Re-balancing
Re-balancing is the process of taking some number of registered users from a functioning Oracle Communications Core Session Managers and redistributing them between other Oracle Communications Core Session Managers. Re-balancing occurs when manually invoked by the user from the Oracle Communications Core Session Manager using the release-users command.
The Oracle Communications Core Session Manager initiates a Reg-Event process to de-register the users. This process includes the following steps:
- The Oracle Communications Core Session Manager waits for users to send registration refresh.
- Upon receipt of the users first registration refresh, the Oracle Communications Core Session Manager sends an Administrative_Deregistration SAR to the HSS.
- The Oracle Communications Core Session Manager sends a 504 Server Timeout to any ensuing registration refreshes by the endpoint.
- The HSS sets the PUID to Not Registered and clears its S-CSCF association.
- The HSS sends an SAA back to the Oracle Communications Core Session Manager.
- The Oracle Communications Core Session Manager de-registers the user.
- The Oracle Communications Core Session Manager sends a NOTIFY messages to all REGEVENT subscribers indicating the de-registration event has taken place.
Note that the Oracle Communications Core Session Manager can accept new registrations during the re-balance process. The process includes a time out at 30 minutes, after which the release-user command stops releasing users regardless of whether it has reached the configured user count. If the user issues the release-users command again, the Oracle Communications Core Session Manager re-starts the process. After completion, the Oracle Communications Core Session Manager echoes a message indicating the re-balance is complete.
If an HA switchover occurs before the release-users command has finished, the process does not continue to release users. If desired, the user can re-issue the command on the backup system after the switchover is complete.
