show load-balancer
On the device running the SLRM function and any load balanced Oracle Communications Core Session Managers, the show load-balancer command is the root command for displaying all load balance statistics. The various arguments the command supports narrows the output for clarity and specificity.
Arguments
stats [load balancer name]—Shows cumulative statistics on a per load-balancer basis. Adding a load-balancer-name as an argument narrows the output to the load-balancer specified.
members—Shows statistics on members in a cluster.
cores <core-name>—Shows load balance statistics on a per-core basis. Adding a core-name as an argument narrows the output to the core specified.
interface <argument>—Shows the cumulative statistics for all load balance interfaces on this device.
- lb-interface-name—Adding an interface-name as an argument narrows the output to the interface specified.
- peer-address:port—Adding peer-address:port as an argument narrows the output to the address/port specified.
Example
ORACLE# show load-balancer interface if3
