Parameters
name—A given name for this IFC profile element. This name is referenced from the sip-registrar configuration element’s ifc-support parameter.
state—Running status of this IFC profile.
- Default: enabled
- Values: enabled | disabled
shared-ifc-filename—The name of the file referenced for shared IFC function.
default-ifc-filename—The name of the file referenced for default IFC function. This file may be the same as that used for the shared IFC function.
options—Identifies a set of features that vary depending on the configuration element in which they occur and that are enabled by invocation in the options parameter. Set the options parameter by typing "options", a Space, and then the option name preceded by a plus sign. If you type the option without the plus sign, you will overwrite any previously configured options. To append the new options to this configuration's options list, you must prefix the new option with a plus sign. Prefixing an option with a minus sign removes it from the list of options.
