SLRM Base Configuration Elements
This section provides configuration samples of elements used for minimal Oracle SLRM operation.
SLRM Configuration
| Set the component type to SLRM |
ORACLE# set-component-type core-load-balancer WARNING: Changing component type is service impacting. ******************************************************** Ensure that you follow these steps if you choose to change the component type: 1. Issue the delete-config command. 2. Reboot. ******************************************************** Continue with the change [y/n]?: |
| The SIP Config must be enabled |
sip-config
state enabled
| You must have a default gateway in your system-config |
system-config
default-gateway 10.0.0.1
| You must have a core physical interface |
phy-interface
name s1p0
operation-type Media
port 1
slot 0
| You must have a core network interface |
network-interface
name s1p0
sub-port-id 0
ip-address 192.170.2.100
netmask 255.255.255.0
gateway 192.170.2.1
| You must have a core realm |
realm-config
identifier core1
addr-prefix 0.0.0.0
network-interfaces s0p1:0
| You must have an ENUM Configuration |
enum-config
name My_e164_cfg
realm-id core1
enum-servers 192.170.2.201
| You must have a Subscriber Database |
home-subscriber-server
name My_HSS
address 192.170.2.202
realm core1
| Configure the Load Balancer Interface |
lb-interface
name My_lb_int
address 192.170.2.101
realm core1
| Configure the Load Balancer's Core Config |
lb-core-config
core-name My_core_config
domains My_first_domain, Other_domains
forwarding-realm core1
hss-config My_HSS
options e164-primary-config=enum:My_e164_Cfg
CSM Configuration (for SLRM)
| The System Config must specify a cluster-ID |
system-config
service-cluster-id cluster1
| The SIP Config must be enabled and define a hostname |
sip-config
hostname CSM1
registration-cache-limit 500000
| Set your Load Balancer Config |
lb-cfg
name My_lb_config
realm core1
| Set your sip-registrar for Load Balancing |
sip-registrar
ims-core My_core_config
lb-list My_lb_config
