Product Functional Matrix
The SLRM is a component of the Oracle CSM/USM product group, which Oracle develops using the same software, basing the discrete operational functionality on configuration and deployment within an IMS core. The Oracle USM and Oracle CSM are distributed as separate products. The Session Load Balancer and Route Manager (SLRM) is distributed as a special configuration of an Oracle CSM.
Refer to the table below to understand product nomenclature as specified by configuration and functionality. Minimum configuration excludes universally common box configurations, such as interfaces and realms.
| Nomenclature | Minimum Configuration | Functionality |
| OC-CSM | registrar, home-subscriber-server, authentication-profile | IMS S-CSCF and I-CSCF |
| OC-USM | ims-access, registrar, home-subscriber-server, authentication-profile | MS P-CSCF, I-CSCF and S-CSCF |
| SLRM | set-component-type, lb-interface, lb-core-config | I-CSCF, Proprietary I-CSCF Load Balancing |
References to these product names must be understood within the context of their nomenclature and configuration for the purposes of understanding which functions they perform and which functions they do not perform.
