Parameters
name—Name for this enum-config to be referenced from within the system.
top-level-domain—The domain extension used to query the ENUM servers for this configuration.
realm-id—The realm-id is used to determine on which network interface to issue an ENUM query.
enum-servers—List of IP address that service the top level domain.
service-type—The ENUM service types you want supported in this ENUM configuration. Possible entries are E2U+sip and sip+E2U (the default), and the types outlines in RFCs 2916 and 3721.
- Default: E2U+sip,sip+E2U
query-method—the ENUM query distribution strategy
- Default: hunt
- Values: hunt | round-robin
timeout—The total time, in seconds, that should elapse before a query sent to a server (and its retransmissions) will timeout.
- Default: 11
cacheInactivityTimer—Enter the time interval, in seconds, after which you want cache entries created by ENUM requests deleted, if inactive for this interval.
- Default: 3600
- Values: 0-999999999
max-response-size—The maximum size in bytes for UDP datagram responses
- Defaults: 512
health-query-number—The phone number for the ENUM server health query; when this parameter is blank the feature is disabled.
health-query-interval—The interval in seconds at which you want to query ENUM server health.
- Default: 0
- Values: 0-65535
failover-to—Name of the enum-config to which you want to failover.
cache-addl-records—Set this parameter to enabled to add additional records received in an ENUM query to the local DNS cache.
- Default: enabled
- Values: enabled | disabled
include-source-info—Set this parameter to enabled to send source URI information to the ENUM server with any ENUM queries.
- Default: disabled
ttl—This value ets the TTL value (in seconds) for NAPTR entries in the local ENUM cache and populates when sending a NAPTR entry to the ENUM server.
- Default: 0
- Values: 1-2592000
order—This parameter value populates the order field with when sending NAPTR entries to the ENUM server.
- Default: 1
- Values: 0-65535
preference—This parameter value populates the preference field with when sending NAPTR entries to the ENUM server.
- Default: 1
- Values: 0-65535
