Actions on Found Match Value
When the match-value is found, the Oracle Communications Core Session Manager references the action parameter. This is configured as either none, add, delete, replace, store, diameter-manip, find-replace-all, log or group-manip and indicates the action to perform on the string. If the match-value is not found, the Oracle Communications Core Session Manager continues processing the message without any AVP manipulation. These actions mean the following:
