Parameters
name—Configured name of this home subscriber server.
- Default: empty
state—Running status of this home subscriber server.
- Default: enabled
- Values: enabled | disabled
transport— The layer 4 protocol used to communicate with this home subscriber server.
- Default: tcp
- Values: tcp | sctp
address—This home subscriber server’s IP address.
- Default: none
- Values: IP address in IPv4 or IPv6 format
port—This home subscriber server’s port.
- Default: 80
- Values: 1-65535
realm—Oracle Communications Core Session Manager realm-config name where this home subscriber server exists.
- Default: none
multi-homed-addrs— Specifies one or more local secondary addresses of the SCTP endpoint. This setting is only applicable to SCTP transport. To enter multiple addresses, bracket an address list with parentheses. At least one address is required if transport is set to SCTP.
Multi-homed addresses must be of the same type (IPv4 or IPv6) as that specified by the address parameter. Like the address parameter, these addresses identify SD physical interfaces.
origin-host-identifier—Used to create segment before the dot in the Origin Host AVP.
- Default: none
origin-realm—Populates the value of the Origin Realm AVP. Populates the segment after the dot in the Origin Host AVP.
- Default: none
destination-host-identifier—Used to create segment before the dot in the Destination Host AVP.
- Default: none
watchdog-ka-timer— The interval in seconds of the watchdog/keep-alive messages.
- Default: 0
- Values: 0-65535
num-auth-vector— The number of authentication vectors downloaded from the HSS per MAR.
- Default: 3
- Values: 1-10
