
No |
1 |
4 |
R |
No |
1 |
5 |
I |
No |
2 |
1 |
R |
No |
2 |
2 |
R |
Yes |
2 |
3 |
R |
No |
2 |
4 |
R |
No |
2 |
5 |
I |
No |
Failure advices are generated only during second retry.
You need to specify the standing instruction cycle details in the following screen. You can invoke this screen by typing ‘SIDXCYCL’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
Once an instruction is past its Value Date for the current cycle, any change to the terms can be made only through the SI Cycle Details table. However, for such an instruction, you can change only the following values:
This advice will be generated for a collection instruction cycle, till you tick the Collection flag field. You would do this when the amount that has to be collected on behalf of your customer has come in.
Intraday Sequence Number
The system displays the effective number of times the corresponding SI group has been executed.This will be irrespective of whether the particular instruction has met the sweep condition or not.This value will be displayed only for Intraday Group Instructions. For instructions which are not executed during intraday, value would be zero.
If a SI group has been executed five times and reversed three times on a given day, the intraday sequence number would be displayed as two.
Note
The following are the operations you can perform on the SI Cycle Details screen:
Refer to the manual on Common Procedures for details on these operations.
During Beginning of Day, the payments, variable payments, sweeps and collections that were defined for this stage (either for the product under which they are processed or the instruction itself) will be executed. The details of the cycle will be updated in the SI Cycle Details table, with the appropriate Execution Status.
For those instructions that have been defined with an Action Code of full pending or partial liquidation, the retries will be executed during Beginning of Day only if the instructions are defined for beginning of day execution.
The accounting entries defined for the payment and the charges will be passed. For a collection however, only the Collection Advice will be generated. To recall, this advice will be generated till the Collection Flag is ticked for an instruction.
The advices defined for the instruction will be put in the Outgoing Message Browser. They could be one or more of the following:
You can generate them from the browser, or carry out any other messaging related operations.
Note
Variable payments for which no amount has been defined for the cycle will be given an Execution Status of unprocessed. These will be processed only if you enter an amount for them in the SI Cycle Details screen.
At this stage of end of cycle processing, the following transactions will be executed:
For those instructions that have been defined with an Action Code of full pending or partial liquidation, the retries will be executed during end of day only if the instructions are defined for end of day execution.
Note
You can view the notifications for partially executed SI through the external system. This notification is triggered for the ‘PEXC’ event.
You can view the notifications for successfully executed SI through the external system. This notification is triggered for the ‘SUXS’ event.
You can view the notifications for rejected or failed payment requests through the external system. This notification is triggered for the ‘REJT’ event.
