diameter-manip
When the action is set to diameter-manip, the Oracle Communications Core Session Manager executes the diameter-manipulation name configured in the new value. The diameter-manipulation name in the new value must match another diameter-manipulation name exactly (case is sensitive).
diameter-manip action type is primarily to reuse diameter-manipulations that may be common to other use cases. A diameter-manip action should never call back to itself either directly or indirectly through a different diameter-manipulation.
