Session Agent
To create a session agent to represent the third party server:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session router path.
ORACLE(configure)# session-router
Type
session-agent and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# session-agent ORACLE(session-agent)#
- hostname—Enter the name for this session agent.
ip-address—Enter the IP address for this session agent. This value must be the same as the registrar-host parameter in the third party regs configuration element to which this session agent definition corresponds.
Continue configuring this session agent’s parameters. Not all session agent functionality is applicable to the Oracle Communications Core Session Manager.
- Type done when finished.
