1. Preface
1.1 Introduction
This manual is designed to help you maintain and process taxes on the contracts you process in Oracle FLEXCUBE.
You can further obtain information specific to a particular field by placing the cursor on the relevant field and striking <F1> on the keyboard.
1.2 Audience
This manual is intended for the officers at your bank who set up tax components.
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Organization
This manual is organized as follows:
Chapter
Description
Chapter 1
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual.
Chapter 2
Building Tax Components explains the process of maintaining the tax details which arise due to the transactions handled with custom­ers. Building Tax Components explains how tax rules, tax classes, and tax schemes are defined in Oracle FLEXCUBE.
Chapter 3
Reports provides a list of reports that can be generated in this mod­ule and also explains their contents.
Chapter 4
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation.
1.5 Glossary of Icons
This User Manual may refer to all or some of the following icons.
Icons
Function
Exit
Add row
Delete row
Option List
1.6 Related Documents
For further information on procedures discussed in the manual, refer to the Oracle FLEXCUBE manuals on:
